UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Aug 13, 2020 at 3:54 PM
    jsi
    jsi Well-Known Member
    native earthling
    Over budget is definitely worse. The CFO explained it to me this way. The business budgets so much money every month. If you spend less that you said you would that could have gone to another department. The CFO was my boss so it wasn't like I had to go up multiple levels to talk to him.
  2. Aug 13, 2020 at 3:57 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Since like 07. But "active" members is WAY less than that.
    RyanL[QUOTED] likes this.
  3. Aug 13, 2020 at 6:20 PM
    Chako
    Chako Well-Known Member
    Utah
    1998 TRDOR M/T 2020 TRDOR M/T
    I wonder how many members have logged on within the past year.
    BOMBS, H3llRid3r and RyanL like this.
  4. Aug 15, 2020 at 5:22 AM
    Mohedano1
    Mohedano1 Well-Known Member
    Ogden, Utah!!
    '15 4wd DCSB TRD Offroad
    Total Chaos uca, King 700lb extended coilovers, King Tundra rear shock w/resi, BruteForceFab Hybrid front bumper, BruteForceFab rear HC bumper, BAMF skidz. 315/75/16 cepek extreme country, 4.88 gears, front arb locker. Rci sliders and diff skid
    My buddies and I just did black bear pass and other linked trails. You will be good, some spots get tight and we 2/3 point turned some of the switchbackz. One jeep friend has 43" mickey baja pro x 13.5"wide with 2" wheel spacers and he was made the routes.
    Gunshot-6A, BOMBS and H3llRid3r like this.
  5. Aug 15, 2020 at 11:03 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    whoa that’s some big rubber
    H3llRid3r likes this.
  6. Aug 15, 2020 at 6:39 PM
    Mohedano1
    Ogden, Utah!!
    Yup, we did holy cross today. I didnt do cleveland rock at the end but he made it in huge krazy jeep!! Some hiker stopped to watch, lol
    BajaAsh, Gunshot-6A, jubei and 3 others like this.
  7. Aug 15, 2020 at 6:41 PM
    Mohedano1
    Ogden, Utah!!
    Holy Cross,Colorado is a good trail!!
    Stxxx, Gunshot-6A, DJB1 and 3 others like this.
  8. Aug 15, 2020 at 6:45 PM
    Mohedano1
    Ogden, Utah!!
    Bear pass, Colorado
    RepoMarket, BajaAsh, Stxxx and 5 others like this.
  9. Aug 15, 2020 at 7:40 PM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Trails look intense. How many days did you spend in Colorado?
  10. Aug 15, 2020 at 7:45 PM
    H3llRid3r
    SLcUT
    I just received my Garmin Inreach Mini. Now to sort it all out. I’m not as savvy (or motivated) as I once was.
    It claims I can somehow map routes, but the screen seems way too small for that. Anyone use there’s to map routes?
    Gunshot-6A and BOMBS like this.
  11. Aug 15, 2020 at 7:53 PM
    Mohedano1
    Ogden, Utah!!
    4 Dayz
    H3llRid3r[QUOTED] and BOMBS like this.
  12. Aug 15, 2020 at 9:54 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I just got one too. Used it on a 7-day rafting trip. Seems great so far.
    I haven’t used any of the mapping features yet, just tried tracking for a bit while we were on the trip. But I think I general, all the features are easier to use and have more function when using the inreach through your phone
  13. Aug 16, 2020 at 10:39 AM
    H3llRid3r
    SLcUT
    You may have to give me a lesson.
    EDIT: Which plan did you go with?
    BOMBS likes this.
  14. Aug 16, 2020 at 6:55 PM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    I have an inreach, but not the mini. Even on the larger model its much easier to use your phone for most things. I don't find the phone app very intuitive either though, so I really only use it for texting when I'm out on an extended trip. It's always with me in the backcountry though, even just for the SOS peace of mind.
  15. Aug 16, 2020 at 8:58 PM
    H3llRid3r
    SLcUT
    I’ve not yet figured out how to text from my phone via the app.
  16. Aug 17, 2020 at 9:34 AM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Im having some problems with my brakes/steering again... Horrible steering wheel shake at about 55-65 mph and also when Im braking from high speeds, which has been getting progressively worse. Replaced rotors and pads and that seemed to fix it, but the problem came back relatively quickly. I'm thinking its either a wheel bearing or I have a seized caliper piston which has chopped up my rotors again already (3 months o_O).
    Geoff Beers, the mechanic I usually use isn't accepting new bookings right now so I'm in need of a recommendation for a trustworthy mechanic. Located in Salt Lake Valley but willing to travel for a good one.
    Gunshot-6A likes this.
  17. Aug 17, 2020 at 10:38 AM
    Gunshot-6A
    Conner
    Everett, WA
    Tacoma wheel bearings usually present as a howling sound around 40 and go silent on turns. You could lift the truck and shake the tire to check for play, then pop the wheel off and turn the hub by hard to check for "gritty" sections. A stuck piston could be the case and explains the rotor wear pattern if that's a repeat issue.
    I have a similar wobble at ~55mph and its from the pax side being knocked out of alignment vs the driver side, as evidenced by tire cupping. When's the last time someone looked at that?
    BOMBS and Kpatt9[QUOTED] like this.
  18. Aug 17, 2020 at 11:48 AM
    RyanL
    Indiana
    Great tips from @Gunshot-6A, put it in the air and do some preliminary checking.
    If you need a shop the guys at State Auto do great work, but they're also pretty busy and $$$ lately. I'd call the folks at Cruiser Outfitters and see what / who they recommend.
  19. Aug 18, 2020 at 8:02 AM
    BajaAsh
    BajaAsh Well-Known Member
    Ty
    Cedar City UT
    2013 TX Pro with all the goodies
    2.5 ext Kings TC UCAs Spydertrax 1.25 wheel spacers Ext. brake lines Cali raised side shooters Custom front grill
    Loaded up for Telluride! Any recommendations for those who have been?
  20. Aug 18, 2020 at 11:32 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Bruce at Bachmann Auto Repair. He is near downtown. 36 W. Fayette Ave. He does all the maintenance and repair work on my work vehicle and just did the brakes and A/C on my wife's Tahoe. He will treat you fair and not jerk you around.
