V6 or 4 banger What should I get?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crisanalex, Apr 29, 2017.
  1. Apr 29, 2017 at 8:48 PM
    crisanalex
    crisanalex [OP] Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    I'm looking for a first gen witch is the better engine for overall longevity, reliability and capability I will probably be doing very little to no towing. And any feedback for purchasing one would be greatly appreciated! Thank you.
    keakar likes this.
  2. Apr 29, 2017 at 8:54 PM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    Condition and maintenance is all that matters. Both great motors! See the fish delivery T100 2.7L with 1 million miles? Now that's longevity!
  3. Apr 29, 2017 at 9:05 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    The 3.4 all day long. The four cylinder is not worth the time or effort. I've also noticed at least in my area it seems like the four cylinders always have had headwork or a complete engine replacement.
    mountainman38 and crisanalex[OP] like this.
  4. Apr 29, 2017 at 9:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea get the 6. Cyl.. they're easy to work on and the extra grunt will help w/ daily driving..
  5. Apr 29, 2017 at 9:15 PM
    crisanalex
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    Ahaha I was totally expecting mixed reviews I was hoping everyone would say the 6 is there anything I should be looking for or be aware of when buying?
  6. Apr 29, 2017 at 9:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Always always always be wary of a blown headgsket
    I like this block tester kit.. I've brought it along when a buddy is buying a used car and I would do it in the parking lot
    http://www.coastaltoolsupply.com/pr...9WpUUN_xpWtCnfq-kvKHdAmNylNIqhhvZbnRoCoLDw_wc
    Also make sure it's easy to downshift coming to a stop syncros and stuff.
    If you dont know the history of the t belt plan on doing it..
  7. Apr 29, 2017 at 9:40 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    OK, so I will put my vote on 2.7. While it has less torque than 3.4 it still has enough "umpfh" for normal driving (I did not do long houl towing in mine except getting 30 ton log spliter from Home Depot and getting heavy stuff on my bed ocassionally). The main things that made me prefer 2.7 are lifetime warranty for timing chain :) (no need to replace every 100k miles like timing belt), and easy to work around under the hood. 2.7 is much smaller than 3.4 so there is easy access all the way around it (maybe except the famous fuel filter). And even replacing a head gasket (which has a tendency to blow around 300k miles) is way easier in 2.7 than in V6. I did replace head gasket in 2.7 and then I watched videos about the same job in 3.4 - man, V6 is so complicated comparing to I4.
    So my suggestion is for performance take 3.4 (more low rpm torque), for easy maintenance you can't beat 2.7.
    Oh, and I'm talking about MT also for the easy maintenance.
  8. Apr 29, 2017 at 9:43 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I think head gaskets may have been an issue on the early Tacoma's but mine had been fine (fingers crossed)
    My 3.4 is only at 126k miles and I've replaced the starter for getting hung up, it idles a little too high (around 850-900) which may be just a pcv valve, and I need to do the valve cover gaskets.
    Not much for a 21 year old engine. If you don't care about saving a couple MPG then get the V6.
  9. Apr 29, 2017 at 9:45 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    They're both good engines.. The 4 bangers really are indestructible. It just depends on what you plan to do with the truck. Any kind of lift and tires you'd want the torq of the 6 cyl
    BigEasy likes this.
  10. Apr 29, 2017 at 9:46 PM
    taco terror
    USA
    The V6 does have a timing belt, but it's a non-interference engine so even if it does snap it won't destroy the engine.
  11. Apr 29, 2017 at 9:57 PM
    col. sandurz
    col. sandurz Well-Known Member
    I've got a 2.7 with 128k.
    It may or may not need a new head, I am getting 9 mpg and makes lots of noise. I can say the 4 does have room to work on under the hood and they are supposed to be reliable.
    Being said, I've never had problems with power off-road, even pulling others out. On road the truck has always felt weak. Even before something has gone wrong, the motor and large tires/tall gearing makes the truck slow.
    Not sure how the extra weight of the 6 affects the driving, though many have both 4&6 with heavy armor and no issues, I imagine it's a good pick
  12. Apr 29, 2017 at 10:06 PM
    RysiuM
    Rysiu
    Really the only few things I did in my 2.7 during last 250k miles and last 19 years (which is since I own this truck) are: head gasket (this was the only major thing), cracked exhaust header, clutch, tip of distributor (that was preventive) and oil pan (replaced by the dealer on their dime because they cross-threaded the plug during the oil change). Everything else is still original. I'm just changing the oil every 5k miles and add fuel every 280 miles (when 1/4 is showing on the dial :)).
    I don't want to jinks myself, but this thing is just amazing. My 5 years old with 100k miles Mercury Sable was just a wreck when I sold it - the only fluids that did not leak was breaks and fuel). That Mercury was my second POS vehicle (after even worse POS Fiat).
  13. Apr 29, 2017 at 10:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A sable baby!
  14. Apr 29, 2017 at 11:04 PM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    The 6cyl gets my vote
  15. Apr 29, 2017 at 11:59 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    2.7l, power difference is negligible, although I'd opt for a manual transmission with the 4 banger to get the most out of it. The 4 bangers are basically bullet proof and very boost friendly if you want extra power. People use the 2rz/3rz for race engines all the time, yet I've never heard of a 5vz being any more modded than a factory supercharger. Oh yah, my 300k+ 3rz still get 22-24 mpg Rollin on 33"s. Won't get that out of a 3.4.
  16. Apr 30, 2017 at 1:11 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is a scheduled to replace at 90,000 miles item. Check the water pump at the same time, easy access, if it drips.
    Those were the only things that needed work on my 2001 Taco, and I put 136,000 miles on it in 5 years!
  17. Apr 30, 2017 at 1:28 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    My 01 4cyl has 200k miles. Runs perfect and no issues
    Since you are saying head gasket goes at 300k anything to look out for?
    Should I do any preventative maintenance ?
    Thanks
  18. Apr 30, 2017 at 1:39 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Love my 5VZFE (V6) I'm
    At 130,000 which is early miles for that engine.
  19. Apr 30, 2017 at 2:42 AM
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    i have a 02 with a 3.4 and has 304k on it. i only use the truck for towing my boat. my daily driver is a 2012 with a 2.7, 5 speed and only 60k on it. the best of both worlds.
  20. Apr 30, 2017 at 5:32 AM
    wbrigance
    wbrigance Member
    Will
    Jackson, TN
    1998 Tacoma 4x4, Reg cab, Manual, 2.7L
    For what it's worth, i have 212k on my 1998 2.7L tacoma. Replaced the radiator and thermostat. Runs like a top. I drive the interstate regularly, sometimes pulling a mower on trailer. Never had trouble getting up to speed. Will hold 80-90mph with no problem.
    tlh178 likes this.
