v8 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by v8taco671, Apr 2, 2017.
  1. Sep 25, 2017 at 7:17 AM
    #221
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Not sure how I have missed this awesomeness for the last few months, but holy ducking chit. So cool.
    I would also like to get in line for info on mounts and crossmember.
  2. Sep 27, 2017 at 7:41 PM
    #222
    v8taco671
    v8taco671 [OP] Well-Known Member
    Well cancel those plans on pulling the motor,after doing measurements and taking cooling into consideration the 6bt cummins that I had lined up isn't gonna work so back yo working on the 5.7.... Message me if anyone is interested in mounts I can make some more
    MY50cal likes this.
  3. Sep 28, 2017 at 2:26 AM
    #223
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Can’t wait for the 5.7 swap!
    Plain Jane Taco likes this.
  4. May 31, 2018 at 12:19 AM
    #224
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    :tumbleweed:
    OP,
    Are you using the stock front diff? Does the oil sump fit over it?
  5. May 31, 2018 at 12:57 AM
    #225
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Somehow I havent subbed this thread yet sooo....
    SUB!! :cheers:
    Any notes on the gauge cluster wiring? Hoping to keep mine as clean OEMish as possible. Still havent started my swap, I've been down since Nov, bought a donor (salvage) 4.7 '03 4runner in Dec. Told the wifey I wouldn't start the project until we move to a bigger house for our growing family.
  6. May 31, 2018 at 4:47 AM
    #226
    v8taco671
    Stock front diff and yes the 4runner upper and lower rear sump oil pans fit perfect around the diff
    tacoburrito and TireFire[QUOTED] like this.
  7. May 31, 2018 at 4:48 AM
    #227
    v8taco671
    Congrats on the new addition to your family. Everything on my cluster works except for the temperature gauge
  8. Jun 4, 2018 at 2:54 PM
    #228
    Tbell18
    Tbell18 Well-Known Member
    iowa
    2009 Tacoma Trd Sport dclb
    see build...but not a whole lot
    what would be different for the swap if I used an 06 4runner. Does VVTi change anything with it.
  9. Jun 4, 2018 at 3:32 PM
    #229
    TireFire
    Olympic Peninsula
    Transmission & ECU for the big ticket items
  10. Jun 4, 2018 at 3:34 PM
    #230
    Tbell18
    iowa
    Doesn't the 4runner use the same a750f that come in tacomas?
  11. Jun 4, 2018 at 3:35 PM
    #231
    TireFire
    Olympic Peninsula
    Yes, but the older pre vvti engines used a different trans
  12. Jun 4, 2018 at 3:36 PM
    #232
    Tbell18
    iowa
    So if i get a vvti then i wouldn't have to worry about trans?
  13. Jun 4, 2018 at 3:43 PM
    #233
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Interested as well. Subd
  14. Jun 4, 2018 at 3:43 PM
    #234
    TireFire
    Olympic Peninsula
    That's a loaded statement. The trans will be the same as in your V6 Tacoma but the bell housing is different and you may have to move the transmission forward or backwards depending on how you fit the motor in the engine bay. What I gathered is that You can't bolt it in using the existing frame perches and 4Runner motor mounts because the oil pan will interfere with the front diff (ADD tube)
    Tbell18[QUOTED] likes this.
  15. Jun 4, 2018 at 3:50 PM
    #235
    Bebop
    Nick
    Would a DB 6inch lift kit help with this? This is my current setup. Would love a v8 swap with a supercharger.
  16. Jun 4, 2018 at 4:27 PM
    #236
    beertimecontinuum
    Everett
    I'm doing a non VVT 4.7 and planning on wiring to my (VVT?) A750F from the tacoma. Still havent started or got a definite answer on what the actual difference is. May not find out until I get started on it lol. I have the entire donor '03 4runner tho so I may find I just use the ECU and wiring harness and it works with the 4runner tranny and just use the Taco transfer case.
    Skootter14 likes this.
  17. Jun 4, 2018 at 4:38 PM
    #237
    TireFire
    Olympic Peninsula
    No idea, sorry
  18. Jun 4, 2018 at 8:26 PM
    #238
    v8taco671
    Bell housing is 100% different and possibly the torque converter
  19. Jun 4, 2018 at 8:27 PM
    #239
    v8taco671
    Won't work. The none vvti computer will not know how to handle the A750 trans (4speed vs 5speed) among other factors
  20. Jun 4, 2018 at 8:28 PM
    #240
    v8taco671
    Wiring and immobilizer would be the biggest difference
    beertimecontinuum likes this.
