V8 SWAP IN TACOMA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by diesel30, Jul 3, 2012.
  1. Jan 4, 2017 at 7:44 AM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What he said. ^^^ :D
  2. Jan 4, 2017 at 7:55 AM
    #42
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    He didnt say anything I just saw boobs
    Biscuits, Torspd[QUOTED] and TegoTaco like this.
  3. Jan 4, 2017 at 7:59 AM
    #43
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Just get a gen 1 Tundra. About the same size as a Tacoma and a V8.
  4. Jan 4, 2017 at 8:01 AM
    #44
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Those are badass but getting harder to find.
  5. Jan 4, 2017 at 8:11 AM
    #45
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    ls swap it with some boost
  6. Jan 4, 2017 at 12:44 PM
    #46
    Captain Taco
    Captain Taco RipCity
    Rob
    Portland
    2013 Black Tacoma Sport
    3" Lift, Krank Fuel Wheels, TRD Pro Grill, Curved Roof LED Light Bar
    Awesome!!! Thank you!
  7. Jan 4, 2017 at 1:13 PM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. Jan 4, 2017 at 2:22 PM
    #48
    TacoJonn
    Jon
    Laramie, Wyoming
    They are badass. They look proportional and not all small-penised like the new Tundras that think they are a Mack truck.
  9. Jan 4, 2017 at 3:12 PM
    #49
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if the motor in the FJ bad??!?! no reason to take on the swap if its running fine.
  10. Jan 4, 2017 at 3:20 PM
    #50
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I want to see a diesel in the tundra due to its size and I think there is a better chance of the fullsize getting it than the hilux coming over
  11. Jan 18, 2017 at 1:22 PM
    #51
    JDohms
    JDohms Member
    Jeremiah
    2007 X-runner- 1996 V6 4X4 Manual
    Hey Guys! sorry to Jack this thread, I'm still getting used to these forums, I have a 2007 X-runner (4.0 1GR) with the 6 speed Manual and my cylinders are warped, I bought it knowing it burned oil hoping it was just rings but its much worse, the shop says that because of the block setup boring the cylinders and larger pistons would not be enough to round them. so I'm faced with a challenge. either I get a new short block and rebuild my 4.0, or from what I've read the 4.7 from the Gen 1 tundras should be a close fit. please give me your input and ideas because as of now I've only been able to find theories about the 4.7 but nobody who has done it yet. any other Ideas that wont be insanely expensive and still dependable? Any input would be appreciated, and if I'm not in the right place to ask this question please direct me! thanks!!
  12. Jan 18, 2017 at 1:26 PM
    #52
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    ls swap
  13. Jan 18, 2017 at 1:44 PM
    #53
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    My dad had one, it was a 2000 I believe. Rusted to the ground, frame, body, the whole thing.
    Have to find a california or florida model.
  14. Jan 18, 2017 at 2:02 PM
    #54
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I ran into a guy who put a 427 chevy engine in his little Datson pickup... what a screaming meme it was!! ;)
  15. Jan 18, 2017 at 2:27 PM
    #55
    JDohms
    JDohms Member
    Jeremiah
    DOUBLLD
    the engine itself would be less expensive initally, but getting mounts and trans and ecu and electrical connections would be an absolute nightmare.
  16. Jan 18, 2017 at 2:51 PM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    DoubllD is in the late stages of that swap as we speak. Check his build thread. Plus he works at a performance shop.
    I have a hunch that all of the necessary components are documented. ;)
    DOUBLLD and Lord Helmet like this.
  17. Jan 19, 2017 at 4:12 AM
    #57
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    it can be as easy or as hard as you make it.
  18. Jan 19, 2017 at 6:16 AM
    #58
    JDohms
    JDohms Member
    Jeremiah
    So the answer on wether the trans mission and engine mounts from a Tacoma would match with the 4.7 is no?
  19. Jan 19, 2017 at 6:23 AM
    #59
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    This is how I see it, if you're going to swap in a V8, do the 5.7. :D
  20. Jan 19, 2017 at 6:25 AM
    #60
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    i havent tried it but if they swap i would assume toyota would have that as a option.
