UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Jan 30, 2021 at 6:47 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    What they ^ all said. Clean it out and cover it back up with a bandage, add a few layers if your clothes are still felt rubbing.
    Gunshot-6A and H3llRid3r[QUOTED] like this.
  2. Jan 30, 2021 at 6:54 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Yes to both. Pharmacy should have a bottle of saline and an irrigation syringe.
    Syringe looks like this (doesn’t have to be curved, they come in straight too):
    Insert into water/saline, draw up to fill, aim at wound, spray. Repeat. Use lots. Cover with a bandage. Keep an eye on it. If redness/swelling/heat etc keep spreading, then you should go get checked out.
    BOMBS and H3llRid3r[QUOTED] like this.
  3. Jan 30, 2021 at 8:03 PM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Xcellent detail. Thx.
    I would post a pic but that might be overstepping the bounds. It does look a bit nasty and yes it’s quite warm to the touch.
    It’s good to hear from you.
    Thanks everyone for the info. I’ll hit the pharmacy in the morning for some supplies.
    Hopefully, everyone is catching Utes gymnastics on the Duce.
    BOMBS and Jiveydude[QUOTED] like this.
  4. Jan 30, 2021 at 9:51 PM
    H3llRid3r
    SLcUT
    Wound has been flushed with moonshine style saline and doused with neosporine. Finally, chased with some Four Roses Single Barrel, which I luv.
    Life is good.
    BOMBS, eltacoutah, Jiveydude and 3 others like this.
  5. Jan 30, 2021 at 11:09 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Hope you have a speedy recovery, that surgery BS is no fun.
    BOMBS and H3llRid3r like this.
  6. Jan 30, 2021 at 11:11 PM
    ChuckTruck
    ChuckTruck Active Member
    Utah
    2017 Taco TRD
    Hey man, sorry to hear that its been giving you a hard time. anytime I've worked with patients who have anterior approach hip surgery (im assuming arthroplasty, or debridement) we always tell them to wear some pretty loose fitting sweats or gym shorts to prevent rubbing. when the wound dehisces (opens up) that becomes a pretty big issue especially in groin area as your skin folds over in that area which makes it much more prone to infection (nature of the beast with that area). I would for sure do everything that has been said but pay really close attention to it and try to keep it dry after irrigation, and change dressings very often. I would give it a day or two at most and if things dont improve go and get it looked at, with an arthroplasty you run the risk of sepsis which degrades the joint spacer and it becomes a pretty gnarly issue quickly (currently rehabbing a patient with that issue).
    hope this helps, bummer you're dealing with it.
  7. Jan 30, 2021 at 11:53 PM
    H3llRid3r
    SLcUT
    I had a torn labrum repaired and the head of my femur rounded out with some arthritis cleaned up. Hip replacement in my future.
    I think I’m good. Just have to make it to Tuesday for my four week post op. It’s feeling reasonably well since I smashed it with my homemade saline. Thanks to all the input. TW rules.
    BOMBS likes this.
  8. Jan 31, 2021 at 8:16 PM
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    Anyone in Provo/SLC? I'm going there for business end of Feb for 2 weeks. Any good spots to eat and chill? Sadly won't be there with my Taco but if there are cool peepz around for a slice and a brew I'm down.
    There will be a lot of downtime boredom... I'll have my laptop with me too for TSBs and OVTunes. (3rd Gens)
  9. Jan 31, 2021 at 9:37 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    Provo...the heart of utah county doesn't have too much int he way of brews and watering holes. Salt Lake valley is gonna be your go to for that. plenty of great bars for some good drinks.
    DJB1, BOMBS, H3llRid3r and 1 other person like this.
  10. Jan 31, 2021 at 10:18 PM
    trdquoc
    "Q"
    I know Provo is kinda lame, SLC is better for that stuff for sure... let's see what happens... I'll also be in Provo for work so I cant party tooo much...
    BOMBS and Gunshot-6A like this.
  11. Feb 1, 2021 at 6:32 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Ill be around. Provo may not have many brews, but a lot of good places to eat and occupy yourself being a college town.
    Edit: though the coof may put a damper on a lot of those.
    BOMBS, H3llRid3r and fredgoodsell like this.
  12. Feb 1, 2021 at 8:35 AM
    ginseng27
    '17 DCSB OR
    not enough.
    I'm sure I speak for both @Gunshot-6A and myself when we say we'd be happy to hit up a bar somewhere in slc.
  13. Feb 1, 2021 at 8:53 AM
    trdquoc
    "Q"
    Fck yeah... I’m in California... can’t even go to a bar. Would be nice to grab a brew talk trucks or whatever.
  14. Feb 1, 2021 at 9:57 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
  15. Feb 1, 2021 at 10:07 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Add me. I need to meet some locals lol
  16. Feb 1, 2021 at 10:08 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    BOMBS, H3llRid3r and Gunshot-6A like this.
  17. Feb 1, 2021 at 10:18 AM
    ginseng27
    '17 DCSB OR
    not enough.
    Deal.
    Kerleyfries[QUOTED] likes this.
  18. Feb 1, 2021 at 10:18 AM
    ginseng27
    '17 DCSB OR
    not enough.
  19. Feb 1, 2021 at 10:22 AM
    Overland&UpMoutains
    Parker
    Deleware
    Is there entry level biking? Just getting into man biking but would love the chance while I'm there?
    ginseng27 likes this.
  20. Feb 1, 2021 at 10:28 AM
    eltacoutah
    eltacoutah Well-Known Member
    Ben
    Utah
    2010 TRD Sport
    May not have good places to drink but lot's of good places to eat.
