V6 5-speed, what was your clutch life?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MattFL, Apr 25, 2016.
  1. Apr 25, 2016 at 1:23 PM
    MattFL
    MattFL [OP] Well-Known Member
    S. Florida
    1999 Tacoma V6 4x4 TRD Extended cab
    You guys with high mileage v6 5-speeds, how long did your clutch last before having to be replaced?
    My 99' v6 5-speed 4x4 with ~187k miles is on the original clutch. I tow a lot, and I'm getting ready to tow a trailer about a thousand miles from home, and that got me thinking about the clutch. It works fine, but sooner or later it's got to wear out, so I'm curious how far everyone else has made it on the original clutch.
  2. Apr 25, 2016 at 3:23 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    220K on my original clutch and still going strong *fingers crossed*
  3. Apr 25, 2016 at 3:26 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    If the previous owner of the truck wasn't lying, then less than 100k :notsure:
  4. Apr 25, 2016 at 7:57 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I went to 150,000 miles and got nervous... changed it when I probably had a shitload of miles left. The wear should be somewhat gradual and give you some time to fix it before disaster strikes, I'd keep going.
    hr206 likes this.
  5. Apr 25, 2016 at 11:33 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I had around 140,000 to I let a clueless person drive my truck I venture I could have made it another few years .
    @ 60,000 on a Luk clutch
    It all comes down to your driving habits unless this trip is going to call for constant pulling out on hard grades with both the truck and trailer overloaded .
  6. Apr 25, 2016 at 11:35 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Just hit 225k on original, and I'm the second one to learn stick on it.
    Black97v6MT likes this.
  7. Apr 26, 2016 at 1:23 AM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    Mine became stick 2 years ago with brand new TG clutch accumulated 13000+ miles I guess I still have another 7-8 more years to go lol
  8. Apr 26, 2016 at 9:59 AM
    BenLC
    BenLC Member
    I am at 302K miles on my original clutch going to be replacing it in the near future.
  9. May 9, 2016 at 11:26 AM
    eon_blue
    Azusa, CA
    jesus christ, you guys are getting a lot of miles on these clutches. I haven't had my truck for very long yet, but on my last car (Scion tC) I had to change out the clutch at around 90k miles and was told by the mechanic that's usually around how long a clutch will last (he said between 90-150k).
    Only 26k on mine right now but I sure hope I get as many miles out of it as you guys are. I'm supercharged though on what I believe is an OEM clutch....should I expect that it'll wear out faster than normal?
    I don't drive like a maniac, rarely ever go full throttle even with the s/c (don't have an upgraded fuel system yet and it'll ping if I do).
  10. May 9, 2016 at 11:31 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    When I sold my '98 it had 229K rounds and was still on the original clutch.
  11. May 9, 2016 at 12:39 PM
    MattFL
    S. Florida
    Aside from just having a really durable clutch, the key to clutch life is don't drag or slip the clutch a lot. When you start out from a light, don't rev the engine high and let the clutch slip, instead only use a little throttle and let the clutch all the way out before the RPM's get high. When you shift try to match the engine RPM to the transmission RPM when you let the clutch out so that there's no slip required. If you're hauling up a hill, or up a boat ramp, use 4x4 low to get rolling. Sometimes when I'm towing at the max capacity (5000#) I'll use 4x4 low to get rolling from a red light to save the clutch. The only time I haven't figured out how to avoid lots of clutch slipping is when backing a trailer into a really tight spot, where you've got to make lots of adjustments and take your time. Can't use 4x4 low there because the wheels will bind up while you're turning, so just have to slip the clutch.
    You guys who have replaced the clutch on the v6; is it a difficult or time consuming job?
  12. May 25, 2016 at 6:26 PM
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    185K miles here, with a couple years of off-roading, and a few tough towing trips of a few thousand miles.
    Clutch was slipping a teeny bit, but the nail in the coffin was when some aluminum piece of the tranny mount broke off and the clutch pedal no longer controlled the clutch. That was not awesome. Experienced tech said he had never seen that before.
  13. May 26, 2016 at 6:26 AM
    Madjik_Man
    Colorado Front Range
    205k on the original clutch
  14. May 26, 2016 at 6:42 AM
    low boy
    low boy 4wd Toyota Enthusiast
    Maryland
    2001 Tacoma TRD Xtra-cab
    lift, tires, wheels, some interior stuff
    135k original, still gtg.
  15. May 26, 2016 at 7:04 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    My neighbor has well over 200k on his orginal clutch and it just started slipping.
    My dad has 130k on his. It is suffering from some oil contamination from a leaky rear main so it will need to be done soon.
    Mine is original and going strong at 146k, but i have the 2.7l
  16. May 26, 2016 at 7:40 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    130k. I was building my lefty and rebuilding my crawl box so i decided it was time to do the clutch while i had everything apart. The stock clutch still looked great. Running a marlin clutch now at 175k and I'm sure the truck will rust apart and be scrapped before the clutch goes.
  17. May 26, 2016 at 7:48 AM
    TerandDi
    TerandDi Member
    2015 White DCSB TRD Sport
    225 thousand kilometres over 17 years and then we sold the truck! Saw the truck yesterday and he new owner loves it...almost as much as we love our 2015 DCSB. Highway driving, towing, getting firewood, hunting....
  18. May 27, 2016 at 6:47 AM
    TACO in SC
    TACO in SC TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
    135,000 on original clutch here. I can feel no slipping or other problems. Bought the truck new so know the history.
  19. May 27, 2016 at 8:35 AM
    Madjik_Man
    The only "issue" I've heard about mine (205k on the original clutch) is that @Squeaky Penguin 's little pinter legs had a hard time pushing my clutch pedal. When I drove his truck, with a new clutch, it felt like my gut.... softy and mushy.
    low boy likes this.
  20. May 27, 2016 at 8:40 AM
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    Got 84,000 ish on mine feels fine but at times it sounds like a cricket is in there untill i put the slightest pressure on the pedal and it goes away.. think its t/o bearing which i was told replace the whole clutch and not just that since the amount of labor involved .
