UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Oct 6, 2022 at 6:50 PM
    RtacomaN
    RtacomaN Well-Known Member
    Taylor
    Colorado
    Set of 4 wheels
  2. Oct 6, 2022 at 9:55 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The FJ wheels?
    So much want
    H3llRid3r likes this.
  3. Oct 9, 2022 at 2:43 PM
    Bubba’sTaco
    Bubba’sTaco Virtually-Known Member
    Spencer
    Ogden Utah
    Toyota XJ
    I’m in ogden and yes, it’s necessary here. When it does actually snow, those plow trucks throw salt everywhere.
    I’ve done mine a couple times and have learned a few tips from trial and error. I’m more than happy to help get you started. I highly recommend doing it yourself instead of paying $700+ for someone else who won’t care as much as you. Go stock up on an angle grinder, wire wheel attachments, wire brushes, putty knife, rust reformer, POR15, fluid film, and some nice knee pads. You can either half ass it and redo it once a year or do it right and redo it once every 5-10 years.
    DrRansom[QUOTED] likes this.
  4. Oct 9, 2022 at 4:31 PM
    DrRansom
    DrRansom Well-Known Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    Thank you for the advice! This is exactly the kind of helpful, no BS answer I was looking for. I'm going to take it and get it done before we get too far along in fall and winter.
    Bubba’sTaco[QUOTED] likes this.
  5. Oct 10, 2022 at 3:32 AM
    Bubba’sTaco
    Spencer
    Ogden Utah
    Toyota XJ
    Yeeaah buddy. Gotta do my part to keep yota’s out of the junkyard haha
  6. Oct 10, 2022 at 7:27 AM
    eltacoutah
    eltacoutah Well-Known Member
    Ben
    Utah
    2010 TRD Sport
    If anyone has or knows someone who has a set of used 285 R16 tires in decent shape they need to get rid of let me know. Looking for a set so I can finally ditch my 265's thanks!
    Gunshot-6A likes this.
  7. Oct 12, 2022 at 7:32 AM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    How long have you been long traveled? I have been long traveled for over 10 years now (mostly in so-cal, and the past 7 in utah). The utah winters aren't kind to the race parts. I am gunna take my front end apart in a couple weeks to re-powder coat my arms and get a front shock rebuild re-zinc.
  8. Oct 12, 2022 at 9:10 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Maybe 6 years? 2 of those were in Utah and just the front. Now I’m safe from salt in NorCal. But I did visit Utah a couple years ago during winter for about a week. That week absolutely destroyed everything. Rear leaves totally rusted. My front bypasses corrosion city. :rofl:
    I ended up finally fixing that by pulling them apart, cleaning with a wire wheel and hitting them with steel it. Looks much better.
    Here’s the before. Look at the condition of that bypass.
  9. Oct 12, 2022 at 11:25 AM
    concentric_killa
    Nice. I have to annually re-paint my rear leafs. My rear bypasses look horrible after just one year (i got them re-zinced in 2021).
    Also FYI, the camburg performance 4x4 spindles work with the chaos +3.5 kit. Im sure they will work with your kit since you are using stock spindles. I think I am one of the first customers to run the spindles on a non camburg long travel kit.
    I purchased them last year with a 14 wk lead time. I had a bent spindle after hitting a hidden rock out near Dumont dunes in 2014. My alignment always felt 'off'.
    H3llRid3r and erok81[QUOTED] like this.
  10. Oct 12, 2022 at 12:19 PM
    erok81
    Imposter
    It’s crazy how quickly that salt ruins stuff. I used to fluid film everything before winter. That stuff is so gross. Glad I don’t have to do it anymore.
    Also damn you. I thought I was done with big purchases for a while. Those spindles look good.
  11. Oct 12, 2022 at 1:05 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Any one in the bountiful area know of a good spot trustworthy that can reboot a cv Axel?
  12. Oct 12, 2022 at 4:23 PM
    concentric_killa
    If you do get them, you might need shorter bolts depending upon your lower uniball adapter. I had to get shorter grade 8 ones since the chaos adapter is thinner than the stock one that my taco had.
    Also the thread is fine for the tapped part of the spindle vs course on the stock spindles. I think it's like 5/8- 18. Luckily Marshalls industrial supply is near by.. my first set of spindles were garbage from camburg. They had powder coat over spray on the axle/ hub machined interface. That tolerance is already too tight for the bearing hub to fit correctly.
    Also they should have packed these in a crate vs a cardboard box and news paper. I sent them back. Luckily they had another set in stock and overnighted them. I almost requested a refund and was gunna buy a new set of stock spindles and then reweld the gusset on them..
    erok81[QUOTED] and H3llRid3r like this.
  13. Oct 12, 2022 at 4:24 PM
    JKO1998
    Utah
    Does anyone know of someone in SLC that has Resi mounts on the shelf?
  14. Oct 12, 2022 at 4:52 PM
    vonellis
    Some and some more
    I have two I saved from the fire. They need to be cleaned up but they will work fine. You can have them if you want.
  15. Oct 12, 2022 at 5:55 PM
    JKO1998
    Utah
    Front or back?
  16. Oct 12, 2022 at 6:24 PM
    microwvbleturtle
    microwvbleturtle Active Member
    Sean
    Lehi
    '10 MGM DC and ‘16 QS T4R
    Anyone here trimmed up their fenders on a 2nd Gen?
    I’m hesitant to trim them without a plan for the liners.
  17. Oct 12, 2022 at 6:42 PM
    vonellis
    Some and some more
    They where on the front but probably could use them in back.41D2083F-AFAA-4EC0-BE38-8713D869F498.jpg
    @JKO1998
  18. Oct 12, 2022 at 6:43 PM
    JKO1998
    Utah
    2.5 or? Sorry for the question, just wanna make sure they'll work haha
  19. Oct 12, 2022 at 6:48 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Reminds me of the scene in Harold and Maude where the kid fires up the cutting torch and you just know he's going to be cutting on the XKE.
  20. Oct 12, 2022 at 6:51 PM
    vonellis
    Some and some more
    2.5 they held ads clicker resis
