UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Oct 17, 2019 at 11:37 AM
    carcinoid
    carcinoid Well-Known Member
    I have a non-truck question for my fellow Utah residents. Does anyone have heat coils on their roof to prevent ice damns? The entrance to our house is inset and doesn't get much direct sunlight during the winter. We had lots of overflow in this area and it covered the entire entryway in a flat sheet of ice. Got a quote from a company that will install the stuff and do all of the electrical in my roof. I attached their quote diagram. Thoughts?
  2. Oct 17, 2019 at 3:31 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I ran Duratracs for 7 years on my Tacoma. When I went to a bigger tire and wheel combo, I went with the Cooper ST Maxx
    08TRDOFFROAD and Gunshot-6A like this.
  3. Oct 17, 2019 at 4:16 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’m running the STMaxx and I really like them. They’re great off-road in everything but the worst clay mud, but there aren’t many tires that can efficiently clear nasty stuff like bentonite. The only real downside for me is the load rating and the weight, but I don’t really care about that too much. They’re 315s, so they’re heavy suckers anyway.
    Gunshot-6A likes this.
  4. Oct 17, 2019 at 4:26 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    I liked this advice from Kurt Williams (owner of Cruiser Outfitters) that he posted on UTOR when someone asked about tires
    For searchibility / posterity:
    Everyone's favorite tire is the last one they purchased in 95% of cases. It's literally like asking what their favorite shoe is.
    That said, I've BFG's have the market share they do for a reason, they just work. They aren't perfect in every way or perhaps any way but they are a good cross section of longevity, performance and reliability. I've driven around the world on BFG's (literally) and driven the length of the Baja 1000 without a failure. No mistake we've had some fail racing but in most circumstances it's been a wheel failure that resulted in a damaged tire.
    I'm also loving the General X3 tires, they have a robust sidewall that continues to impress me. I did manage to destroy one on a sharp Moab rock but I dont know that any tire would have faired better. My next purchase is some X3's for a Land Cruiser project... my 2 cents.​
    Kpatt9, Gunshot-6A and H3llRid3r like this.
  5. Oct 17, 2019 at 6:26 PM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    I have had two sets of Toyo Open Country Mud Terrains (255/85/16). My truck isn't my daily so if I would probably go with an all terrain if it was. I like how robust the sidewall is, and have not had one fail yet especially when aired down to 15 psi.
    H3llRid3r likes this.
  6. Oct 17, 2019 at 7:24 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I vote ST Maxx for a daily
    Gunshot-6A and jubei like this.
  7. Oct 17, 2019 at 7:58 PM
    jsi
    jsi Well-Known Member
    native earthling
    Looks pretty good to me. The heat lines go where I'd put them and they've run a line in the down spout to keep that flowing too. I always threatened to do that at my old house but never did, so I can't share any experience about how well that tape works.
  8. Oct 17, 2019 at 8:21 PM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I can’t get the attachment to open.
    However, the big issue with heat tape is the quality of the heat tape and how it’s controlled. I like RayChem on a 2-4-8-12 timer switch. RayChem is on the pricey side but lasts a long time.
  9. Oct 17, 2019 at 8:22 PM
    H3llRid3r
    SLcUT
    Once again. Toyo MT’s FTW!
  10. Oct 17, 2019 at 8:34 PM
    km87
    km87 Well-Known Member
    Kurt
    Utah
    2005 Tacoma 4 cyl, 4WD, MT.
    I run 265/75R16, Pathfinder 10 ply or E rated, whatever the hell you want to call it on mine. They are a really solid tire all around. They play great all over Moab, the San Juan Mountains and in the snow.
  11. Oct 18, 2019 at 7:39 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Which dealer is best for 'repair' work? I'm tired of getting the run around by Karl Malone...thinking about heading to Brent Brown Toyota because thats the next closest one to me. Does anybody have experience with them?
    A metal post type thing got wedged up under my truck and cut one of the o2 sensors harnesses and now I'm getting all sort of errors codes and CEL...I repaired the wire but they are still on.....Karl Malone wouldnt look at it until I removal all my wiring accessories.
  12. Oct 18, 2019 at 7:47 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Brent Brown is dead to me. Tried to tell me a wheel bearing wasn't covered under the powertrain warranty despite me having the certified preowned manual they themselves gave me saying it absolutely was. LHM collision center in Orem did great work on my truck after a semi backed into it, and their front office person Kelsie is a tundra owner as well.
  13. Oct 18, 2019 at 7:48 AM
    km87
    Kurt
    Utah
    I’ve had nothing but great experiences with Mark Miller. My service advisor Chris is great to work with.
  14. Oct 18, 2019 at 7:49 AM
    eltacoutah
    eltacoutah Well-Known Member
    Ben
    Utah
    2010 TRD Sport
    Yeah brent brown tried to charge me $300 for a fog light..... ef that
    Gunshot-6A[QUOTED] and Technique like this.
  15. Oct 18, 2019 at 7:54 AM
    Technique
    Alex
    Utah
    Sounds like Mark Miller may be the way to go...damn. Didn't wanna drive up that far north. And can't get in there until Monday (for an app. with Chris anyways)...was hoping to drop it off tonight/tomorrow morning.
  16. Oct 18, 2019 at 7:57 AM
    km87
    Kurt
    Utah
    I know what you mean by wanting to drop it off as soon as possible. The waiting it out is is very difficult.
  17. Oct 18, 2019 at 8:00 AM
    Technique
    Alex
    Utah
    I've had my CEL on since last Saturday...happened out of state too lol. Just wanna get it in somewhere and fixed....tired of seeing it on. I've tried the past few nights on my own to get it going again but tbh I think the ECM is messed up, sadly.
  18. Oct 18, 2019 at 8:26 AM
    RyanL
    Indiana
    Mark Miller for the win. Absolutely worth the drive.
    So is Geoff Beers in Provo if you're open to a non-dealer route...
  19. Oct 18, 2019 at 8:34 AM
    Technique
    Alex
    Utah
    If the dealer cost is SUPER ridicilous I may go non-dealer. My truck is under warranty still so I hope to get everything patched up properly.
    H3llRid3r and Gunshot-6A like this.
  20. Oct 18, 2019 at 9:14 AM
    Technique
    Alex
    Utah
    Any of you guys that have gone to Mark Miller worked with Wendell McMullen service advisor? He's the only one with an appt tomorrow.
