UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Jan 29, 2020 at 9:05 AM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Yes they're doing their job. Thanks again - life saver. Night and day difference. Never ended up bedding them though lol.
    08TRDOFFROAD likes this.
  2. Jan 29, 2020 at 9:19 AM
    Flash_Adalwolf
    Flash_Adalwolf cougar valley WA
    Patrick
    Marysville, WA
    CBI Rock Sliders, BAMF custom Grill, Fuel Vector wheels, switch-pro 9100,, prinsu roof rack caliraised LED 40" light bar and ditch lights, meso red LED map and dome light
    hey guys, im from Seattle area and im going to be heading down to the Mojave in March, im trying to decide if i want to just go through CA or go more east and come down and through Utah. and see the Valley of the gods, Grand Canyon and Zion. anyone have recommendations? i got about 3 days to sit and play in Utah
    H3llRid3r, BOMBS and Gunshot-6A like this.
  3. Jan 29, 2020 at 10:31 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Do it. Dont pass up on the opportunity. March is a good time to drive through Southern Utah
    Kpatt9, ginseng27 and RyanL like this.
  4. Jan 29, 2020 at 10:47 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    depends on how far "east" you want to go. "Valley of the gods" will be cool but it is quite the detour. but at the same time you could hit up moab area (arches, canyonlands, sand flats rec area [this is where famous jeep trails are]). Also would be able to hit monument valley. if you're that far east, you could probably hit up parts of lake powell as well. pop on down to the grand canyon from there. but it is quite a bit of driving. you'll probably eat up most of your 3 days just driving.
    if you want to hit up southwest Utah, you could hit up bryce national, capitol reef, and zion. Bryce and Zion are really close to each other. st george's snow canyon state park is pretty cool as well. Doing this route might afford you some more time in said places.
  5. Jan 29, 2020 at 11:33 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    I believe the guy putting it together already took care of all the set ups because we have our spots for both areas
    H3llRid3r and Gunshot-6A like this.
  6. Jan 29, 2020 at 11:33 AM
    GARSHA91
    Chicago
    Unfortunately he isnt i was trying o convince him to come
  7. Jan 29, 2020 at 12:41 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Just plan on getting to Zion early as balls in the AM to beat the crowd. Wont be so bad as in the summer but youre getting into spring break timeframe
    BOMBS likes this.
  8. Jan 29, 2020 at 8:40 PM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I’m interested.
    BOMBS likes this.
  9. Jan 29, 2020 at 9:09 PM
    spudboy82
    spudboy82 Weekend Warrior looking forward to Utah getaways!
    Sean
    Logan, Ut
    Blazin Blue DCLB
    2017
    A few weeks ago I got a set of 4 new tires I went with the Falken Wildpeaks 265/70/17 should I spend the money and get the matching spare or am I fine with the stock?
    Gunshot-6A likes this.
  10. Jan 29, 2020 at 10:32 PM
    Gunshot-6A
    Conner
    Everett, WA
    Id get the matching spare. I went up a size too and had this same debate. You can get away with the factory spare, but if your flat is on the back, youll need to pull one of the fronts, put it on the back, then put the spare up front. It also would take out your 4wd ability because the system cant handle a different sized tire safely when all 4 have power..
  11. Feb 2, 2020 at 7:22 PM
    ginseng27
    '17 DCSB OR
    not enough.
    avalanche course starting tomorrow...large storm coming in tomorrow...great timing.
    Gunshot-6A, BOMBS and H3llRid3r like this.
  12. Feb 2, 2020 at 8:16 PM
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Get your real life experience, training and possibly hero merit badge all in one day.
  13. Feb 2, 2020 at 8:24 PM
    Gunshot-6A
    Conner
    Everett, WA
    OK class, grab your stuff, your exercise...isn't
    Just remember, probe soft for friends, probe hard for enemies :rofl:
  14. Feb 2, 2020 at 8:27 PM
    ginseng27
    '17 DCSB OR
    not enough.
    What about frenemies?
    BOMBS and Gunshot-6A[QUOTED] like this.
  15. Feb 2, 2020 at 8:28 PM
    Gunshot-6A
    Conner
    Everett, WA
    Hard to find, soft to confirm :notsure:
  16. Feb 2, 2020 at 10:12 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Yesterday was a good day ... saw a red Bentley Continental GT near @Gunshot-6A ’s house, then came out from dinner to an R8 parked behind me. I expect they’re both headed back into hibernation with the storm coming in.
  17. Feb 2, 2020 at 10:27 PM
    ginseng27
    '17 DCSB OR
    not enough.
    Hey! That's r&r/tsunami in Lehi! My stomping grounds!
    08TRDOFFROAD and RyanL[QUOTED] like this.
  18. Feb 2, 2020 at 10:27 PM
    RyanL
    Indiana
    Nailed it! Met up with some friends at R&R and loaded up on some brisket.
  19. Feb 3, 2020 at 5:49 AM
    BOMBS
    What is R&R/Tsunami?....is that a restaurant?
  20. Feb 3, 2020 at 6:58 AM
    RyanL
    Indiana
    R&R is some great bbq, my 2nd favorite brisket in the state with Bam Bams taking the top prize.
    Tsunami is a pretty good sushi place from what I hear.
