UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Mar 15, 2015 at 9:59 PM
    #3981
    TRDEAN
    TRDEAN Too bad it’s a PreRunner
    Austin
    Dobbins, CA
    04 Prerunner
    Speedometer, tailights (going to change), sub and amp, Kenwood Head unit Bilstein 5100 on rear CB RADIO smoked tail lights eagle wheels Kenda Klever MT Icebeam bulbs (superwhite) I WANT RETROFITS!
    Call me dumb, but does that actually mean run? Or wheeling. :eek:
  2. Mar 16, 2015 at 6:39 AM
    #3982
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    hahaha, WHEEELINNNNNNN
    i dont run.. :anonymous:
  3. Mar 16, 2015 at 7:46 AM
    #3983
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
  4. Mar 16, 2015 at 12:30 PM
    #3984
    squeethebee
    squeethebee Well-Known Member
    Ed
    slcut
    04 TRD double cab
    32's, tg bumpers, budbuilt skids, OME lift, some audio
    It was good times. We drove up a hill.
    05FC123C-50B6-46D1-9988-5DF445A32C10_zps_8996315540eaf212ab0d374be04c26f093ee662c.jpg
    05CCEA58-968C-4537-B232-2EA60B5BC605_zps_eb74311f25cdbd7a3975c32229bf826fb00a38ee.jpg
    644BEF96-C029-4611-9483-1ABF4EB88D59_zps_c51eb62f62b5085e7dd1bd00812b61b57f738b24.jpg
  5. Mar 16, 2015 at 12:49 PM
    #3985
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
  6. Mar 16, 2015 at 1:31 PM
    #3986
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
  7. Mar 18, 2015 at 9:55 AM
    #3987
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    Good afternoon everyone!
    Just had a quick question. I have those adjustable LR UCA's and the 3" OME lift kit and it seems as if my alignment goes out of spec quite fast and I haven't even been out wheeling lately.
    So my question is: Since those are UCA's adjustable would they likely be getting loose while just doing my daily driving? any thoughts?
    Thanks!
  8. Mar 18, 2015 at 10:00 AM
    #3988
    BradyT88
    BradyT88 Well-Known Member
    I doubt they are moving while daily driving unless they are severely under torqued... Mine would move during rock crawling, but I have a pretty heavy rig.
    To fix this I maxed out the camber adjustment on the UCA and then torqued that nut to 200 ftlbs and it hasn't moved on me since. Even beating on my rig out in the dunes. There are two advantages to moving the camber adjustment out all the way as well. 1. Wider stance, slightly more travel (though minimal) and 2. You know where it goes now, so if you think it moved, you can check them and if they did move, then you can put it back yourself and won't have to get it realigned.
    How do your cam tabs on the LCA's look? They bend easy...
  9. Mar 18, 2015 at 1:23 PM
    #3989
    Hawaiisurfer
    Hawaiisurfer Well-Known Member
    Utah
    '01 Tacoma Double Cab
    Does anyone know any fun trails off of Provo canyon? My wife and I want to take the dog and get out this weekend. We just want something easy. Really looking for a fun drive in the mountains.
  10. Mar 18, 2015 at 1:45 PM
    #3990
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Thank you for your response sir!
    Sorry, might be a dumb question but will maxing out the camber have abnormal wear on the my tires or anything else?
    Ill be having an alignment check here soon too see if they are out of spec again so we will see. And might have to go that route if they are..
  11. Mar 18, 2015 at 1:54 PM
    #3991
    BradyT88
    You'll want to get it aligned after you max out the adjustment. Maxing it out will give you some positive caster making the tires do this \ /, then have the alignment techs adjust the camber back to 0* using only the LCA cams to get the tires back to | |. The cams have plenty of adjustment to do so. I'm actually running a little bit of negative camber on my setup / \.
  12. Mar 18, 2015 at 2:33 PM
    #3992
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    not much up provo canyon unfortunately, its really to early to go on alot of the higher elevation trails, do to closures and snow.
  13. Mar 18, 2015 at 2:48 PM
    #3993
    squeethebee
    Ed
    slcut
    04 TRD double cab
    I traded leaf peepers for those gates man...
  14. Mar 18, 2015 at 3:15 PM
    #3994
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Awesome thank you for your help sir!
  15. Mar 18, 2015 at 4:59 PM
    #3995
    big dog
    big dog Hug balls bitch
    Las Vegas
    03 SR5 TRD 4X4
    OME 3" k&n cai magnaflow muffler all pro front bumper 4x innovations rock sliders moto metal wheels with 33" Bridgestone dueler revo 2 AT tires
  16. Mar 19, 2015 at 9:48 AM
    #3996
    squeethebee
    Ed
    slcut
    04 TRD double cab
    52's Jake!!
  17. Mar 19, 2015 at 10:43 AM
    #3997
    big dog
    Las Vegas
    03 SR5 TRD 4X4
    Nice try but I think 37s are the biggest I can get :D
  18. Mar 19, 2015 at 11:30 AM
    #3998
    squeethebee
    Ed
    slcut
    04 TRD double cab
    37's Jake!
  19. Mar 19, 2015 at 1:14 PM
    #3999
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    haha! im fucking pissed dude! i just took my truck to some mechanic, just to look over a few things, and hes telling me i basically have to rebuild my whole rear end. wtf... it seams like its fine but idk enough about it.
  20. Mar 19, 2015 at 1:52 PM
    #4000
    big dog
    Las Vegas
    03 SR5 TRD 4X4
    I'll fix it...
    For the quad :D
