V8 SWAP IN TACOMA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by diesel30, Jul 3, 2012.
  1. Jan 19, 2017 at 7:01 AM
    #61
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Only a matter of time now that the Ram 1500 and F-150 have diesel options. I'm even willing to bet that the Tacoma will soon have a diesel option given that the sales of the 2.8L Duramax Colorado and Canyon have done surprisingly well. There is a growing market out there and Toyota can't completely rest on its laurels in the mid-size segment..
    ecoterragaia likes this.
  2. Jan 19, 2017 at 8:41 AM
    #62
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I hope so, the RD has been complete for some time now with toyotas diesels. Damn near every hilux overseas has 2 diesel options. Hell make a smaller version of the 7.6 from the Hino and drop in a tundra. Great torque and are pretty damn quick compared to other trucks its size.
  3. Jan 19, 2017 at 8:42 AM
    #63
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Definitely would be more interested in a diesel swap but the likelihood of that happening to my truck is nigh ZERO +/- 0.000001%.
    Now I need to search the forum to see who has done it... :cool:
  4. Jan 19, 2017 at 8:58 AM
    #64
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @anothernord has.
  5. Jan 19, 2017 at 2:48 PM
    #65
    JDohms
    JDohms Member
    Jeremiah
    2007 X-runner- 1996 V6 4X4 Manual
    I figured because the 4.7 from the 4runner v8 is the same as the one from the tundra it would have similar mounts and the trans should also be the same?
  6. Jan 19, 2017 at 3:02 PM
    #66
    lose_money
    lose_money Well-Known Member
    Dean
    2016 MGM TRD OR 4x4 MT
    King 2.5, Icon AAL, SCS Ray10 16x8
    Not worth it if your engine is perfectly fine. If it's shot then it possibly makes sense for a fun project
    TegoTaco likes this.
  7. Jan 19, 2017 at 6:51 PM
    #67
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Funny, I was thinking that since the 4.0 appeared in the Tundra, the Tundra V8 might fit in the Taco :)
  8. Jan 19, 2017 at 8:17 PM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Same as the 4Runner.
  9. Jan 20, 2017 at 2:06 PM
    #69
    JDohms
    JDohms Member
    Jeremiah
    My motor is shot. cylinders are warped, just trying to see my options
  10. Jan 20, 2017 at 2:15 PM
    #70
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The Ram 1500 diesel isn't working out to well for Chrysler. http://www.reuters.com/article/us-fiatchrysler-emissions-idUSKBN14W29S
  11. Jan 20, 2017 at 2:25 PM
    #71
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How badly warped? Something a torque plate and slight boring could fix, or is that cost and time prohibitive versus a drop in 4.7 w/OEM ecu?
  12. Jan 20, 2017 at 3:42 PM
    #72
    Tikabear
    Tikabear Member
    Memphis, TN
    2010 White V6 Double Cab Prerunner TRD Sport
    I'd like to see Toyota offer a V8 in a Tacoma. I just got a used one with a V6 though and am enjoying the power difference over the 4.
  13. Jan 20, 2017 at 5:06 PM
    #73
    JDohms
    JDohms Member
    Jeremiah
    Apparently with the 4.0 you can't bore it because of the way the sleeves are, a friend said that it would need to be resleaved, but most people recommend getting a whole new short block, which I would hate to do....
  14. Jan 20, 2017 at 7:45 PM
    #74
    MadRiverTaco
    Brenden
    Waterbury, VT
  15. Jan 20, 2017 at 7:53 PM
    #75
    Pigpen
    Dan
    Northwest Montana
    I have great difficulty reading anything you type, yet I'm impressed by every post.
    TegoTaco[QUOTED] likes this.
  16. Jan 21, 2017 at 10:17 AM
    #76
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It can be bored. Been there, done that. You just don't want to go extensive like .030" over. Not enough nicasil lining for that.
    Getting a long block is easier than a short block. Picked those up from 1200 - 1800.
  17. Jan 21, 2017 at 10:49 AM
    #77
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    :D
    Pigpen[QUOTED] likes this.
  18. Jan 21, 2017 at 11:28 AM
    #78
    JDohms
    JDohms Member
    Jeremiah
    Great advice! what is the max that you could safely bore you think?
  19. Jan 21, 2017 at 11:38 AM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    LC Engineering was doing them to near .020" over.
    I'd only go as much over as necessary though. With a torque plate.
  20. Jan 23, 2017 at 9:01 AM
    #80
    anothernord
    anothernord Well-Known Member
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Yep, I swapped a 1KZ into my 2001 Tacoma. It's sweet.
    Torspd and orezona[QUOTED] like this.
