V6 KM per Tank ?
Discussion in 'Canada' started by OZ-T, Jan 3, 2010.
  1. May 19, 2015 at 6:05 PM
    #761
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    His truck isn't stock
    I'm calling Shenanigans
    Tridet167 likes this.
  2. May 19, 2015 at 6:05 PM
    #762
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Just sounds unusually high kms.
  3. May 19, 2015 at 6:06 PM
    #763
    Tridet167
    Tony
    Toronto, Canada
    I find it amazing that people get such variations on mileage even from a stock setup.
  4. May 19, 2015 at 6:08 PM
    #764
    OZ-T
    Peter North
    British Columbia
    I'm at 350km at just above 1/4 tank right now so I'm probably going to hit 450km at the light this time , zero highway , below 80 km/h , hilly rural driving
  5. May 19, 2015 at 6:08 PM
    #765
    sixspeedlife
    sixspeedlife Well-Known Member
    Braden
    MB, Canada
    05 TRD OFFROAD Six speed
    Leveled, BHLM, Black mesh grill, black skid plate
    Ha ya I just creeped his build thread, epic truck
  6. May 19, 2015 at 6:15 PM
    #766
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    I got 660 kms on 52 litres after my first oil change from the Toyota service oil and OEM filter (first 4 changes were free) to Mobil 1 full synthetic, a Mobil 1 high flow filter, and a Fumoto valve. That was all highway miles at 115 kph average from Belleville, ON to Montreal, QC and back. Now I average 680 kms to a tank (light not on at fuel up - 60 to 65 litres of high test gas) of mixed highway/stop and go in the County. I was only getting about 365 kms per 60 litres on factory oil. It must be the valve.
    BTW, I found that Toyota had cross-threaded my oil plug.
    True story.
  7. May 19, 2015 at 6:43 PM
    #767
    taczilla
    Marc
    2016 RAM Rebel
    Thanks, man. I just did some more to it.
  8. May 19, 2015 at 8:21 PM
    #768
    Fuse
    Fuse Geologist
    Calgary
    2015 TRD Sport 6MT
    My last tank driving Calgary to GP was 58.21L in for 452.3km traveled. Works out to 12.87L/100km or 18.3MPG, holding 115-118km/hr with a fair amount of gear in the truck.
    I'm sure I can do better with some adjustments to my driving style and a slightly lower average speed.
  9. May 20, 2015 at 7:19 AM
    #769
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  10. May 20, 2015 at 7:26 AM
    #770
    sixspeedlife
    Braden
    MB, Canada
    Is this an app or...?
  11. May 20, 2015 at 7:31 AM
    #771
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Sure is!
  12. May 20, 2015 at 7:32 AM
    #772
    sixspeedlife
    Braden
    MB, Canada
    Is it called fuelly?
  13. May 21, 2015 at 1:56 PM
    #773
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Correct sir.
  14. May 21, 2015 at 8:11 PM
    #774
    taczilla
    Marc
    2016 RAM Rebel
    I used to run regular and got crappy mileage with a stock set up. I changed to high test and mileage improved considerably. Then I lifted and put bigger tires, a slightly different castor/camber alignment, and changed from Toyota oil to Mobil 1. I now run 91 octane only and don't pound the pedal. The speedo reads 98 kph at 1800 RPMs. 120 kph at 2100/2200 RPMs.
  15. May 21, 2015 at 9:03 PM
    #775
    OZ-T
    Peter North
    British Columbia
    I run ethanol free 91
  16. May 22, 2015 at 3:59 AM
    #776
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    That surely helps! Mine is at 2500 rpm at 110 kph. Around 2200-2300 at 100 kph. So if yours is under 2000rpms at 100 thats a great advantage!
  17. May 22, 2015 at 9:09 AM
    #777
    sixspeedlife
    Braden
    MB, Canada
    Are you re geared at all? Just curious as to how you can get the rpms down to 1800. I'm sitting at about 2200 at 100kph
  18. May 22, 2015 at 9:28 AM
    #778
    OZ-T
    Peter North
    British Columbia
    Same question here
  19. May 22, 2015 at 9:59 AM
    #779
    taczilla
    Marc
    2016 RAM Rebel
    Me too. The regular 87 octane looked like it literally poured out the tailpipe. There was always moisture at start up and idle. There is no moisture/vapour with the ethanol free.
    Nope, no regear. I run 285/70/17 MT Baja ATZ P3's. I watch the speedometer and RPM gauge like a hawk. If I hit 100 kph it jumps over 2000 RPM, so I keep it at or under 98 kph on the county highways. I also accelerate slowly above 95 kph to avoid the 2600 + RPM range that it usually takes to get to 120 kph. It gets thirsty when it goes over 2000 RPM's. I use Shell premium gas that I buy on the reserve for $1.13 (this week's price).
  20. May 25, 2015 at 7:07 AM
    #780
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Mine also sits at about 1800 at 98-100kph with 285's.
