v6 springs had lift?
Discussion in '5 Lug' started by 5 Lug Slug, Apr 11, 2015.
  1. Apr 11, 2015 at 7:47 AM
    5 Lug Slug
    5 Lug Slug [OP] New Member
    David
    Alabama
    5 Lug Fabtech lift spindles ADL in rear
    3 in Lift 30' tires
    This might have been covered already but I couldnt find so here I am I have a 99 ext cab tacoma 4 cylnder (2.4) and I noticed v6 coils are taller has anyone put the 6 cylinder coils on there 4 cylinder and if so how did they work ?
  2. Apr 16, 2015 at 5:54 AM
    5 Lug Slug
    David
    Alabama
    3 in Lift 30' tires
  3. Jun 19, 2015 at 9:56 AM
    samisim0
    samisim0 Member
    Sam
    2000 5lug
    I am wondering the same thing ... i think as long as they have the same spring rate ... it should be a lift of whatever the springlength is ... but i still havent had confirmation from anyone who truely knows
  4. Jul 3, 2015 at 12:43 AM
    samisim0
    samisim0 Member
    Sam
    2000 5lug
    alright ... i pulled the trigger ... :fenforcer: ... i ordered the v6 5lug springs for my front suspension rebuild... I ordered the Moog version as opposed to the acdelco's mainly because they were 45 bucks ... and the AC Delco's were 75 ... we'll see if anything breaks! ... Ill update this thread with updates
  5. Aug 23, 2015 at 4:22 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    How are they holding up? I'm ready to pull the trigger too but I can't find the safety...
  6. Aug 24, 2015 at 1:54 AM
    samisim0
    samisim0 Member
    Sam
    2000 5lug
    just got them in ... as in test drove it tonight.. its alright, definitely stiffer feeling however that may be due to the new shocks i also installed.
    to be honest the driver side seems to be about an inch lower than the passenger .. and I think it may be the quality of the spring that led to this .. I will post some pics soon and give a better account soon
    I DID buy the cheaper MOOG brand rather than the AC Delco ones for more ... oh .. I see that is in my quote from earlier ..
  7. Aug 24, 2015 at 5:38 PM
    tacomatt602
    Phoenix, AZ
    Hmmm... the only reason I can think of is that the bottom end of that coil isn't butted up against the seat correctly?
    But looking forward to seeing the finished product! :thumbsup:
  8. Aug 26, 2015 at 4:04 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I have a set of TRD springs from a 6 lug and might do this as well depending on how it works out.
  9. Aug 31, 2015 at 10:24 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Any news on how it fits/rides/looks ?
  10. Aug 31, 2015 at 5:59 PM
    tacomatt602
    Phoenix, AZ
    :popcorn:
  11. Aug 31, 2015 at 6:25 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Yo pass some :popcorn:
  12. Sep 6, 2015 at 11:19 PM
    tacomatt602
    Phoenix, AZ
    Do you have a link to those springs? I wanna check em out. I'm so desperate for more lifttt
  13. Sep 6, 2015 at 11:43 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I've seen you on a couple of threads regarding lifts. I hope you don't mind me asking, but if you're so concerned on lift, how come you didn't go with a 6Lug? 5lugs always seem to be a lot shorter.
  14. Sep 7, 2015 at 12:16 AM
    tacomatt602
    Phoenix, AZ
    Lol, fair question. Well long story short, a year ago I was in the market for my first vehicle. Didn't really care either way if it was a car or a truck, but I came across this 5-lug on craigslist and after only being listed for like an hour, I had to check it out. Mind you I had zero knowledge of Tacomas except that there were 4x4s and 2WDs. But you know what they say about Toyotas :p and the price was too good to pass up, so I took it! Turned out to be a good buy, but at the time lift wasn't the first (or 2nd or 3rd) thing on my mind and a 4x4 or Prerunner was waaaaay out of my price range!........Not that I even knew what a Prerunner was .-.
  15. Sep 7, 2015 at 12:23 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Lol. At least you got a nice truck for a first car. Good luck with it.
  16. Sep 7, 2015 at 12:25 AM
    tacomatt602
    Phoenix, AZ
    Thanks man! :cheers:
  17. Sep 7, 2015 at 3:02 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Yes, V6 coils can give you a little lift, but these days unless the coils are off a truck with less than 50k you're not going to see much lift. The only options now are Doetsch lift spindles, some coil spacer lifts and body lifts.
  18. Sep 7, 2015 at 10:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    FWIW...... My husband and I used to work on 1st gens/lifts back in 2000. So....
    The consensus was (at that time) was the V6 coils gave about 1" lift. The OEM coils on the 1st gens are side specific.
    If you feel energetic, I would recommend swapping the coils assemblies from side to side and see if you get different result.
  19. Sep 10, 2015 at 6:32 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    There are no 2nd gen 5 lug lift spindles :'( it's either spacer or go mid travel
  20. Sep 10, 2015 at 6:26 PM
    tacomatt602
    Phoenix, AZ
    Thanks guys! Solid info. :thumbsup: I'm still trying to decide if I should make the switch but that definitely helps.
    Hopefully 2nd gen spacers actually LEVEL out the truck. Spacers for 1st gens only lift the front end 3/4" (aka not high enough).
