V8 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joshhhsyayyyy, Nov 27, 2020.
  1. Nov 27, 2020 at 2:51 PM
    Joshhhsyayyyy
    Joshhhsyayyyy [OP] Member
    Hey guys, I own a 3rd gen tacoma with the I4 engine. With larger wheels and tires it struggles to get up to speed and has low fuel economy. I also own a 2007 sequoia with the 4.7 V8 engine and was wondering if anyone had an opinion about swapping them. Either way the sequoia will soon be parted out.
    Response would be greatly appreciated. Thanks.
    Kolohe and CocaineAndCreatine like this.
  2. Nov 27, 2020 at 2:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Nov 27, 2020 at 2:54 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Where are you located? Look up your smog laws. If done right, why not? Gonna be a good amount of work and I would bet some custom fabrication. Just think it through.
    it would probably be cheaper to just swap AND supercharge a v6 3rd gen....but if you are looking for something different, could be fun
    I’d be in for a good build thread
  4. Nov 27, 2020 at 2:54 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    You should absolutely do this.
  5. Nov 27, 2020 at 2:55 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  6. Nov 27, 2020 at 2:58 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    'nuff said above.
    Joshhhsyayyyy[OP] likes this.
  7. Nov 27, 2020 at 3:03 PM
    DeeKay20
    DeeKay20 Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
  8. Nov 27, 2020 at 3:04 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    LSx...:thumbsup::thumbsup:
  9. Nov 27, 2020 at 3:23 PM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Swapping a V8 into a 3rd gen wouldn’t be all that difficult. Swapping a V8 into a 3rd gen and retaining all the built in supporting systems is another story. As a project it could be fun, if it has to be done in a short time frame because you depend on it, it would probably suck balls. Everything depends on how you view the roadblocks along the way. I’d probably just sell it and buy a new Reg cab, short bed F150 with a 5.0 and call it a day.
    Chew likes this.
  10. Nov 27, 2020 at 3:31 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Go for it! You'll leave all the blower fan boys in the dust!
  11. Nov 27, 2020 at 3:38 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    drop in a second I4 That's the ticket!
  12. Nov 27, 2020 at 3:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    While you're at it, might as well go 40s and tons :burp:
    @jbrandt
    9th likes this.
  13. Nov 27, 2020 at 3:44 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do it
    shakerhood and BillsSR5 like this.
  14. Nov 27, 2020 at 3:51 PM
    sshadow69
    sshadow69 Well-Known Member
    S
    Dallas, TX
    X-Pre-Runner
    X-Runner rolling chassis swap
    I would think the V8 swap from your sequoia should be on the easier side, since you have a complete vehicle to get the whole engine, accessories, wiring harness, and ECU but there will be some custom work that will need to be addressed... motor mounts... front springs to hold extra engine weight... rear end and gearing and I am sure a few other things that I am not thinking about. Good luck
  15. Nov 27, 2020 at 4:03 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I don't think so, Tim...
    shakerhood likes this.
  16. Nov 27, 2020 at 4:03 PM
    sshadow69
    S
    Dallas, TX
    X-Pre-Runner
    Keep in mind that bigger wheels and tires change up the gearing in that Gen 3 Taco... that really needs to be offset or changed to work better with your current power plant... even with more power from the larger engine you will still probably be losing power through wrong gearing. Yes the bigger wheels and tires weight more but the gearing would seem to be the biggest problem. The weight of the larger rims and wheels also puts a great strain on your braking system too and will probably start warping the front rotors... just a few things to think about
  17. Nov 27, 2020 at 4:12 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    TacoManOne and LunarRock_Pro like this.
  18. Nov 27, 2020 at 4:15 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    I love Friday threads
  19. Nov 27, 2020 at 4:40 PM
    Buttermilker
    Buttermilker Well-Known Member
    Danny
    Bishop, CA
    '16 ACOR
    Sierra pinstriping Eibach stage 1, 3 leaf AAL
    Just do it. Watrrya, chikin?
  20. Nov 27, 2020 at 4:42 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    I wouldn’t swap it into a third gen. Makes more sense to buy a first or 2nd gen with less electrical crap to deal with. My $0.02 after I’ve helped with a swap in a new(er) truck
    Lawfarin likes this.
