UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Mar 23, 2020 at 9:39 PM
    calebc
    calebc Well-Known Member
    Are you talking about the Cherry Creek area? I used to ride dirt bikes out there quite a bit (haven't rode for a few years) and it was a blast. However, I don't know that there is all the much to "explore". The area is quite massive but is also used quite a bit, so you'd be with dirt bikes and those pesky sxs users all-day (probably not as bad as at the dunes).
  2. Mar 23, 2020 at 9:40 PM
    calebc
    Here's a map of the area.
    BOMBS likes this.
  3. Mar 24, 2020 at 6:09 AM
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Where did you get your flag from?
    Is it required for our trucks too?
  4. Mar 24, 2020 at 7:05 AM
    calebc
    You can get the flags at any motorcycle shop, Rocky Mountain atv, or even at the station there at the dunes. Anything in the rec area (car, truck, bike, sxs, etc) requires a flag.
    08TRDOFFROAD and BOMBS[QUOTED] like this.
  5. Mar 24, 2020 at 7:17 AM
    BOMBS
    Ok, thanks for the info. I'll look into getting a flag.
  6. Mar 24, 2020 at 7:57 AM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I don't claim to be any good at spelling. It's my kryptonite (had to Google spelling).
    I don't recommend the area I was in (Big Sand Mountain?). Too many motorcycles and side-by-sides. Not the best place for a 6,000 lb Taco. I was thinking more of the area to the north. There were lots of trails out there and I have no idea where they go...
    I believe the area I was in was Big Sand Mountain? Cherry Creek I believe was one of the camp grounds. I was thinking further north to explore and not so much in the park itself.
    I borrowed the flag. I had no clue that it was required for ALL vehicles that are out on the dunes. Too many people running around. A motorcycle rider was ran over by a side-by-side. Life flight was called in. Apparently, this happens a lot. There was a sign near the entrance that said "2 Days Since Last Accident". It was a bit chaotic out there.
    BOMBS[QUOTED] likes this.
  7. Mar 24, 2020 at 10:06 AM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    While I do get what you're saying, everyone will have an excuse. That was blatant disregard for everything thats going on right now. Hundreds - possibly a thousand shoulder to shoulder welcoming home hundreds (more?) home from out of the country. Child or not this is exactly what we've been asked not to do but because they're missionaries they get a pass? I mean come on. Whether you like it or not Mormons effect non-mormons lives substantially here in Utah, and sometimes you get a bad wrap for that by some people. Is that right? no. But it is what it is.
    08TRDOFFROAD, carcinoid and jubei like this.
  8. Mar 24, 2020 at 6:52 PM
    ronsenpai10
    ronsenpai10 That one Filipino guy with a Taco... and guns!
    Ron Christian
    SLC, Utah
    2019 Tacoma TRD OffRoad 4x4
    3" lift with Bilstein 5100s, OME coils, and an AAL package... so far.
    Do you have spacers for your tires so they don't rub on your UCA? Or how did you mitigate that?
  9. Mar 24, 2020 at 6:54 PM
    ronsenpai10
    Ron Christian
    SLC, Utah
    I heard the biggest problems with the OEM wheels with bigger tires is rubbing on the UCA and people recommend spacers if I want to stick with the OEM wheels... I thought about the beadlock-style wheels that toyota has but I haven't really heard much about them.
  10. Mar 24, 2020 at 8:28 PM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    I have a +3.5 long travel kit for the front, plus my wheel offset is a 4.75". The wheel offset is what is key for not rubbing on the UCA's. Check out this site..
    BOMBS and ronsenpai10[QUOTED] like this.
  11. Mar 24, 2020 at 8:31 PM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I don't have any personal experience with spacers, but they're generally not a great mod as they add a bunch of potential complications. I know it's more money, but upgrading wheels to something with less backspacing is the ideal solution. The cheapest option is probably to go with a narrower tire, but it's hard to say what size you'd need.
    ronsenpai10[QUOTED] likes this.
  12. Mar 24, 2020 at 9:09 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I have .75 spacers on the front only to clear my uca running a 285/70-17
  13. Mar 25, 2020 at 2:00 PM
    H3llRid3r
    SLcUT
  14. Mar 25, 2020 at 2:36 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Amen....today is dragging and I am exhausted!
    H3llRid3r[QUOTED] likes this.
  15. Mar 25, 2020 at 5:13 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
  16. Mar 26, 2020 at 8:43 AM
    H3llRid3r
    SLcUT
    Gunshot-6A[QUOTED] likes this.
  17. Mar 26, 2020 at 9:36 AM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    people keep talking about earthquakes and tremors and all i can think of is:
    Fohu, concentric_killa and H3llRid3r like this.
  18. Mar 26, 2020 at 9:44 AM
    08TRDOFFROAD
    Dan
    :bananadead:
    H3llRid3r likes this.
  19. Mar 26, 2020 at 9:49 AM
    08TRDOFFROAD
    Dan
    H3llRid3r and Gunshot-6A[QUOTED] like this.
  20. Mar 26, 2020 at 10:05 AM
    Gunshot-6A
    Conner
    Everett, WA
    Only a "bih" would make a mess like that. :rofl:
    Mission in Provo? Oh man, had to walk down the street huh? :rofl:
