V6 and 2.7L Trannys - Same?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Garth223, Jan 6, 2011.
  1. Jan 6, 2011 at 2:40 PM
    Garth223
    Garth223 [OP] Well-Known Member
    Garth
    04 PreRunner
    All Pro Bumpers, K&N CAI Kit, Rough Country 1.5" Fender Flares, Lund Bug Deflector, Icon Coilovers, Total Chaos UCAs, Billy 5125's rear, Deavers leaf springs, GrillCraft Black Mesh Grill, Blacked-out Taillights, All Pro 1.5" Wheel Spacers on back axle, FJ Cruiser Rims.
    Im getting tired of only having 2WD so Ive been looking at doing a conversion to 4x4. I have found threads detailing the parts i need, however I am wondering if I need to get a 2.7L transmission, or will either one work? And if anybody is parting out a 4x4 near Eastern North Carolina, or New Hampshire, I would love to talk to you.
  2. Jan 6, 2011 at 2:43 PM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    Wait, I'm confused. Don't you have the 2.7 tranny (4-speed) in your truck already? Most will tell you to just trade in your truck for a 4x4, depending on your skill in mechanics. But the transmission shouldn't be an issue.
  3. Jan 6, 2011 at 2:48 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Uhhhh
    I read it and re-read it.
    But, I think, just maybe, you mean "Transfer Case" instead of "Tranny" which is an abbreviation for "Transmission."
    If that's not what you mean, perhaps you should clarify your question.
  4. Jan 6, 2011 at 3:19 PM
    Garth223
    Garth
    04 PreRunner
    alright sorry, perhaps question was not well worded.
    When doing a PreRunner to 4x4 swap, you need a new transmission, transfer case, and shorter drive shaft to accomidate the additional length of the TC, which is roughly 11 and 3/4 inches or something along those lines.
    Edit: A 4x4 transfer case cannot be attached to my transmission, meaning i need to replace that component, along with the drive shaft, cross member, spindles, etc.
    MY question is: Is a transmission from a V6 compatable with my 2.7L engine?
  5. Jan 6, 2011 at 3:22 PM
    PWhite13
    Prescott
    Southern California
    I could be wrong, but I haven't heard of needing a new transmission for 4x4 swaps.
  6. Jan 6, 2011 at 3:30 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Jan 6, 2011 at 3:36 PM
    Garth223
    Garth
    04 PreRunner
    If i was to reuse the 2WD tranny i would need to crack it open and swap out the output shafts. Less work to just get a whole new one and skip that step.
    Next question, and perhaps what is causing all the confusion: Did the 1st Gen 2.7L engine come with a 4x4 option? Or was that reserved only for the 3.4L?
  8. Jan 6, 2011 at 5:53 PM
    PWhite13
    Prescott
    Southern California
    Yes, you could get 4x4 in either the 2.7 setup, or the 3.4 setup.
  9. Jan 6, 2011 at 6:58 PM
    Garth223
    Garth
    04 PreRunner
    OK, so is the transmission the same between the two of them? Thats what i have been wondering from the begining. Just didnt word it right.
  10. Jan 6, 2011 at 7:00 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    I dont think they are the same, im looking at doing the conversion too.
  11. Jan 6, 2011 at 7:33 PM
    Garth223
    Garth
    04 PreRunner
    It doesnt look to be too hard of a job, just a weekend of solid work. Anybody got a 100% positive answer?
  12. Jan 9, 2011 at 10:37 PM
    Garth223
    Garth
    04 PreRunner
    After some further research, I have learned that the transmission in question is the A340F. It was used on both the 2.7L and 3.4L engines, equipped with 4WD, in all 1st Gen models.
    The following is a list, which I believe to be complete, with the year and model of other Toyota's also using the A340F:
    00 - 04 Tundra
    95 - 04 4 Runner
    90 - 94 Pickup
    95 - 04 Tacoma
    93 - 98 T-100
    01 - 04 Sequoia
    Of course, the A340F is located only on the 4WD equipped models of those years. The 2WD models come with different ones, such as my 04 PreRunner, which uses the A340E.
    From what I have learned, the only differences between them is the wiring harness, but due to the absolute lack of Tacoma's at junk yards in the Southern NH/ Mass, and Eastern NC, I believe it will be far easier and cheaper to locate the A340F from one of the above listed vehicles, and simply purchase a harness off ebay, or if that fails, the dealership.
