UTAH (and Surrounding Areas) BS Thread
Discussion in 'South West' started by Drunknsloth, Feb 27, 2011.
  1. Sep 21, 2023 at 3:36 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    oh interesting! that's a good idea! this will also take care of odo reporting, correct? obviously, i won't be rolling back because of...legalities. but want to mak sure the actual future odo readings are more accurate to teh vehicle's true mileage. (it's probably super high right now).
  2. Sep 21, 2023 at 7:16 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Toyota ODO And Speedo are controlled by wheel sensors only. No need to adjust for regear, only larger tires.
    if you have larger than stock tires your ODO/Speedo are actually reading lower speeds and miles, so ODO is showing lower mileage than actual.
    BOMBS and H3llRid3r like this.
  3. Sep 21, 2023 at 8:44 PM
    ginseng27
    '17 DCSB OR
    not enough.
    hmmmm. good to know. but the car is reading higher. a 100 mile gps trip showed up as 110 miles. :/
  4. Sep 21, 2023 at 9:31 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    That's true. Didn't think of his issue being higher than it should. Mine was slower and under reporting mileage before I installed the calibrator.
  5. Sep 22, 2023 at 8:40 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    My 23 4Runner's speedo is 3% over. I'll be doing 75 mph per GPS and the speedometer will read 77 mph. I plan on going to 285s. Two birds, one stone.
  6. Sep 22, 2023 at 12:50 PM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Strange, what size tires?
  7. Sep 22, 2023 at 1:03 PM
    ginseng27
    '17 DCSB OR
    not enough.
    pretty sure it's stock but i'll have to check.
  8. Sep 22, 2023 at 6:16 PM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Yeah, if you are on stock tires, 265/70/R16 it does under report mileage/speed, and inflate mpg. If you go to 265/75/R16 tires it reads correctly.
    Why would Toyota want to inflate mileage/ODO and MPG? Oh wait…
    08TRDOFFROAD likes this.
  9. Sep 23, 2023 at 9:58 PM
    ginseng27
    '17 DCSB OR
    not enough.
    265/70/r17.
    Pretty sure it's stock.
    Lol. Yeah.....right? Hahahaha.
    BortisYeltzen[QUOTED] likes this.
  10. Sep 23, 2023 at 11:36 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Fall sure has begun
    Can you spot the deer? (just say no because you can't)
    BOMBS, Gunshot-6A, DJB1 and 5 others like this.
  11. Sep 24, 2023 at 1:11 PM
    08TRDOFFROAD
    Dan
    Where abouts is this at?
    unstpible[QUOTED] likes this.
  12. Sep 24, 2023 at 1:37 PM
    unstpible
    Derek
    Cedar City, Utah
    This is Hancock peak, Directly east of Cedar Breaks National Monument. The spot I took the photo from is easily accessible via Hwy 143 but we took a road less traveld
  13. Oct 2, 2023 at 4:47 PM
    Stxxx
    Stxxx Well-Known Member
    2009 Tacoma TRD
    Any recommendations for local installation of remote start for an ‘09?
  14. Oct 2, 2023 at 4:47 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Best Buy did mine, usually have a black Friday sale
    buy an upgraded remote, only problem I have with mine.
    Stxxx[QUOTED] likes this.
  15. Oct 2, 2023 at 4:48 PM
    Stxxx
    2009 Tacoma TRD
    Thank you! Do you know what model you have and what you like/don’t like about it?
  16. Oct 2, 2023 at 4:51 PM
    JKO1998
    Utah
    Some sort of viper, seems like it works fine. I think I have a small fuel leak somewhere though, takes a couple
    Times to start in the summer.
    Takes a minute when it turn the key too
  17. Oct 2, 2023 at 8:31 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    I had mine done a few years back (also audio upgrades and front camera) at Laketown in Draper. Still works great.
    BOMBS, H3llRid3r and Gunshot-6A like this.
  18. Oct 3, 2023 at 9:52 AM
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    This is exactly where I did mine. They were great.
    BOMBS, Gunshot-6A and RyanL[QUOTED] like this.
  19. Oct 5, 2023 at 12:39 PM
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    The weather is looking fabulous through the weekend. Hopefully, someone is getting offroad.
  20. Oct 5, 2023 at 1:23 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I'm going to be home, playing in my shop, trying to get my '78 Chevy chassis ready to be shortened from 131.5 inches to 112... so I can put my M37 body on it. Getting very close. Can't wait to start mounting the body on the truck.
    08TRDOFFROAD and Gunshot-6A like this.
