V6 fuel filter change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amocat21, Dec 3, 2014.
  1. Dec 3, 2014 at 9:39 AM
    amocat21
    amocat21 [OP] Active Member
    2012 6 cylinder 4x4
    How often do you change the fuel filter in your V6? Is it a tough job? Thanks:)
  2. Dec 3, 2014 at 9:59 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Dec 4, 2014 at 4:14 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    These Tacomas were engineered with a new style fuel filter that doesn't need to be changed and is part of the fuel pump. Given our gas in the US is pretty darn clean, engineers determined that our fuel filters didn't need to filter down to as many microns because it only made for higher change intervals. The fuel pump/filter assembly is all one piece and they're banking on the fuel pump going and needing to be changed before you need to worry about the filter restricting fuel flow. The research I've done says this shouldn't be a problem at all. Lots of people are skeptical but I for one subscribe to the no external fuel filter system in these trucks and thank engineers for thinking outside of the box.
  4. Dec 4, 2014 at 4:16 PM
    Ostrichsak
    Jer
    Usually looking at a 40k mile change interval for external fuel filters. I sure as shit wouldn't scrap my stock setup for the sole purpose of adding an external fuel filter that requires more maintenance that's for sure. Just creating more work for yourself is all.
  5. Dec 4, 2014 at 4:20 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I'm glad I swapped out personally..... We found some steel scraps in the sock. Very strange for sure.
  6. Dec 4, 2014 at 4:26 PM
    Ostrichsak
    Jer
    In the stock but not in the engine. ;)
  7. Dec 4, 2014 at 4:27 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    True... It did its job, but I am glad its changed
