v6 manual 13-14 mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JimmyBuckets, Nov 2, 2011.
  1. Nov 2, 2011 at 4:24 PM
    JimmyBuckets
    JimmyBuckets [OP] Well-Known Member
    Access Cab 6 speed V-6 sr-5
    I have a 2010 Sr5 extended cab 4x4 all stock and have been seeing 13 to 14 mpg for the last bunch of tanks. I realize the manual is only rated 14 city and 18 hwy but this is pretty retarded. The truck has right under 10k miles on it. Anyone else seeing this with their manual v6? I got about the same mpg in my 04 six liter Chevy 2500. It would be one thing if this had the 5.7 in it...any ideas?
  2. Nov 2, 2011 at 4:30 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    check your air filter, winter gas :notsure:, tire pressure, lead foot? Is this all city, are you hauling anything?
  3. Nov 2, 2011 at 4:33 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    '09 SWB 4.0 6-speed semi-debadged
    clear DTRLs, AMO Buckshots, factory upgrades, lifted
    If you figure it out, lemme know.
    What are your current driving habits? (shift pattern, RPMs, speeds, etc.)
  4. Nov 2, 2011 at 4:37 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    I hear ya...been posting on the Canadian thread on this...I am getting way worse than most on fuelly.com...2005 automatic TRD OR access cab, 265/75/R16 BFG At's...aftermarket CAI,
    I'm getting about 15.7L per 100km's...or about 420Km per tank...at today's prices it costs almost 20 bucks to go 100 km's
    Haven't done the conversion, but pretty bad compared to most Tacos on the fuelly site.
    Still wouldn't trade...love my truck.
  5. Nov 2, 2011 at 4:38 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    I do 18-19 in the city, assuming I can keep my foot off the floor and traffic isn't shitty. The AC comes on if you have it on defrost or Def/floor. That will hurt MPG in town.
    Don't coast in neutral - keep it in gear/downshift and let the engine brake you. Also, check your tire inflation and check if a brake is hanging up.
  6. Nov 2, 2011 at 5:01 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Keep your speed down 35PSI in the tires skip gears unless you need the power put a block of wood under the gas pedal. I usually do 400 miles per tank empty and 225 or less pulling my camper at 75 so speed and weight makes a big difference.
  7. Nov 2, 2011 at 5:11 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    '11 TM DCSB & '13 BRM regular cab
    Leather seats, WeatherTech's, Access LiteRider tonneau cover, extra D-rings in bed & tailgate. Pelley lightbar with Hella 700FF's. Temp./compass O/H console.
    Ouch. Like others have said, check air filter & tire pressures. With only 10K miles, unless you're on dirt roads daily, the air filter shouldn't be too bad. Good luck.
  8. Nov 2, 2011 at 5:19 PM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    07 AC TRD 4x4 25K Miles All stock except tires.
    I tracked it for a few months and my long term average was right around 19MPG (Imperial, not US). City and highway mix.
  9. Nov 2, 2011 at 5:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    2006 TRD V6 6speed. I am running 89 octane, have a cab high campershell. Truck is stock with highway tread tires, 40 psi tire pressure.
    If I stay out of the throttle, I get 15 in town. On the highway I average 19 at 70mph. Start getting into the throttle around town and I drop to 14. I have seen 13 only once, and that was with 87 octane. The octane does make a difference on mine. My owner's manual recommends 91 octane.
  10. Nov 2, 2011 at 6:59 PM
    JimmyBuckets
    We just moved to a new area and there is a lot more stop and go. I would say I normally shift below 3k and run about 70-75 on the hwy. I have been running 87 after a long run on just 93. I was thinking getting tire pumped up a new air filter and switching back to 93 might help. But something tells me it won't make that much difference. It seems like to only way to get ok mpgs out of this truck is to shift at or below 2k and go 60 on the hwy...which totally sucks balls and makes me want to kill myself. I love driving it, but for fucks sake with the mpg.
  11. Nov 2, 2011 at 7:20 PM
    First Taco
    First Taco Well-Known Member
    Robert
    Wa
    TRD Sport 4by4 4.0
    I would think the stick is better. I never buy auto's but did on the Taco
    2011 access cab 4 by 4 TRD sport loaded prite mica which grows on you quick! I get 19.5 all the time mix city hwy. Love it!
  12. Nov 2, 2011 at 10:45 PM
    KingTaco91
    KingTaco91 Active Member
    11 AC TRD Offroad 6spd
    13 - 14 Sounds pretty low. I remember when I first got mine I was getting about 15. I now have 23k miles on my 2011 6 spd 4x4 and consistantly get 17.5 to 18 mpg per tank. And this is driving through garbage traffic of downtown LA. Your mpg's should get better as you pile up the miles.
  13. Nov 2, 2011 at 11:26 PM
    canadaman
    canadaman Active Member
    Canada
    07 TRD Sport
    That's about what I average with my 07 6 spd DC 4x4 TRD sport. Even if I drive like a grandma I can't break 20. I am honest with myself though. I take a true average over all kinds of driving....because thats how I drive. A tank of all highway may get 18mpg. A tank of city closer to 14mpg. Either way, I guess I didn't buy a truck for gas milage. If i wanted that I would have got a Jetta tdi or something similar. Its still brutal on the pockets though.
  14. Nov 3, 2011 at 3:22 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    True. At 75 mph the truck is only averaging about 16-18mpg, so there's no chance to recuperate the fuel spent accelerating. Dropping to 65 mph will bump that up to about 22 or so. 6th gear is way too short.
    For some reason going to 3k on this motor to shift really does use a lot of fuel. Chances are you're not using high engine load to land yourself in the lowest BSFC you can, which is part of why low rpm works better.
    I shift at around 1800 and keep it over 19 mpg easily. I tried going to 2200 and even at the same engine load my fuel consumption average went down about a half a mpg.
  15. Nov 3, 2011 at 4:12 AM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    The gas mileage on the Tacoma is frustrating. Especially if you factor in that the 5.7 Crewmax Tundra gets the same or better. :mad: I have helped the gas mileage situation by not driving it as much and grouping my errands into one big round trip. :cool:
  16. Nov 3, 2011 at 4:25 AM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    I have a V6 4x4 6 speed. I was getting around 19-20 mpg with my current set up (small lift and 265 70 17 duratracs).
    Now that hunting season has started and I am taking more short trips and using 4x4 I am seeing around 17.
    I consistenly shift under 2500 but I dont baby it either. I think the sweet spot is around 2100 rpms.
  17. Nov 3, 2011 at 6:23 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    When I had my 06 X-Runner I was getting about 14-15mpg,(gas was cheap then) :rolleyes: but I drove it like I stole.
  18. Nov 3, 2011 at 6:26 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    3 inch lift 6 speed with Bf G's 265/70/17. All city and I get 17. Keep the rpm's below 2,000 and downshift.
  19. Nov 3, 2011 at 7:37 AM
    JimmyBuckets
    I just wanted to see if what I have been seeing is normal.
  20. Nov 3, 2011 at 11:39 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I didn't see anything saying WHERE you are? I am in Southern California and the retarded gas blend as so little real gasoline in it, we get less miles than other places per gallon.
    I filled up yesterday and for city/ hwy. combined was 15.7 mpg. This is with a corrected odometer with the 32" tires, however. I have gotten as little as 14.5 mpg around town driving.
    It goes up anytime I am on only the highway... 18-19 mpg.
