V-6 (4-liter) oil filter question
Discussion in 'Technical Chat' started by RV7Garage, Dec 4, 2011.
  1. Dec 4, 2011 at 5:19 PM
    RV7Garage
    RV7Garage [OP] R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    While from an ease-of-maintenance standpoint I really like the placement of the oil filter on my '12 V6, I wonder where all the crap goes when the engine is shut off.
    Won't all the crap in the filter just drain out and down, due to the inverted orientation of it? Is there a valve that prevents this, or will the filter itself keep the gunk trapped? :confused:
  2. Dec 4, 2011 at 5:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Most filters have anti drain back valves. Also, The oil flows from the pan, up to the filter, then around the engine. Any oil that were to drain back, would simply go back into the pan with the rest of the dirty oil.
  3. Dec 4, 2011 at 5:25 PM
    RV7Garage
    Paul
    Ill Annoy
    Ok, so I think you just enlightened my understanding of how an oil filter works. It doesn't really trap particulates and gunk, but by being upstream of the engine just keeps the inflow clean? Is this right?
    Edit: total noob question, I realize. But I always looked at oil filters like they were air filters, trapping particulates. Sounds like I was mistaken!
  4. Dec 4, 2011 at 5:31 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    No. Oil filters definitely trap particulates. Take a look at this thread for pics and videos of how they're constructed - should help your understanding of how they work, not to mention which ones to buy... :wink:
  5. Dec 4, 2011 at 5:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The oil filters DO trap most all contaminants. However, as the oil goes thru the filter, and is "cleaned" of these particles, it then flows thru the engine, lubing, and picking up more, then goes down to the pan, to the pump, and back thru the filter.
  6. Dec 11, 2011 at 4:18 PM
    BREAK
    BREAK Well-Known Member
    Washington
    2016 TRDOR LB
    BFG KO2 265/75R16 Icon Dynamics 2.0 Front Coilovers and rear shocks. Rear AAL Borla Catback exhaust Afe momentum CAI
    I found a small rubber cap when I took my oil filter off. Maybe a half inch in diameter. Is this supposed to go in one of the holes?
  7. Dec 11, 2011 at 4:25 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Sounds like the the drain stopper at the bottom for the oil-cooler?
