UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Jan 11, 2023 at 2:44 PM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    The jeep sway bar is electronic and it has some sort of spline/ gear connect in the center of it. It can only be disconnected in 4hi or low and you have to be on flat ground. It has a speed limit on it at 18mph. At 19mph, a message on the dash is displayed. Connecting Swaybar... The bronco one is hydraulic and can be disconnected under load which is cool. If I buy a Tazer unit, I think I can change this speed, or even allow disconnection in 2Hi. I am not sure if I will void my warranty by connecting a Tazer to the OBD port. You can also do crazy stuff with the tazer. Things like speedo/ gear re-cal, turning off Auto stop/start, Headlight party show....
    For a Solid axle suspension, most travel is droop travel. I would imagine it would be quite noticeable without a front sway bar and swerving at speed. With IFS, the suspension is more forgiving. I haven't run one for years with my long travel kit, but the coilover spring rate is stiffer than stock so it makes up for it.
    If you don't have a rubicon, you could buy swaybar quick disconnect links. Before you hit the trail, just disconnect your links and you are good to go. These can be a pain to re-connect if you aren't on flat ground.
    Im guessing the 18mph is linked to some sort of lawyer guideline.
    H3llRid3r[QUOTED] and DJB1 like this.
  2. Jan 11, 2023 at 7:41 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Look into the Z Automotive Taser.
  3. Jan 11, 2023 at 8:51 PM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Good point. I forget the Heep is solid axle.
  4. Jan 12, 2023 at 4:58 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Looking for anyone that is interested in running the trifecta in Moab in the next few months. It is a combo of three hard rated trails, Poison Spider (6/10), Golden Spike (7/10), and Goldbar Rim (6/10). Good descriptions here https://www.rr4w.com/Trails-Home.cfm. Videos abound on YouTube.
    I’ve run Poison spider and Top of the World both 6/10 along with 6 or so other 5/10 rated trails and numerous easier trails in Moab.
    Anybody looking for a challenge wanna join me?
    (Me on Top of the World for fun)
  5. Jan 12, 2023 at 7:27 PM
    H3llRid3r
    SLcUT
    I have interest.
    I would need to study up on those trails. Familiar with the names, but not much else.
    BOMBS likes this.
  6. Jan 13, 2023 at 6:42 AM
    concentric_killa
    Might be interested depending on the month. I'll have to check my work schedule. I just attempted top of the world last weekend in our gladiator. The first major step was snow/ ice covered. The initial large ledge is taller than it was in 2019. Might have to wait a month or two for all the snow to melt.
    It was just the wife and I and the doggos. We called it since we were the only ones out and didn't want to damage our new adventure rig with only 500 mi on it. I would probably do those trails in my long travel taco with 33's and my trusty elocker.
    This is from last weekend.
    This is from 2019
  7. Jan 13, 2023 at 11:59 AM
    deekyn
    Dustin
    Yellowstone
    Don’t really want to do the trifecta in the snow. Any time in the next few months.
    It’s just really hard to find people to wheel with. So many people “wheel” on mild ass dirt roads a Subaru can easily do twice a year and congratulate themselves. I want to push my wheelin but need people to go with.
    Wife and I have done all the 5 and 6 rated trails we’ve done solo. She’s a good spotter but don’t want to push much harder without other rigs
    BOMBS likes this.
  8. Jan 13, 2023 at 5:36 PM
    concentric_killa
    I know the feeling. I have wanted to do lockhart basin or even make a trip and do Road to Hite/ Dollhouse/ Flint Trail one weekend. I have also wanted to do Hole in the Rock Trail (near halls crossing). I would definitely want to go with another vehicle on that one.
    Typically its just the wife and I and doggos. We hardly ever see anyone on the trails, but it would be nice to wheel with another vehicle for that reason. We recently upgraded our SPOT Gen1 to a SPOT x to where we can actually communicate full messages via Satellite.
    Maybe we can figure out something. PM me!
    Jensonbt likes this.
  9. Jan 13, 2023 at 8:25 PM
    H3llRid3r
    SLcUT
    I’m down for Hole-in-the-Rock.
    Jiveydude and BOMBS like this.
  10. Jan 14, 2023 at 11:29 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Its been several years since I heard anything about hole in the rock. we use to run it every year when I was a kid in my dad's 69 Land Cruiser and once in the 94 dodge Cummins. I've heard you can't make it to marble camp any more because of a crazy wash out but that was probably 10 years ago
  11. Jan 14, 2023 at 1:47 PM
    deekyn
    Dustin
    Yellowstone
    Trail Mater video of hole in the rock recently. Not sure how far down he went.
    and two people on trailsoffroad did it last year.
    https://youtu.be/b9t7S0ZrIL8
    Travlr likes this.
  12. Jan 14, 2023 at 9:26 PM
    H3llRid3r
    SLcUT
    Myself, @Jiveydude and @Rockymtntacoma did it back in January 2019. It was epic. It’s a fabulous trail run.
    Gunshot-6A likes this.
  13. Jan 15, 2023 at 6:15 AM
    concentric_killa
    One thing is gas on that trip. Does the airport still offer gas? Also I assume that ferry at halls crossing is closed so you gotta go down and get gas in Hite and then continue down?
  14. Jan 15, 2023 at 4:53 PM
    unstpible
    Derek
    Cedar City, Utah
    Gas is a definite issue for me right now. I've been getting 10mpg since the DT header install so I don't drive it much more than necessary.
  15. Jan 15, 2023 at 6:19 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    I'm good for May for TriFecta. But after the 15th.
    If you've run Hells Revenge and Top of the World you can do the TriFecta. Ya, theres a few spots that you gotta be able to get up some ledges or drop some ledges. But its a fun trail to run with a few challenges.
    Hites crossing for is indefinitely closed. Closest fuel is Hanksville.
    deekyn, BOMBS and H3llRid3r like this.
  16. Jan 15, 2023 at 7:01 PM
    H3llRid3r
    SLcUT
    Luckily we were able to fuel up at the airport, or it would’ve been problematic.
    Yeah, I think the ferry has been closed now for several years. You have to go all the way around. However, it’s pretty scenic.
    Hole in the Rick is one of my favorite trails I’ve done.
    BOMBS likes this.
  17. Jan 15, 2023 at 7:52 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Gas in Hite? Last time we went through there everything except the park service housing was shut down.
  18. Jan 16, 2023 at 9:40 PM
    deekyn
    Dustin
    Yellowstone
    I live in ABQ NM but last year we camped/wheeled in Utah maybe 12 times. Moab is just under 6 hours from home and I have every other Friday off this year so I plan to make a bunch of trips that way. I’m sure I’ll be up there a time or two before May and might have some NM dudes lined up for the trifecta. But I’ll post when I’m headed to Moab. Always looking for people to wheel with. Would love to do Lockhart and hole in the rock and similar.
    H3llRid3r likes this.
  19. Jan 16, 2023 at 9:56 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Best bet is to PM me. I get behind on TW a lot.
    For Lockhart, just an out n back through the tough mile or the whole thing? I did the whole thing back in 2021. From Needles north. https://www.tacomaworld.com/threads/the-longest-mile.738348/
  20. Jan 27, 2023 at 1:20 AM
    G0AT
    G0AT Tell me how you really feel
    2021 TRD Off-Road DCLB
    I live in UT now but my wheeling friends are all in Idaho with jeeps that are questionable on driving to Moab on their own power lol. And my UT friends are hippie climbers with Subarus. Anyways I have a Taco and need additional friends to do more sketchy stuff with.
    Glueman, ChestaT, H3llRid3r and 10 others like this.
