uTorrent Anyone?
Discussion in 'Technology' started by Ghost96Romeo, Jan 5, 2009.
  1. Jan 5, 2009 at 4:32 PM
    Ghost96Romeo
    Ghost96Romeo [OP] What is the Search Tab for????
    Texas
    06 TRD Off-Road D-Cab
    3" Pro-Comp Suspension Lift AAL Rear w/TSB, All-Pro Plate Bumper, Lightforce 240 Blitz lights, Lund Genesis Roll-top Bed cover, K&N Filters, Spidertrax Wheel spacers, Built-by-Me Rock Sliders, Jeep Tow-Hook, Black Leather seats, 48"Hi-Lift Jack mounted in the bed, Blacked out TRD Rims, BHLM, FLM..... and Awesomeness
    I'm not really sure how everything works for this. I understand how Limewire works and I can get stuff for that, but uTorrent seems a little different for downloading programs. Can anyone help me understand this?
  2. Jan 5, 2009 at 4:35 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I use Vuze. But its quite simple
    1. go to your favorite torrent site... I use mininova.org
    2. Find whatever pleases you
    3. The downloaded will be downloaded through whatever program you're using (uTorrent or Vuze)
    4. Find the file whatever you downloaded was saved to.
    5. Its that simple!
  3. Jan 5, 2009 at 4:50 PM
    roggs01
    roggs01 Roggs01
    Surprise, AZ
    16 TRD Sport
    Predator steps,Method NVs, 285-70-17 KO2s
    Let me give it a shot
  4. Jan 5, 2009 at 4:55 PM
    slimsdepot
    slimsdepot slimsdepot.com
    SoCal
    08 PreRunner
    I use Vuze as well... formally known as Azureus or something. I got my windows office from there! Get the blue version if you need it its full version no serial key needed. :)
  5. Jan 5, 2009 at 4:58 PM
    Ghost96Romeo
    Texas
    Well the program I'm trying to get is the RosettaStone. I have the language Cd's already, but I need the programs exe. file to run the program.
  6. Jan 5, 2009 at 5:04 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    I use uTorrent. Used to use Azureus, but it is too bloated now. uTorrent is much much leaner and less resource hungry.
  7. Jan 5, 2009 at 5:24 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
  8. Jan 5, 2009 at 5:26 PM
    Ghost96Romeo
    Texas
    I'll have to check that out too. I've been trying to figure out www.btjunkie.org
    It seems like everything I download needs to be burned to a disc first before I can do anything with it. Does this seem right?
  9. Jan 5, 2009 at 5:31 PM
    sooner07
    A A Ron
    DFW, Texas
    Get an emulation tool like dameon tools. You can then run the image (which is what you are downloading if you need to burn it first to use it) and install or what ever from there.
  10. Jan 5, 2009 at 5:59 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
  11. Jan 7, 2009 at 11:38 AM
    Ghost96Romeo
    Texas
    utorrent won't let me download anything with my wireless router and claims I need to setup a static IP for outgoing transmissions, but I can't repair this porblem. Linksys is no help for setting this up and I've never had the issues with limewire. Any ideas?
  12. Jan 7, 2009 at 11:43 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Are you sure the correct ports are open on your router firewall? I have started just completely shutting down the router firewall when I want to download and I only use the windows firewall.
  13. Jan 7, 2009 at 11:48 AM
    Ghost96Romeo
    Texas
    thats the other problem, for some reason I can't access my Linksys web based router setup. When I set it up, I password protected it and to get to it, i need the username and password, but to no avail its not working to let me login. :(
  14. Jan 7, 2009 at 11:49 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    some routers can be setup to only allow wired administration.
  15. Jan 7, 2009 at 12:00 PM
    slo2sixty
    slo2sixty Well-Known Member
    Syracuse, NY
    19 cement DCSB TRD offroad
    i also use utorrent thats how i got my 4000 songs!! and thers a site i know to get serial keys... serials.ws but there advertisments are porn so use with caution :D hahahah
  16. Jan 7, 2009 at 12:04 PM
    wing103
    Boston
    Hi, Hhost96Romeo
    They are right, may be when you do the set up on your linksys router, you select only wired device can login to your router.
    use the cat5 cable to login to your router and open up the port, also make sure on the windows base firewall, open up the port too.
    Worse case, if u forget your password, you have to reset your linksys wireless router.
  17. Jan 7, 2009 at 12:06 PM
    wing103
    Boston
    Also how about we post the site here to share the BT site? Also I have some site you do not have to use BT, if you have a rapidshare account, you can get a ton of stuff.
    let me know if you want it. I can post the link here.
  18. Jan 7, 2009 at 12:13 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I've got a Linksys Router, and you don't have to be wired to set it up. Hold the reset button in on the back for 15 seconds and reset the thing. It will set it back to factory defaults, so you'll have to set everything back up, and then do port forwarding to your computer. Once you reset it, the user name is blank and password is 'admin' to login.
  19. Jan 7, 2009 at 1:19 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Let's hear about it!
  20. Jan 7, 2009 at 1:25 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I think default username and password for Linksys routers is admin. Try typing in 192.186.1.1 to get to the login and then putting admin for both username and password.
