V6 valve cover gasket replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Jan 11, 2018.
  1. Jan 12, 2018 at 11:01 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    From a Tacoma guy, he said 3-4 hours labor for everything...
  2. Jan 12, 2018 at 11:02 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    What part of the country are you in?
  3. Jan 12, 2018 at 11:02 AM
    vettehigh
    Jon
    Upstate, NY
    NY
  4. Jan 12, 2018 at 11:04 AM
    rzgkane
    Dammit.
  5. Jan 12, 2018 at 1:12 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Are the cam plugs not a reusable item? Just curious...
  6. Jan 12, 2018 at 2:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're reusable but they recommend changing them because the adhesive sticks really well and is hard to get off, if left alone they leak.
  7. Jan 12, 2018 at 2:14 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  8. Jan 12, 2018 at 4:39 PM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    Not really. The cam plugs have a kind of coating around their circumference. I guess you could just ignore them if they weren't leaking. But replacing them kind of "goes along" with the valve cover gasket job.
    The half moons, on the other hand, are totally reusable; they are solid aluminum pieces that you can remove and re-dope with the packing sealant. I've no idea why folks are replacing those.
  9. Jan 14, 2018 at 6:11 AM
    vettehigh
    Jon
    Upstate, NY
    Regarding the front camshaft seals #90311-38051 (2), isn't that part of the timing belt kit and involved removing the timing cover and coolant? If that's the case, I will hold off on those and just have my guy replace the following for my valve cover job:
    OEM VALVE COVER GASKETS (2) 11213-62020
    OEM SPARK PLUG GROMMETS (6) 11193-70010
    OEM VALVE COVER BOLT SEALS (16) 90210-05007
    OEM CAMSHAFT PLUGS (2) 11188-62010
    TOYOTA FIPG (1) 00295-00103
    OEM ALUMINUM HALF MOONS (4) 11183-62010
    OEM PLENUM GASKETS (2) 17176-62040
  10. Jan 14, 2018 at 6:15 AM
    01GreenTacoma
    The half Moon's are reusable
  11. Jan 14, 2018 at 6:17 AM
    vettehigh
    Jon
    Upstate, NY
    Need to know about the front camshaft seals
  12. Jan 14, 2018 at 6:19 AM
    01GreenTacoma
    You should only be messing with the rear cam plug seals... replace them as they have a rubber coated edge.
  13. Jan 14, 2018 at 6:20 AM
    vettehigh
    Jon
    Upstate, NY
    OK...so I will just hold onto those for future use if needed? Thanks
  14. Jan 16, 2018 at 12:43 PM
    vettehigh
    Jon
    Upstate, NY
    Thank you Gunny...received my parts today. Ordered Fri from Arizona, arrived in NY today. Super fast and thank you again :thumbsup:
    I will send the camshaft seals (90311-38051) back as I will not be needing them. If I'm wrong and I should keep them, please let me know
  15. Jan 17, 2018 at 6:01 AM
    #35
    vettehigh
    Jon
    Upstate, NY
    Double checking, do I need these camshaft seals (90311-38051) also or I will send them send them back today?
  16. Jan 17, 2018 at 7:18 AM
    #36
    Timmah!
    Timmah! Well-Known Member
    TIM
    No, you don't. Replacing the camshaft seals is not part of this repair. It's related to the timing belt job.
    vettehigh[QUOTED][OP] likes this.
  17. Jan 17, 2018 at 7:22 AM
    #37
    Timmah!
    TIM
  18. Jan 17, 2018 at 4:53 PM
    #38
    vettehigh
    Jon
    Upstate, NY
    Book and/or manual that has detailed instructions on this job?
  19. Jan 17, 2018 at 4:55 PM
    #39
    Jackstraw13
    Jackstraw13 Well-Known Member
    2003 Tacoma Doublecab 4X4 TRD
    Wow. Do you have more wonderful spreadsheets like this?
  20. Jan 17, 2018 at 5:07 PM
    #40
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    Unfortunately this is the only Tacoma spreadsheet I currently have. I haven't even done this job myself, nor bought any parts. Turned out 99% of my valve cover seep was fixed by retorquing the cover bolts!
