Uuugh, it never ends.
Discussion in 'Suspension' started by Bearskill, Jan 22, 2010.
  1. Jan 22, 2010 at 1:56 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Just recently installed some OME 2.75" Dakar leaf springs on my 06 access cab prerunner. This was supposed to be the last big mod. Well there have been 4 or 5 times now that when I hit a large bump on one side only, drivers side/pass side I hear and feel a "scrunch". It sounds like I am rubbing on the fender. But that does not make sence. I didn't rub when I had stock springs and a 2" Toytec AAL, Now Im at 2.75".......? There does not seem to be rub damage or any mark as all, and I went back and checked the tourque on everything. I am running Toyo Open Country A/T P265/70R17. Anyone have an idea?
  2. Jan 22, 2010 at 1:57 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Wheels turned or straight?
  3. Jan 22, 2010 at 2:04 PM
    Bearskill
    Sac
    No. REAR tires. I know it sounds crazy. The wheels look pretty centered in the well. I can't tell if they are rubbing weather it would be the front or back of the tire.
  4. Jan 22, 2010 at 2:08 PM
    mjp2
    NJ
    Oh geez. Only happens when you hit a bump on 1 side of the truck?
    Look for rub marks behind the tires, possibly on the shocks. Sounds like something that only rubs when the rear axle is articulated.
  5. Jan 22, 2010 at 2:17 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You need a RTI type ramp or a spot where you can articulate your rear end and let it sit so you can inspect it.
  6. Jan 22, 2010 at 2:20 PM
    Bearskill
    Sac
    Ya, I Don't get it. I bought Wheelersoffroad.com's full OME rear set up package. Along with the Dakars I bought everything "Recomended" with the spring to avoid something exactly like this. Think calling Wheelersoffroad.com could help?
  7. Jan 22, 2010 at 2:22 PM
    Bearskill
    Sac
    I thought of that. Been looking for a good spot the last couple days.
  8. Jan 22, 2010 at 2:25 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    They may have some ideas for you man...but looking at your rig somewhere you can see the parts move will probably help more.
  9. Jan 22, 2010 at 2:26 PM
    Bearskill
    Sac
    If I am rubbing, how do I fix it? And cheaply? I know Silverback07 made some axle relocation plates because of a sim prob, but I didn't have access to much in the way of tools.
  10. Jan 22, 2010 at 2:27 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Gotta find out what rubs and then figure out what you need to space out or move. I'm sure someone here can help you out once you know what the problem is.
  11. Jan 22, 2010 at 2:31 PM
    Bearskill
    Sac
    Your right. Im on 12s for the next three days. Will look for a good spot Tues unless i can find a place on base. Thank you.
  12. Jan 22, 2010 at 2:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Got a hobby shop on base?? Or a small oil changing ramp?? Doesn't sound like you need much to make the noise.
  13. Jan 22, 2010 at 2:36 PM
    Bearskill
    Sac
    Ya, got the hobby shop. If I can't find a ramp, think I could just jack up one side of the axle?
  14. Jan 22, 2010 at 2:42 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Worth a shot....If you get the sound over bumps it should need to be a full articulation.
