V-6 Rod knock?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MyTaco, Nov 14, 2010.
  1. Nov 14, 2010 at 5:33 PM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Hey all, I have an 08 with 6k miles on it. I started it last night and a god awful knocking erupted, like a rod was going to launch out. Oil pressure light wasnt on and it ran for about 10-15 seconds and i shut it down. I fired it up again and the knock was less than the 1st time and lessening as a few more seconds went by but i shut it down again. This morning i started it and it was hardly noticeable, warmed it up and it was back to normal.
    Anyone have this strange issue before?....
  2. Nov 14, 2010 at 6:28 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    I haven't ever heard of that before. I would take it to the dealer, you may not be able to replicate it while there, but they will at least have it on record so if your engine blows up it will be easier for you to make them replace it.
  3. Nov 14, 2010 at 6:29 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    when was the last time it was actually driven or started before the first time in this sequence? 6k miles isnt anything on an 08.
  4. Nov 14, 2010 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    if a rod knocks....It doesnt go away. Its gotta be something else.....
  5. Nov 14, 2010 at 6:32 PM
    MyTaco
    Az
    08 Prerunner
    Drove it 2 days before this happened...ran perfect. Not like it was sitting for any long period of time.
  6. Nov 14, 2010 at 6:35 PM
    MyTaco
    Az
    08 Prerunner
    I was just trying to describe the sound using the rod thing. I thought maybe it lost oil pressure for some reason like a bypass valve stuck open...just kinda scratchin my head on this one. I will fire it up again in the morning and see wat happens.
  7. Nov 14, 2010 at 6:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What part of AZ are you in? Also, You may want to try and record it and post it up, so we can get a better idea if it makes the sound.
  8. Nov 14, 2010 at 6:42 PM
    MyTaco
    Az
    08 Prerunner
    Tucson. Unfortunately I dont have anything to record it with. Seriously it sounded like it had no oil pressure, like it hadnt been started in awhile and the was no lubrication anywhere in the motor.
  9. Nov 14, 2010 at 7:20 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Any chance something got put in your gas??
  10. Nov 14, 2010 at 7:22 PM
    MyTaco
    Az
    08 Prerunner
    No sir. Always In the garage. Ran great 2 days before this....
  11. Nov 14, 2010 at 7:31 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    You wont get a huge knock with no oil pressure, unless the engine has already spun a rod bearing...
    Oil pump failed on my 2.5L sentra. I started it and had it on for a few seconds with the oil light ON :eek: Of course after I noticed the oil light NOT going away, I shut the car off immediately and replaced the oil pump... It sounded fine even with no oil pressure....
  12. Nov 14, 2010 at 7:49 PM
    MyTaco
    Az
    08 Prerunner
    I used "rod knock" as to describe the sound, thats how loud it was. I dont think it was as it started knocking as soon as it fired but ran perfect 2 days before hand...go figure...
  13. Nov 14, 2010 at 7:54 PM
    05RedTaco
    Tony
    Scottsdale
    You won't get good answer without a sound clip even then to actually get an answer over a message board which tells you exactly what is wrong is slim.
    For me to try to diagnose this, I would have to hear this sound and drive the truck, as well as any mechanic would while trying to pinpoint the problem.
  14. Nov 14, 2010 at 8:01 PM
    MyTaco
    Az
    08 Prerunner
    I realize that. I'm just looking to see if anyone has had a sinilar issue with this engine. I was a mechanic at a dealer ship about 20 years ago so i'm familiar with engine diagnosis, but now a days with all the new fangled wiz bang gizmos on cars I thought i'd see if anyone here had any suggestions. thanks for your help.
  15. Nov 14, 2010 at 8:12 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Could it just be piston slap?
  16. Nov 14, 2010 at 8:14 PM
    MyTaco
    Az
    08 Prerunner
    Better not be w/only 6k miles!
    No, it was loud as hell like something wanted out..lol
  17. Nov 14, 2010 at 8:16 PM
    dan0688
    dan0688 Active Member
    06 sr5 6spd
    was it much colder outside then usual when this happened? an aluminum block will make what you may think of as a rod knock when it is cold, common complaint we hear at the dealership i work at in NY durring the winter
  18. Nov 14, 2010 at 8:18 PM
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    i say take it to the dealer and let them deal with it while its under warrenty. Belive me if it was rod knock it would be loud and the sounds wont go away.
  19. Nov 14, 2010 at 8:20 PM
    MyTaco
    Az
    08 Prerunner
    Nope...about 75 degrees out. It ran fine just 2 days before... not a valve train noise,loud enough to scare the s**t out of me!
  20. Nov 14, 2010 at 8:22 PM
    MyTaco
    Az
    08 Prerunner
    It was loud enough that i thought any second something was going to come out the side of the block. I'm fire it up tomorrow and see how it sounds.
