V6 mpg?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomaconvert, Aug 10, 2012.
  1. Aug 10, 2012 at 9:58 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Between 17 and 18mpg city and about 19 hwy. Sometimes I can do 20 or even 21 hwy if I really try.
    On the other hand I often do around 15mpg city in the winter months when temparature drops to -20C or -30C. Worst was 13.5 or so.
    07 DCSB 4x4 6MT
    Summer: 265/75/16 AT's
    Winter: 265/65/17 winter tires.
    More info in my fuelly sig.
  2. Aug 10, 2012 at 10:07 AM
    tacomaconvert
    tacomaconvert [OP] Well-Known Member
    NY
    '12 White SR5 DC 4X4
    Factory roof rack, bed extender Extang Full Tilt Tonneau
    Dam, very active site. Thanks for all the info and quick replies. I had trucks for 10 years and had mileage worse than the current Tacoma's, then switched to a SUV with much better mileage and now the Tacoma is somewhere in the middle. Not expecting to get great mpg's, just trying to realistically prepare myself for what to expect and was somewhat confused why there were different MPG's listed on a few of the ads.
    Thanks!
  3. Aug 10, 2012 at 10:09 AM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Sitting at 20.2 combined. V-6 dbl cab short bed with 5100's leveling front and stock size tires. I run 87 grade gas on a regular basis.
  4. Aug 10, 2012 at 10:19 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yes, the official mpgs change each year due to revised EPA measurement methods. With several Toyota models, you'll see the 2012 published numbers are better than 2011 or 2010 numbers by 1 or 2 mpg because Toyota re-tested with 0W20 synthetic oil.
    For Tacos, mpgs also vary greatly with engine, body style, auto vs manual, and 4x4 vs 4x2. Take a look at the Toyota press kit for all the different mpg ratings:
    http://pressroom.toyota.com/article_download.cfm?article_id=3139
  5. Aug 10, 2012 at 10:25 AM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    best I've done is 21.7 MPG all highway. typically get ~17 MPG city, ~19 MPG highway.
  6. Aug 10, 2012 at 10:33 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    2010 DC AUTO 4WD CALIF.
    Best highway 19-20 mpg
    Typical highway 18 +/- mpg
    Typical mixed city/hwy 16.5 mpg
    City only 15 mpg
    The truck hates starts and stops (city).
  7. Aug 10, 2012 at 10:33 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    also the 6 spd MPG is lower than the auto MPG on the sticker
  8. Aug 10, 2012 at 11:15 AM
    ssmith29440
    ssmith29440 Well-Known Member
    2012 Tacoma TxPro Trd
    I do mostly city driving. Avg around 15-17 mpg. I try to avoid fast accelleration and coast when approaching stops. I've also used 87-93 octane and see no difference.
  9. Aug 10, 2012 at 11:17 AM
    KenLyns
    Belly of the Beast
    I drive mostly rush-hour highway. Avg mpg is spot on with the EPA city rating of 16 mpg for my truck's configuration.
  10. Aug 10, 2012 at 11:17 AM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Not a buttkicker for MPG's. I can't see more than 23-24 at steady highway speeds, getting 18-20 with mixed usage but the truck weighs about 4300 lbs with the topper. I had a '99 F150 4WD no topper with the Mustang 4.6L DOHC V8 and that got about 14 MPG around town, about 20 on the highway. That F150 weighed maybe 200 lbs more.
  11. Aug 10, 2012 at 11:19 AM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    17MPG on average click my sig I have a DCSB. I now have a little over 2K miles on my truck now and it seems my mileage is getting a little better.
  12. Aug 10, 2012 at 11:24 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i get 15-17 mixed driving, have only pushed 20 on one road trip that was all highway. in the winter with mostly city driving i get about 14-15
  13. Aug 10, 2012 at 11:39 AM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    Click on the link below. I like to use fuelly and find someone who is consistent about entering their fillups. That is as "real world gas mileage" numbers as you are going to get.
  14. Aug 10, 2012 at 11:51 AM
    KenLyns
    Belly of the Beast
    Note if you get larger tires without re-gearing, the odometer reading will be less than actual. Be sure to account for this when calculating mpg.
  15. Aug 10, 2012 at 12:37 PM
    #35
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    2011 access v6 6 speed manual
    If I keep it under 55 I can get 21.7 mpg. Once I hit the highway and go around 70 it drops down around 17. For mine it's all about the rpm range.
  16. Aug 10, 2012 at 6:34 PM
    #36
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    OP may want to look at tacomas equiped with the 2.7l 4 cylinder. Stock 4x4 you can get mid 20s
  17. Aug 10, 2012 at 8:59 PM
    #37
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Not totally true, my summer tires [305's] and winter tires [stock] is less than 1/2 mpg, I average about 17 mpg city and hiway combined
  18. Aug 10, 2012 at 9:02 PM
    #38
    AddicTioN
    AddicTioN Forklift technician
    wyatt
    north carolina mountains
    2020 dclb off road
    i get around 17-19...i mostly get 17. i like the skinny pedel:headbang:
  19. Aug 10, 2012 at 9:05 PM
    #39
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    Ive logged every mile since i bought my truck brand new. i get 16.5-18mpg per tank avg. I have 3" lift and 33" AT's it also depends how you drive for sure. When i tow i get 12-13mpg.
  20. Aug 10, 2012 at 9:09 PM
    #40
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    if youre worried about MPG's get a double cab 5 speed 4 cylinder
