V6 Belt diagram
Discussion in '1st Gen. Tacomas (1995-2004)' started by cm103, Jun 25, 2014.
  1. Jun 25, 2014 at 6:00 PM
    cm103
    cm103 [OP] Member
    Miramar, FL
    2k PreRunner
    Continuing on my slow rehab of the taco I was trying to recharge the AC. As soon as the refrigerant went in, I could hear it hissing coming out somewhere under the power steering reservoir.
    On closer look it seems like the PO bypassed the AC compressor pulley and there is no belt on it, just on the water pump. I'm going to try to crank the pulley and see if it turns and just do a belt change at the same time to see if I can get the compressor back in the loop. Hopefully what I heard was just a hole in the line and I can just have that changed out.
    Does anyone have a good belt diagram or a pic they can share? The sticker on the underside of the hood is worn.
  2. Jun 26, 2014 at 11:03 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    EDIT: (I posted wrong pic, check next post)
  3. Jun 26, 2014 at 11:51 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    That's not the 3.4L v6 belt diagram. P/S and alternator are on opposite sides of each other.
  4. Jun 27, 2014 at 5:55 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Whoops! I was trying to go off memory... Engine number matches this one..
    77837d1260615917-3-4-drive-belt-diagram-_20e78f41b7ad6406454c7ab2dfec6540d8f8810b.jpg
  5. Jun 28, 2014 at 4:58 AM
    cm103
    cm103 [OP] Member
    Miramar, FL
    2k PreRunner
    Thanks all. I did see those diagrams when I did a google/bing image search, but I saw others as well. I wanted to make sure that I was routing the belt correctly.
    I believe I saw one article that mentioned a single serpentine belt which totally threw me off since looking at my engine bay I see separate accessory belts.
