v8 transmission in a tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROMYER8313, Sep 15, 2022.
  1. Sep 19, 2022 at 4:00 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    My reply will not help the op with his issue. Years ago, I installed a similar cooler for my transmission.
    Knowing that it is possible to have the radiator portion fail, leaking transmission fluid into the cooling system, and apparently letting coolant into the transmission, I set mine up without connecting to the radiator. Scangage is set up to monitor transmission pan fluid temp. Normal South Florida driving temp stays around 160. Pretty sure stock, with the tow package trans cooler ran about 180/185.
    I did utilize the oem tow package trans cooler and run the power steering fluid thru that smaller cooler.
    Ultimately, the goal was not connecting the transmission fluid hoses to the radiator.
