Utility Trailer Bearing Maintenance
Discussion in 'Towing' started by Sinister184, Feb 6, 2023.
  1. Feb 6, 2023 at 11:03 AM
    Sinister184
    Sinister184 [OP] Well-Known Member
    23 Tacoma TRD OR 4x4
    I have a 5x8 utility trailer I bought new a few years ago now. I use it fairly infrequently for odd jobs. It's probably got less than a 1k miles on it. Most of the advice online says it's best to repack the bearings every year. Given the low use and that it's stored out of the elements, I'm thinking that could be excessive. Any additional advice on how often to repack the bearings and such? Thanks.
  2. Feb 7, 2023 at 12:31 PM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    I push my luck. I have a 2000 jetski trailer with Bearing Buddies (it lets you pump in grease anytime). It started leaking on one wheel in Texas on a round trip from Los Angeles to North Carolina in 2004. I just added more grease every stop and replaced the bearings in North Carolina. No trouble since then including my move in 2006 to Indiana. I bought a 4x8 utility trailer without Bearing Buddies for the move in 2006. No trouble with it but I think about regreasing it. I have 6 or 7 thousand miles on the utility trailer and at least 8000 on the jetski trailer. It might be a good idea to slap the wheel lightly to see if they are getting hot after stopping occasionally. I bought a temperature gun from Harbor Freight a couple of years ago to get an easy accurate wheel temperature.
  3. Feb 7, 2023 at 12:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    In the mid 70s I built a utility trailer out of an old boat trailer as I wanted the tilt feature. I had no clue how old the trailer was or how it had been treated bearing wise.
    I pulled the bearings and they were good, but the hub seals were weak, so those I replaced. And hand packed the bearings.
    About 10 yrs later I repeated the process and added Buddy Bearings and ran it another 20 years
    Then 20 yrs ago I gave the trailer away and he's still rolling it. So original bearings well over 50 yo, Buddy Bearings over 40
    Buddy bearings work. And you can visually know when you need to add grease
    Sinister184[OP] likes this.
  4. Feb 7, 2023 at 12:44 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My camper sees about 5-7k miles a year, but it has those wonderful ez-lube axles. I flush grease annually (and even a good grease tends to come out a little "watery" I've noticed). Every other year I pull hubs and inspect bearings and brakes. Every 5 years I replace bearings and races, whether they need it or not.
    Not looking forward to this March, bearings and roof sealant are all due for replacement, on top of the normal camper maintenance stuff. And my truck will be rolling 60k miles at around the same time. I see much garage time in my immediate future. :annoyed::annoyed::annoyed:
    Even that is excessive, but with the great and remote areas of this country I pull mine across, I really don't want a case of roadside hot-wheel.
  5. Feb 7, 2023 at 12:45 PM
    Sinister184
    Thank for sharing. Mine has bearing buddies as well. I read mixed feedback on how effective those are are getting grease to the bearings. Most people say they're really only helpful at keeping water out by filling the cavity with grease. I'm thinking I'll pop one off and see how everything looks.
  6. Feb 7, 2023 at 12:46 PM
    DuffyBank
    DuffyBank Well-Known Member
    it is so easy to do with ez lube hubs, why not haul out the grease gun for a couple of minutes a year.
  7. Feb 7, 2023 at 12:48 PM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    Jack it up and feel if there is any motion in the 12-6 or 3-9 position if there is then you need to tighten the castle nuts to remove the play in the bearing to bearing cups.
  8. Feb 7, 2023 at 12:49 PM
    Sinister184
    I can't speak from experience, but I've read that approach isn't as effective as disassembly and repacking the bearings. I imagine it's good for occasionally maintenance.
  9. Feb 7, 2023 at 12:59 PM
    DuffyBank
    https://www.youtube.com/watch?v=XT0RKDGgDm8
  10. Feb 7, 2023 at 3:13 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    There's a technique to it, if your trailer has them. My trailer sits on stands, and I give the wheel a moderate spin with one hand while injecting grease with the other. It ensures equal distribution through the bearings while also not putting too much pressure on the rear seal. Keep pumping until you no longer see old grease falling out.
    My first year of using the EZ zerc I was so convinced that I did it wrong I unpacked the bearings and replaced the seals. Turns out, I did it right, and the replacement of new grease over old is pretty uniform throughout.
  11. Feb 7, 2023 at 6:05 PM
    Sinister184
    Thanks I’ll look into the zerks a little more.
  12. Feb 8, 2023 at 3:38 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Since you’ve had the trailer for a few years and you don’t know if the prior owner did anything with the hubs and bearings I’d pull the bearing and inspect them. Clean the bearings and hubs and install new seals, replace bearings if necessary , repack the bearings and put it all back together. Now you know all is good and you are good to go for 3 to 5 years. Before every trip inspect the inside and outside of the wheels for any grease. If it’s throwing grease then you need to pull and inspect them. If you use good seals and do the job right I don’t expect you’ll find any grease on the wheels.
    After your first trip , jack each side of the trailer up and check how much play if any in the wheels. If all good, you should have no problems for years.
    Since the trailer gets so little use and it’s light use I personally don’t think it’s worth it to buy and install ez lube hubs. But that’s your decision. EZ lube, EZ zirc, Bearing Buddies etc. are all great products but in your particular case I just don’t see the need.
  13. Feb 23, 2023 at 1:29 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Since all my trailers Have brakes and they never work every spring they get done every year.
    Our work equipment trailers the bearings get greased when the new ones are installed after the old ones failed.
