utroda's Tacoma (LT, Lckd, 35s) & FJ40 Build (In Progress)
Discussion in '2nd Gen. Builds (2005-2015)' started by utroda, Jan 25, 2016.
  1. Feb 15, 2018 at 5:48 PM
    #521
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    He said it was on CL for less than 4 hours...
  2. Feb 15, 2018 at 6:29 PM
    #522
    utroda
    utroda [OP] Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    Sounds good thanks
  3. Feb 15, 2018 at 6:30 PM
    #523
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    I bet
  4. Feb 19, 2018 at 1:39 PM
    #524
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Well, ordered some new FK uni-balls from @Wheeler's Off-Road Inc hope to have them by the weekend and get the lowers replaced while the wife is in Arizona watching some spring training games.
    Also did the oil change on the tacoma and tundra, has anyone seen any good deals on mobil 1 full-synthetic, need to restock.
  5. Feb 19, 2018 at 1:40 PM
    #525
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    @velillen are you going to be linking your 40 or running leafs?
  6. Feb 19, 2018 at 9:37 PM
    #526
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    here is another 80 with low miles - > CL
    utroda[OP] likes this.
  7. Feb 23, 2018 at 7:29 AM
    #527
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Okay, so here an update on the 40.
    When we started we couldn't decide if we wanted to restore it or build it into a crawler. I think we are leaning towards a crawler. Our first thought was to get a donor FJ80 with the full float rear and swap everything over and keep it toyota, but after getting some measurements off of one it just doesn't seem to work without possibly stretching the frame.
    With the FJ80 motor to end of transfer case is around 80-83". which would basically end around 6" from the rear axle in its stock location.
    So now this is the new idea
    Option 1
    Chevy 350
    TH400 (auto) - with the smallest tailshaft
    Atlas 4 Speed
    Option 2
    5.3L Vortec
    4L60-E (auto)
    Atlas 4 Speed
    Stretch Wheelbase 105-110"
    Full Width Dana 60s with ARB's
    37-40" Tires
    3-Link Front
    4-Link Rear
    King Dual Rate Coils
    Internal Cage so the hard tops still fits
    Anyone have thoughts on option 1 over option 2?
    Acerwin likes this.
  8. Feb 23, 2018 at 7:47 AM
    #528
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    5.3 are every where and cheap. That’s what I’d go with. Easy to build horse power also.
  9. Feb 23, 2018 at 7:52 AM
    #529
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    I just found one in Idaho for $1500 that with the ECU and harness, but might have a line on 350 with the TH400 transmission for $900.
  10. Feb 23, 2018 at 7:54 AM
    #530
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    My buddy got the 5.3 with transmission and transfer case for 1400. Guess it really depends on which you cannot me across first
  11. Feb 23, 2018 at 5:03 PM
    #531
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Either will work fine. Im more of a fan of the 350 just cause its an "easier" swap in the sense of no computers and less wiring needed. And if you stay carb'd you wouldnt need to change out fuel setups all that much. I vote for just going with whichever you find first for the price you are willing to pay
    The 2uz could be an option for keeping it Toyota....though itll cost a lot more.
    I have a TH350 if you are open to using that instead of a Th400. It MIGHT need a rebuild but really I have no clue. It was in my FJ40 but I swapped over to a H42
  12. Feb 23, 2018 at 7:50 PM
    #532
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Thanks on the trans I'll keep that in mind, I should get some more info on the 350 tomorrow its currently in a guys FJ, he wants to swap to the LS he has in one of his corvettes.
  13. Feb 23, 2018 at 7:58 PM
    #533
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    350 on propane
  14. Feb 23, 2018 at 8:00 PM
    #534
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Didn't think of that, but that would be cool. One of my old friends had his 22r converted for propane.
  15. Feb 23, 2018 at 8:16 PM
    #535
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    A friend of mine runs it in his 22r powered truggy.
  16. Feb 23, 2018 at 8:23 PM
    #536
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Hows it work for him, any downsides?
  17. Feb 23, 2018 at 8:30 PM
    #537
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    He's got an older Holley setup that works about perfectly. It's been going strong for 10+ years. He had some issues when it was first done but I think it was mostly learning the system and breaking in a whole new build.
  18. Feb 24, 2018 at 7:24 PM
    #538
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Day one on the 40 tear down,
    Finished getting the fenders off and disconnecting everything from the fire wall
    Pulled the gear shift off and the gears look brand new,
    Then pulled the tub off, engine hoist and ratchet strap made easy work
    Just had to finish off by getting the motor mounts and trans mounts off
    Picked that heavy bitch up and set it to the side
    Finished the day pulling the axles and getting the rest of the bolt on shit off. Going to start tomorrow by building a box to get the frame up off the floor so we can work on it at a decent height and then finishing getting the break lines and everything that's riveted on off. Pretty good progress on the first day. Frame is in super nice shape just hella dirty.
  19. Feb 24, 2018 at 7:27 PM
    #539
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Bad ass! Damn good progress for one day
  20. Feb 24, 2018 at 7:28 PM
    #540
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    I thought so, its nice to have the tub off and able to start taking some measurements.
