UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Apr 23, 2020 at 11:00 AM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    You could detail my truck. It's just an idea.
    Gunshot-6A and RyanL like this.
  2. Apr 23, 2020 at 11:02 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I have one that would take him days
  3. Apr 23, 2020 at 11:20 AM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    lol! If I can use the supplies on mine too then I may be in.
  4. Apr 23, 2020 at 11:49 AM
    H3llRid3r
    SLcUT
    I have a particular way it needs to be done.
  5. Apr 23, 2020 at 11:50 AM
    H3llRid3r
    SLcUT
    I'm getting the impression that, that is what he's looking for.
    JKO1998[QUOTED] likes this.
  6. Apr 23, 2020 at 5:40 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I have to do this in the very near future. Please tell me it wasnt the lca hardware that gave you such a fight...
  7. Apr 23, 2020 at 5:41 PM
    JKO1998
    Utah
    Oooof
  8. Apr 23, 2020 at 5:45 PM
    08TRDOFFROAD
    Dan
    My front cam tabs are seized in the bushings and I can't get a proper alignment. I am hoping it is just the front two I am going to have to cut through...
    Gunshot-6A likes this.
  9. Apr 24, 2020 at 7:43 AM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    You should also do research on how regearing will affect the Odometer of the vehicle if you plan on actually selling it one day. On my truck 2011 V6 6-spd manual, my odometer reads more than what I have driven. This depends on where the speed sensors are on the truck. Manuals are different than the autos. One thing that bugs me about toyotas is the inability to actually tell the computer what gear/ tire combo you are running.
    I put this spreadsheet together a while ago. My tire/ gear combo is 4.56 and 255/85/16 (33's). I could increase to 35's and make my odo and actual miles driven match more closely. But I don't want the added wear on all the components.
  10. Apr 24, 2020 at 8:23 AM
    P.Blackley
    P.Blackley Well-Known Member
    Patrick
    Layton, UT
    99 Tacoma 4WD SR5
    Fox extended coilovers, LR UCA's, Deaver J59's W/ 12" Fox triple bypass shocks
    The cam sleeves were seized in the bushing. I was just using the blades I already had, I'm pretty sure there are better ones available for cutting through the sleeves that are much faster.
  11. Apr 24, 2020 at 8:57 AM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Now I'm really confused....I plan on regearing my truck very soon with 4.56 gears and am running the same size tires are you are. I too have a 6MT (2015). Right now with my 3.73 gears and 33" tires my odo/trip show lower than I have actually driven. So when I fuel up/do oil changes I always multiply my number by 1.07 (7% is what I've determined my speedo to be off by) to get the real numbers. So the part I am confused about is that after I regear, my odo (and speedo?) will read higher than I have actually driven? Why is this? Doesn't the truck track distance driven at the wheels/tires? I'm so confused...
  12. Apr 24, 2020 at 9:08 AM
    H3llRid3r
    SLcUT
    Today would be a good day to do the detail. Just saying.
  13. Apr 24, 2020 at 9:10 AM
    H3llRid3r
    SLcUT
    Status?
  14. Apr 24, 2020 at 9:33 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Duolingo to learn a new language
    Learn to play the guitar or other musical instrument (Biddies love Wonderwall :rofl:)
    Redo all the elctrical wiring with weatherpack connectors to get rid of janky butt splices
    wash and wax the truck
    Detail the interior
    wash and wax and detail MY truck...and also @H3llRid3r 's
  15. Apr 24, 2020 at 9:37 AM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Stalled with the passenger shock bolt that won't come out. The thread end is facing the bed side. I may need to drill an "access" hole in the bed to knock it out... :annoyed:
    Next, I'll grind off the OEM shackle hangers. Yeah sparks!
    H3llRid3r[QUOTED] and Gunshot-6A like this.
  16. Apr 24, 2020 at 9:44 AM
    concentric_killa
    Ok, I was adding vs. subtracting. So you are correct with stock gearing and 33's, your ODO mileage will read lower vs actual miles traveled. Due to the fact that the tire is larger and covers more ground per rev.
    Now the sheet makes a little more sense.
    For 33's and 4.10's, your ODO is nearly matched with the stock calibration. Increasing to 35's and 4.10's your odo should still read less since the larger tire is exceeding the gear selection.
    For 33's and 4.56, the opposite takes over. The tire size is essentially too small for the gear ratio, so my ODO mileage reads more. It has been a while since I checked this, so I could be wrong (i have given up caring). Trade off is that my truck crawls like a tractor in 4lo.
    Also on the freeway, my speedo will read 80mph when I am actually going 70.6 mph. I actually need an inline speedo calibration with a multiplier of 0.883745131. I have found an $80 Amazon unit that will work for the manual trans.
    Sna[QUOTED] likes this.
  17. Apr 24, 2020 at 9:59 AM
    H3llRid3r
    SLcUT
    Lets say you had to take your snowblower into the shop. Would it still fit in the back?
  18. Apr 24, 2020 at 10:01 AM
    Gunshot-6A
    Conner
    Everett, WA
    Little stuff like this...and the price tag...it exactly why I dont have a drifter already.
    RyanL and H3llRid3r[QUOTED] like this.
  19. Apr 24, 2020 at 10:02 AM
    H3llRid3r
    SLcUT
    ^^^^^^This
  20. Apr 24, 2020 at 10:04 AM
    H3llRid3r
    SLcUT
    Jeezus! I'm thinking cutting torch.
