V6 Engine Ticking?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrdbrn, Apr 10, 2016.
  1. Apr 11, 2016 at 11:20 AM
    sand storm
    sand storm Active Member
    ernie
    south texas
    2016 grey met TRD 4x4 off road
    stock
    I'm a previous owner of a 14 Tacoma DC 4x4 4.0......the 3.5 in my 2016 TRD off road 4x4 is much louder. After hearing all the advertising about how quiet the engine is etc. I am somewhat disappointed. This engine struggles, and sounds loud at idle and like it is coming apart at higher RPMS. The Toyota" its normal "answer to what seems wrong is a cop out! The hood needs insulation along with the fire wall to reduce some of this "normal" engine noise.
  2. Apr 11, 2016 at 11:26 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The 4.0 in my 15 ticked like crazy too, drove me crazy. I fixed it with a supercharger, now it just whines instead. Much more pleasant. Unfortunately that fix isn't available for the 3.5.
  3. Apr 11, 2016 at 1:53 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I think most people confuse rocker arms with lifters
  4. Apr 11, 2016 at 3:42 PM
    Tocobob
    Tocobob Well-Known Member
    Correct overhead cam engines do use lifters.also called tappets or buckets. They sit below the cam and directly above the valve spring and valve. They can cause ticking at low oil pressure in cold starts but most likely you're just hearing the direct injection. That will tap under normal use. The self cleaning is caused by the standard injectors pulsing. You can hear it but most of the noise is from the direct injectors this is common in every direct injection engine.
  5. Apr 11, 2016 at 4:33 PM
    Tolip
    Tolip Well-Known Member
    2016 Blue Tacoma Limited
    http://www.toyotareference.com/guts/tacoma16_engine.pdf
    My apologies. It looks like our engines use a roller rocker arm type system to open the valves (pg 83). I had a 1992 300ZX TT in a past life (3.0 liter DOHC V6), and the lifters (between the cam and the valve) drying and causing a clicking sound was a very common problem.
