UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Nov 17, 2015 at 11:39 AM
    #4241
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I could use some help installing my ECGS bushing. So I will be watching this closely.
  2. Nov 17, 2015 at 1:20 PM
    #4242
    08TRDOFFROAD
    Dan
    I find the uinta's to be hit or miss. If you have a boat or float tube, Strawberry is where it is at for trophy trout. If you want to have a good time with kids or just catch a lot of small planters, Tibble Fork or Silver Flat up American Fork canyon are good.
  3. Nov 17, 2015 at 6:17 PM
    #4243
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    I'm still tied up with work at the moment but this will happen soon, do you have the bushing tool?
  4. Nov 19, 2015 at 10:58 AM
    #4244
    08TRDOFFROAD
    Dan
    I don't.
  5. Nov 19, 2015 at 11:50 AM
    #4245
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I have one you can borrow.
  6. Nov 19, 2015 at 5:28 PM
    #4246
    ZIB
    ZIB Well-Known Member
    Zach
    Rhode Island
    2014 TRD DCLB Sport
    Pelfreybilt front bumper steel full hoops Warn Zeon 10s winch Caliraised 20" slim light bar and amber 18w pods TRD exhaust Century High-C topper Stubs Welding SKO sliders Pelfreybilt Skids King 2.5 RR extended travel coil over with 650 springs and King 2.5 RR rear shocks Dakar leaf pack Total Chaos UCA BFG KO2 265/70/17 Cobra 75 wx st CB w/ 4' Firestik FS Rotopax 4 gallon gas can
    Provo river, middle and lower have some good fishing, better in the winter in my mind due to the fish being hammered all summer long. Jones Hole, a tributary off of the green, is a special place. And if you have a float tube or boat many of the reservoirs are great and hold some big fish. Found a great spot outside of Duschense, Canyon Lake or lake Canyon has some monster tiger trout. I've got an extra float tube too!
  7. Nov 20, 2015 at 12:17 PM
    #4247
    utahskierdave
    utahskierdave Well-Known Member
    salt lake
    08 tacoma dbl cab
    Anybody get their frame inspected yet?
  8. Nov 20, 2015 at 12:42 PM
    #4248
    08TRDOFFROAD
    Dan
    Nice! Thanks!
    I haven't yet...planning on taking it in next spring before the drop dead date the end of March. I don't plan on getting a replacement as I haven't seen anything super concerning when I have been under it poking around. But it will be nice to have a fresh undercoating done.
    utahskierdave[QUOTED] likes this.
  9. Nov 20, 2015 at 7:46 PM
    #4249
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Yep. At 2 different dealers. Failed at both. Been waiting 2 1/2 months for the frame so far.
  10. Nov 20, 2015 at 7:50 PM
    #4250
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone see what I see at Nitro Circus SLC?
  11. Nov 22, 2015 at 4:11 PM
    #4251
    08TRDOFFROAD
    Dan
    Which dealers? Did they put you in a loaner?
  12. Nov 25, 2015 at 7:09 AM
    #4252
    ervmcd
    ervmcd Well-Known Member
    Evan
    SLC, UT
    2014 TRD Off-Road DCSB
  13. Nov 25, 2015 at 7:16 AM
    #4253
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    lets go ev!
  14. Nov 27, 2015 at 8:00 AM
    #4254
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Im in bountiful utah working right now. Now that cold weather has hit im noticing my water pump is going out. The old girl has 115k on her and wont blow hot air on idle, but once the rpms spin up the hot air flows. Fluid level is fine and thermostat is good. I know there are dealers here, but wasnt sure if anyone in the area has a better option.
    Thank you
  15. Nov 27, 2015 at 9:05 AM
    #4255
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    I would say it's the heater core not the water pump, have u checked ur cabin filter lately
  16. Nov 27, 2015 at 9:08 AM
    #4256
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Why are you so sure the thermostat is still good?
  17. Nov 27, 2015 at 11:04 AM
    #4257
    Hartford
    Maine
    2011 Acc Cab 5spd
    I think its the water pump because hen the truck just idles she will climb to 194 but goes right back down when moving. Also heat is rpm dependant. Idle has no heat regular driving is fine. Havent checked cabin filter since I put the new one in in September. Its just what I was thinking. I certainly dont know a whole lot about it.
    Thermostat was changed in june because it wasnt opening. After the change out truck would run at 186 with a 185 tstat.
  18. Nov 27, 2015 at 3:52 PM
    #4258
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    I was under the impression that the water pump has nothing to do with the heat coming out of your vents, that has to do with the heater core, I may be wrong
  19. Nov 27, 2015 at 3:56 PM
    #4259
    Glueman
    Utah
    The Plague....
    Water pumps move water to cool the block. Heater cores get air blown on them to make heat in the cab using the block heated water.
  20. Nov 27, 2015 at 4:00 PM
    #4260
    Glueman
    Utah
    The Plague....
    Main sign of a failing water pump is a leaking Water pump seal. If you don't see any water leaks around the water pump, keep looking. Still not convinced your thermostat isn't bad (or a radiator blockage).
