V6 Antifreeze/Coolant Change How-To
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Foghorn, Mar 15, 2020.
  1. Oct 4, 2023 at 4:27 PM
    #41
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    pink instead of green but the gradient is valid
  2. Oct 4, 2023 at 4:34 PM
    #42
    machrx
    machrx Member
    ND
    2010 DC LB 4X4 TRD SPORT
    #Dm93, okay, I drain and check visually how dirty it is, and perhaps flush if it is dirty, I am hoping its clear...Even tho I have a 4x4, I NEVER went Off-Roading with the Tacoma...
    Dm93 likes this.
  3. Oct 4, 2023 at 4:35 PM
    #43
    machrx
    machrx Member
    ND
    #Dm93, thanks for the advice...very helpful..
    Dm93 likes this.
  4. Oct 4, 2023 at 4:41 PM
    #44
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Crap in cooling systems typically comes from coolant breaking down due to age, mixing incompatible coolants, and/or using tap water instead of distilled water.
  5. Oct 5, 2023 at 4:21 AM
    #45
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    -J
  6. Jan 13, 2024 at 12:34 PM
    #46
    ShawooTaco
    ShawooTaco Member
    I’m doing my flush right now and only drained 3/4 of a gallon out of the radiator and passenger side drain combined. What am I doing wrong here? Coolant came out clean. Yes the radiator cap was off. I poured in about the same amount that came out
  7. Jan 13, 2024 at 4:16 PM
    #47
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    maybe the thermostat didn’t get up to temperature and didn’t fully open. This was a great buy when I did mine:
    https://www.amazon.com/dp/B01I40ZQWE
  8. Jan 13, 2024 at 8:33 PM
    #48
    ShawooTaco
    ShawooTaco Member
  9. Jan 13, 2024 at 8:49 PM
    #49
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If it was full when you started I'm not sure, mine has always taken almost exactly 2 gallons when I open the rad and both block drains but the drivers side drain is never more than a quart or 2.
  10. Jan 13, 2024 at 9:41 PM
    #50
    ShawooTaco
    ShawooTaco Member
    I know, that’s what so confusing for the radiator was filled to the top when I started. Barely anything came out of the passenger side drain. Maybe it was tied up in the heater core?
    Zero issues once I burp the system and brought it up to temperature.
  11. Jan 14, 2024 at 5:33 AM
    #51
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You sure the drain wasnt just plugged?
  12. Jan 14, 2024 at 12:56 PM
    #52
    ShawooTaco
    ShawooTaco Member
    I didn’t think of that during the time, I guess anything is possible. Maybe it’s clogged? But I guess why would 3/4 of a gallon come out and not the rest? Also, I got nothing but drops out of the passenger side engine block. Maybe everything is just clogged? is there anyway to unclog that? Will a paperclip fit in there?
  13. Jan 14, 2024 at 1:03 PM
    #53
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Doesn't take much to clog those, any piece of small semi stiff wire should work to clean it out.
  14. Jan 15, 2024 at 6:19 PM
    #54
    ShawooTaco
    ShawooTaco Member
    I’m guessing I can unscrew the entire drain plug without damaging anything? I only drained from the hose
  15. Jan 15, 2024 at 6:20 PM
    #55
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes you can.
  16. Feb 29, 2024 at 9:37 AM
    #56
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Quick question for you guys that replaced the thermostat. How did you get the nut that is closest to the block back on ? I can get to the top and the one closest to the radiator but can't get my hand in there to start the nut to do the one on the bottom closest to the block . And even removing the oil cooler line I can only get one finger on the nut .
  17. Feb 29, 2024 at 9:43 AM
    #57
    Tenmile Tacoma
    Tenmile Tacoma IG: tenmile_tacoma
    Nate
    Colorado
    2016 DCLB TRD Sport 4x4
    F&R locked on 33s
    Great write up, OP! Thanks a ton. Your truck is CLEAN btw. Looks like it just rolled off the showroom floor!
  18. Feb 29, 2024 at 12:41 PM
    #58
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    That's exactly what I do...Works fine for many cars over many years !
  19. Mar 1, 2024 at 3:29 AM
    #59
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    I use a short extension with an elbow attachment. I put a dap of silicone on the sock head to hold the nut in place. It is still tricky, but it works.
    blnewt likes this.
  20. Mar 1, 2024 at 7:35 AM
    #60
    tacoma guy
    Joe
    Phoenix Az.
    That is a good idea ! I will have to give that a try . Thanks for the reply ! Much appreciated!! Yeah I definitely see how that one is tricky to get back on and start threading it .
    POOLGUY[QUOTED] likes this.
