V4 to v6 swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUISFER, Aug 18, 2010.
  1. Aug 18, 2010 at 12:28 PM
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    I bought a 2010 tacoma with a v4 which i thought would be fine since it would save me gas and my friend has an older v4 which seems to do fine off-road. Gotta say i am not liking the v4 and i am missing my gas guzzling f250 v10. I want to know if anyone know how difficult it would be to swap my engine for a v6 in a couple of years when i run out of warranty. I have a 5 speed transmission. Just wondering because i actually have an auto parts store so i want to lift the truck and put a lot of accessories on it. Any info will help.
  2. Aug 18, 2010 at 12:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not to pee in your wheaties, but if you really don't like the I4 and can't live without the V6, it's probably be cheaper to trade it in and get the engine you want. That way you can start the mods now with the set-up you want to run.
  3. Aug 18, 2010 at 12:31 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2021 Honda Ridgeline Sport AWD
    You do not have a V4 in you Tacoma,,,and your friend doesn't have a V4 either
  4. Aug 18, 2010 at 12:39 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    V-4s are pretty rare... I think Saab had one (made by Ford) years ago. The Flat or Horizontal 4 is famous as the VW air cooled motor of generations and the Subaru water cooler motor...everything else is an INLINE 4.
    DirtySouthSurfer likes this.
  5. Aug 18, 2010 at 12:40 PM
    LUISFER
    LUISFER [OP] Member
    TX
    2010 TACOMA 4X4
    It's my first toyota. Im not that familiar with it. And i dont want to trade it in because i would probably loose a good deal of money plus i dont have the money to do so.i plan to swap engines when im done paying the truck. i got it 2 months ago. so 2 more years. I shouldnt have any problems with swapping it since i have a mechanic shop. We just never really work on imports but im sure it wont be a problem. I just want to know what parts i would need and how difficult. also if anyone has done it on their truck or on an older model.
  6. Aug 18, 2010 at 12:44 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Hold on... you're a mechanic?
  7. Aug 18, 2010 at 12:52 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    and he thought he had a v4?
  8. Aug 18, 2010 at 1:00 PM
    Pugga
    Massachusetts
    :facepalm:
    This engine swap outta end well! OP even if you do manage to get the V6 in there, it won't be like your F250 with the V10. It'll be closer but it's still 4 cylinders short.
  9. Aug 18, 2010 at 1:01 PM
    David K
    Don't hassle the guy... he came here for help! Because he has a mechanic shop doesn't make him a mechanic... he's the boss!
    Dragon007 likes this.
  10. Aug 18, 2010 at 1:05 PM
    Jester243
    Dan
    Spokane, WA
    I'm not hasseling him, I am askign questions. If he is in fact the boss and not a mechanic then perhaps it is better to hand this off to his mechanic.
  11. Aug 18, 2010 at 1:06 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    x2
  12. Aug 18, 2010 at 1:07 PM
    Przemekmsu
    Przemekmsu Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    If your going to swap anything put a V8 in it. Or even better find a nice diesel engine.
  13. Aug 18, 2010 at 1:07 PM
    PLC721
    Patrick
    Chandler, Az
    hilux!
  14. Aug 18, 2010 at 1:08 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    stick with the V4, they're rare
  15. Aug 18, 2010 at 1:13 PM
    Pugga
    Massachusetts
    Not trying to hassle, meant to be all in good fun.
  16. Aug 18, 2010 at 1:22 PM
    josem3
    josem3 Member
    Florida
    2013 Gray TRD Sport PreRunner V6 2WD
    You not only need a V6 engine, you will need the ECU and the transmission for the V6 engine. So, it will be very expensive to swap engines. Better option, trade the truck. Less hassle here.
  17. Aug 18, 2010 at 1:23 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I don't know if anyone's actually done it, but it'll likely entail more than you'd expect at face value. For example, engine mounts may be different, new trans, drivetrain and suspension may not be able to handle the added weight and/or torque (e.g. drive shafts, axles, shocks, differential gears, etc), new computer or reflash, etc. These are all things you'd have to research and possibly upgrade to handle the V6. Even after all this, there could be sneak issues like the computer expecting some sort of sensor input which doesn't exist on the 4-cyl and it might start throwing all kinds of trouble codes.
    Long story short, unless you are an experienced car builder, it's easier to either get the V6 now, or pay off the I-4 as you currently plan to do, then trade it in for a V6. Just try to keep the miles low on the I-4 to keep your equity (i.e. trade-in value) as high as possible.
    You could just learn to love it as I have...someday I'll get a V6! In the mean time, maybe a turbo or supercharger is a better alternative. I believe there are kits out there (and info on this site)...not sure if you have to beaf up any engine components to handle the increased compression, but it sure beats trying to install a V6.
  18. Aug 18, 2010 at 1:34 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Here's an easier way to get almost the same power of the v6.
    http://www.tacomaworld.com/forum/4-...supercharger-pricing-performance-numbers.html
    And I bet with a few add ons it will surpase the six. Also this route probably won't hurt the resale value. You might even be able to remove it and sell it seperately if you sell it(reason I say might is because you may have to flash the ecu and that might not reversible)
  19. Aug 18, 2010 at 1:37 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    x1000 well put
  20. Aug 18, 2010 at 1:47 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Raptor!
    sorry... couldn't help myself
