UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Dec 19, 2019 at 5:54 PM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    H3llRid3r and Gunshot-6A like this.
  2. Dec 22, 2019 at 7:44 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    BOMBS and Gunshot-6A like this.
  3. Dec 22, 2019 at 7:58 PM
    calebc
    calebc Well-Known Member
    Been on my short list to get my license for many years. I need to just do it.
  4. Dec 23, 2019 at 6:40 AM
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Technique[QUOTED] likes this.
  5. Dec 23, 2019 at 6:55 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Present! Ham is a great asset to have as an adventurous type. I would highly recommend being an active member on some of the repeaters around the state, learn what the intermountain intertie is and how it works, and what aprs is. Ham more so than anything else is a great tool to potentially save you life over just being a trail walkie talkie.
    Id be glad to have you over and talk through various aspects to consider in use of ham.
    Regardless, Id upgrade your stock antenna to a Nagoya nr771. Cheap as anything and vastly improves your antenna performance
    H3llRid3r likes this.
  6. Dec 23, 2019 at 7:49 AM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    Most people who run CB have there antennae mounted in the wrong spot. I see this on jeeps a lot. They have it mounted on the tire carrier. The antennae just reflects off the back window. Best spots are in the enter of the roof or on the front bumper.
    My old neighbor is a CB nut. He has his own base station trailer that he tows to high mtn passes. He then starts the gen set and talks to his buddies across the states.
  7. Dec 23, 2019 at 7:55 AM
    Technique
    Alex
    Utah
    Thanks for the offer! I think for now I'm good, but down the road I may take you up on it.
    I just did some research on APRS and also EchoLink..both are very cool. I had no idea about any of them but I'll definitely look into getting that all setup.
    I almost ordered that antenna on Amazon with my radio, but got turned off because some reviews were saying worse or no improvement from the stock UV-5R antenna...so I was skeptical about it. Figured I'd see how the stock ones does and go from there.
    Gunshot-6A[QUOTED] likes this.
  8. Dec 23, 2019 at 7:58 AM
    concentric_killa
    My dad has been using Yaesu radios for years. No complaints. Little more than the baofeng but wont crap out after years of use. The larger 12V units can have one of the jumpers removed for more power, but you didnt hear that from me. :anonymous:
    https://www.amazon.com/Yaesu-FT-60R-Handheld-Amateur-Transceiver/dp/B00Q1UYR1G
  9. Dec 23, 2019 at 8:01 AM
    Technique
    Alex
    Utah
    I read those ones are good. I figure I'd dabble with a cheap radio first to see how much I use it and get into it before I drop 100+ on a nice radio.
  10. Dec 23, 2019 at 8:27 AM
    Gunshot-6A
    Conner
    Everett, WA
    I def notice a difference between the stock antenna and the 771. We use them as a part of staffing some offroad races and I can reach Weatherman on my radio and hear him back, and those around me with the oem ducky antennas just get static.
  11. Dec 23, 2019 at 9:04 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  12. Dec 23, 2019 at 11:45 AM
    NateMob
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Yep, always run the antennae where it can actually broadcast and receive, can't do that right next to the body. Either way, my handheld 8 watt with no external antennae blows away any CB setup i've ever wasted money on. Sure it could be better but i dont want to hardwire or permanently mount anything comm related in my 80.
    H3llRid3r and BOMBS like this.
  13. Dec 23, 2019 at 11:45 AM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    The bad reviews on the antenna probably come from the abundance of knockoffs that are available. Gotta make sure you get a genuine Nagoya, they generally are an improvement over the stock uv5r one.
    Check out miklor.com if you haven’t. Lots of great info on the baofengs including programming and antennas.
    Technique[QUOTED] and NateMob like this.
  14. Dec 23, 2019 at 12:36 PM
    Technique
    Alex
    Utah
    Where can I be sure I am getting a genuine one? I was looking at Amazon and that's where I saw the bad reviews.
  15. Dec 23, 2019 at 1:00 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Technique[QUOTED] and BOMBS like this.
  16. Dec 23, 2019 at 4:20 PM
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    How does a person gets tracked and identified for not having a HAM license while using a HAM to transmit?
  17. Dec 23, 2019 at 4:39 PM
    Technique
    Alex
    Utah
    That's a good question. I figure I'd rather not find out, hah. Taking the test seems easy enough...but I've been looking for a place to actually take the exam and there really isn't much options or times to take it around Lehi.
    BOMBS[QUOTED] likes this.
  18. Dec 23, 2019 at 5:16 PM
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    I actually took mine in Provo. Here’s one group that does them: http://user.xmission.com/~uarc/testinfo.html
  19. Dec 25, 2019 at 10:46 AM
    Technique
    Alex
    Utah
    Did a little wheelin last night! Merry Christmas to everybody.
  20. Dec 25, 2019 at 10:52 AM
    BOMBS
    Where is that tunnel located at?
