V6 engine running on 3 cylinders
Discussion in '1st Gen. Tacomas (1995-2004)' started by drew.franklin88, Mar 9, 2014.
  1. Mar 9, 2014 at 12:23 AM
    drew.franklin88
    drew.franklin88 [OP] New Member
    clarksville, tn
    Lift
    I have a 1996 Toyota Tacoma 3.4L V6. All 3 cylinders on the driver side are misfiring. I fixed a blown head gasket here a bit ago with a mechanic's help and haven't had a problem till recently. I did a tune up and replaced the spark plugs and cables but no change. My temperature gage does not work either. I replaced most of the vacuum lines but still no change. I was wondering if anyone had any ideas of what to check, where to start, and then maybe some possible fixes.
  2. Mar 9, 2014 at 6:00 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Start with a compression check.
  3. Mar 9, 2014 at 6:54 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Do you have spark on all cylinders? Fuel?
  4. Mar 10, 2014 at 11:58 AM
    drew.franklin88
    clarksville, tn
    Lift
    well i replaced all the vacuum lines and will be replacing the coil packs today after that I guess its just the fuel injectors to check. Any ideas
  5. Mar 10, 2014 at 12:00 PM
    drew.franklin88
    clarksville, tn
    Lift
    also my temperature gage does not appear to be working so I read that the engine stays in a closed loop unless the temperature gage sends the signal to the computer, any ideas?
  6. Mar 10, 2014 at 12:05 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Check for spark on the dead side.
    If you don't have spark, backtrack the circuit until you find either a break or a bad connection.
    If you've got spark, check for fuel pressure.
    Good luck!
  7. Mar 10, 2014 at 12:09 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Coil packs are a good idea, since the 3.4 uses one coil to drive spark plugs on two cylinders.
    Could also be injector wires? Basically looking for any common electrical connection among all 3 cyliners on the driver's side bank.
    Any CEL codes?
    I don't suppose you have an oscilloscope with current probes?
  8. Mar 11, 2014 at 1:17 AM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    So the driverside cylinders are misfiring. Is it still able to run long enough for the engine to warm up? Can you explain with some detail how it idles or runs?
