UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Jul 16, 2019 at 7:44 AM
    #9281
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    KSL. Not sure if any place like Sam Evans or whatever does secondhand.
  2. Jul 16, 2019 at 8:48 AM
    #9282
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    What do you need done?
  3. Jul 16, 2019 at 6:42 PM
    #9283
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Looking at getting the Bud Built weld on traction bar.
  4. Jul 16, 2019 at 7:13 PM
    #9284
    vonellis
    Some and some more
    Pm’d Ya
  5. Jul 17, 2019 at 4:32 AM
    #9285
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Can you install a cab mount relocation kit?
  6. Jul 17, 2019 at 5:39 AM
    #9286
    Mohedano1
    Mohedano1 Well-Known Member
    Ogden, Utah!!
    '15 4wd DCSB TRD Offroad
    Total Chaos uca, King 700lb extended coilovers, King Tundra rear shock w/resi, BruteForceFab Hybrid front bumper, BruteForceFab rear HC bumper, BAMF skidz. 315/75/16 cepek extreme country, 4.88 gears, front arb locker. Rci sliders and diff skid
    Which kit are you installing?!!
  7. Jul 17, 2019 at 6:56 AM
    #9287
    BOMBS
    Alpine Designs.
    Mohedano1[QUOTED] likes this.
  8. Jul 17, 2019 at 9:24 AM
    #9288
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Why not do the traditional CMC? It's much easier.
    H3llRid3r likes this.
  9. Jul 17, 2019 at 11:06 AM
    #9289
    BOMBS
    I have. I'm on my second chop.
  10. Jul 17, 2019 at 1:48 PM
    #9290
    vonellis
    Some and some more
    No I have a friend who is a fabricator/ mechanic who helps me with my builds. He could do it though no problem. I can get you his information if you want it.
    H3llRid3r and JKO1998 like this.
  11. Jul 17, 2019 at 2:59 PM
    #9291
    BOMBS
    Sweet. Hook me up with his contact info please.
  12. Jul 18, 2019 at 10:09 AM
    #9292
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Here are some random Paris pics.
    AE9BAD82-F6B1-45A5-A6AB-6EA3BD1BEF7F.jpg E24999FD-EE1A-4320-BDB7-31B186018128.jpg 5CA03095-A8FB-4C19-8082-D0B24AAC2844.jpg 0D2CE975-FEF5-4741-8490-850D6142D567.jpg 5B44A4D3-26AD-44AB-BA79-52D53B715C35.jpg
  13. Jul 18, 2019 at 11:56 AM
    #9293
    BOMBS
    Paris looks dope.
    H3llRid3r[QUOTED] and Gunshot-6A like this.
  14. Jul 18, 2019 at 2:30 PM
    #9294
    Gunshot-6A
    Conner
    Everett, WA
    Paris is cool. Lots of better towns to go and see, but Paris is a must at least once. Colmar on the German border was prob my favorite town in France I've stayed in.
    BOMBS[QUOTED] likes this.
  15. Jul 18, 2019 at 4:04 PM
    #9295
    BOMBS
    One day I will visit Europe, as for now I still have a list of places I need to go and see here in the states.
    H3llRid3r and Gunshot-6A[QUOTED] like this.
  16. Jul 18, 2019 at 9:15 PM
    #9296
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone have or know anyone that has some 15x10/ 6x5.5 laying around?
  17. Jul 19, 2019 at 6:18 AM
    #9297
    H3llRid3r
    SLcUT
    It is.
  18. Jul 19, 2019 at 8:43 AM
    #9298
    slcTaco4321
    slcTaco4321 New Member
    2008 sport double cab long bed
    Anyone have any recommendations for shops in the salt lake area to install a lift kit? Went at it last night but ran into issues with lower shock bolts that were welded into place. Went at it with everything we had pb blast, heat, hammer, air hammer... We were able to get the rear shocks swapped out but had to break out the z wheel saw to cut the lower shock bolts out. We couldn't get a good angle on the bolts in the front with out a complete disassemble so here I am looking for a shop to finish the work. Front struts are already completely assembled and I have an aal to add in the rear. Currently have quotes ranging from 450-725. Anyone have better luck elsewhere?
  19. Jul 19, 2019 at 8:31 PM
    #9299
    Little Bruiser
    Little Bruiser Well-Known Member
    Jon
    Salt Lake City
    2014 tacoma TRD
    Ready for a little fishing tomorrow
  20. Jul 19, 2019 at 9:43 PM
    #9300
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    I was in Colmar a couple years ago, such a cool town! Was staying in Strasbourg and fell in love with that place.
    Gunshot-6A[QUOTED] and H3llRid3r like this.
