UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Jan 26, 2019 at 5:16 PM
    #7581
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Anybody knows what to use or what to do if your stock antenna is slightly loose?
  2. Jan 26, 2019 at 9:17 PM
    #7582
    Oscar I
    Oscar I No longer a toyota driver
    Pull the headliner and tighten it down.
    Gunshot-6A and BOMBS like this.
  3. Jan 26, 2019 at 9:39 PM
    #7583
    BOMBS
    Ok, I'll try that.
  4. Jan 26, 2019 at 10:56 PM
    #7584
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    They still make those?
  5. Jan 27, 2019 at 5:39 AM
    #7585
    BOMBS
    I should have the same one like you do. The fin looking thing on top of the roof.
  6. Jan 27, 2019 at 12:50 PM
    #7586
    H3llRid3r
    SLcUT
    Roger. I was picturing the old school wip antennae, and I’m thinking AM radio.
  7. Jan 28, 2019 at 8:15 AM
    #7587
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    You can also rent this from Oreily's.
    https://www.oreillyauto.com/detail/...-race-and-seal-driver-set/67034/4700252?pos=9
    Gunshot-6A likes this.
  8. Jan 28, 2019 at 8:41 AM
    #7588
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Kpatt9 likes this.
  9. Jan 28, 2019 at 8:53 AM
    #7589
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I keep a 8mm?? open end wrench in my center console because I remove it when going through a car wash. I finally just gave up tightening it every time and now just hand tighten it. It finally broke off with the stem down in the hole. I was able to get the post out. At Autozone they have a standard replacement with a package of adapters. It's not quite as sturdy as the OEM one but works perfect. I also put a touch of anti-sieze on the threads. The OEM was like $25. Autozone was $9. I figure I can buy 3 replacements for the same cost if needed. I can listen to the Jazz, U of U sports, KSL, anything else just as well as OEM.
  10. Jan 28, 2019 at 9:08 AM
    #7590
    Gunshot-6A
    Conner
    Everett, WA
    He's got a 3rd gen with the radio antenna in the shark fin. Not the mast antenna like 1st and 2nd gens.
  11. Jan 28, 2019 at 11:46 AM
    #7591
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I found some Kings, Camburg UCAs and SCS Ray 10s up on KSL today. I'm not sure if the prices are good but maybe one of you guys are interested.
    Just search tacoma on KSL and you'll find em'
    08TRDOFFROAD and Meximan61 like this.
  12. Jan 28, 2019 at 11:51 AM
    #7592
    Gunshot-6A
    Conner
    Everett, WA
    Sounds exactly like my exact same setup. I'll take a look...
    Edit: Pretty decent deals, could probably haggle a bit, but not much.
    NIB Tacoma King Coilovers and Camburg UCA's $1950 - New are 1525 plus 5-600, so you're saving ~100-200 over new. You'll wanna check the spring rate though. Stock King offerings is 600# springs, but can be specced at 650 or 700 as well.
    NIB Toyota Tacoma SCS Ray 10 Wheels $750, Pretty decent deal since they are about $200 new AND are hard as balls to get a hand on. Saves you $50 + shipping and a crapload of time and effort. I'd snatch these up even if you just wanted to flip them.
  13. Jan 28, 2019 at 4:21 PM
    #7593
    BOMBS
    I don't think I need to tighten anything down on the shark fin antenna. The rubber seal has broken loose on the bottom of the shark fin antenna. So I want to prevent water and moisture getting underneath it by using some type of adhesive. Super glue did not work.
  14. Jan 28, 2019 at 4:22 PM
    #7594
    BOMBS
    Man...if those Ray 10s were 17 inch rims I would buy them.
  15. Jan 28, 2019 at 5:17 PM
    #7595
    P.Blackley
    P.Blackley Well-Known Member
    Patrick
    Layton, UT
    99 Tacoma 4WD SR5
    Fox extended coilovers, LR UCA's, Deaver J59's W/ 12" Fox triple bypass shocks
    Gunshot-6A[QUOTED] likes this.
  16. Jan 28, 2019 at 5:45 PM
    #7596
    H3llRid3r
    SLcUT
  17. Jan 28, 2019 at 10:56 PM
    #7597
    Gunshot-6A
    Conner
    Everett, WA
    12 mpg was just a bridge too fafar on that for my DD. Might pick one up as a side piece one day.
    Just thinking about going to a slightly bigger size.
  18. Jan 29, 2019 at 5:24 AM
    #7598
    H3llRid3r
    SLcUT
    Roger that.
  19. Jan 29, 2019 at 2:45 PM
    #7599
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Meximan61 and Gunshot-6A like this.
  20. Jan 29, 2019 at 2:46 PM
    #7600
    Gunshot-6A
    Conner
    Everett, WA
