V4 to v6 engine swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by AJK47, Aug 9, 2020.
  1. Aug 9, 2020 at 2:33 PM
    AJK47
    AJK47 [OP] Member
    AJ
    2000 Tacoma 4×4
    New stereo and speakers 2 added subwoofers
    I have a 4 cylinder 2000 tacoma 4x4. My local junkyard has a 1997 V6 4×4 tacoma for $500. It has about the same amount of miles as mine and the engine bay is all there and works. I want to see if I can swap the V6 into my V4 and what all I need to pull from the truck and use.
  2. Aug 9, 2020 at 2:35 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Why? Is the 4 blowd up?
  3. Aug 9, 2020 at 2:37 PM
    electricmarauder
    electricmarauder Well-Known Member
    2014 | Tacoma | RC | White | 4×4 | 5-speed
    Tacomas don't have a "V4" they have an I4 (Inline 4).
    Coma 13 likes this.
  4. Aug 9, 2020 at 2:47 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Engine frame mounts are in the wrong location for a v6. You'd have to cut the mounts off the v6 frame and weld to yours.
  5. Aug 9, 2020 at 11:23 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Pull the entire harness and make it easy. It's been done before, I'd buy the entire truck and have everything available. Is this for the same street racing truck?
  6. Aug 10, 2020 at 7:27 PM
    AJK47
    AJK47 [OP] Member
    AJ
    2000 Tacoma 4×4
    Or what other 6 cylinder engines would work with my truck.
  7. Aug 10, 2020 at 7:41 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    If you are gonna go through the hassle, skip the 6 cylinder and get an LS motor and T56 to drop in
    TireFire likes this.
  8. Aug 10, 2020 at 8:00 PM
    AJK47
    AJK47 [OP] Member
    AJ
    2000 Tacoma 4×4
    Is there A thread or video about doing the LS and t56 swap? Thnx
  9. Aug 10, 2020 at 8:01 PM
    suaveflooder
    Not sure to be honest, but you will be swapping a good amount of things around. That would make more sense to me if you are already gonna be putting in the work
    Ls engines are cheap and readily available
  10. Aug 10, 2020 at 8:05 PM
    suaveflooder
