Vacuum leak or transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverTaco2012, Aug 31, 2015.
  1. Aug 31, 2015 at 6:40 AM
    SilverTaco2012
    SilverTaco2012 [OP] New Member
    Johndman
    6cyl Pre-Runner 2012
    There is a hesitation in the gear shifting when driving around town. If I'm driving at 35+ mph and tap the brakes, I can feel it shift into neutral. Stepping on the gas, the motor revs up and then shifts into gear jarring the truck.
    Weird thing is when I slow to a complete stop say at a stoplight, I can feel it shift into neutral as soon as I tap and hold the brakes. I can count to 3 and feel it shift into gear.
    Bringing it by the dealership in a couple of days. Here are some details of the truck;
    2012 Automatic
    6 cylinder
    Pre-runner
    Anyone else have these issues?
  2. Aug 31, 2015 at 7:09 AM
    gearcruncher
    Canadain bumper technician
    Considering your transmission is completely computer controlled , start by scanning for codes and post back what you find ,
    A quality scanner should be used if you can . Autozone scans for free I believe.
    I am fairly certain you have the 750 series trans with no filler tube -Got some diagnostics at this link if you are interested
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
  3. Aug 31, 2015 at 7:50 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    6yr 50k mi power train, if you are under that take it to the dealer and have them check the fluid level.
  4. Aug 31, 2015 at 8:02 AM
    SilverTaco2012
    Johndman
    Thanks guys. I will bring it by O'Reilly's (on my way home) and I'm pretty sure they can check the codes for free as well. I set up the appointment with the stealership and will bring it by there in a couple of days. It's out of warranty because it has 70K miles. :(
  5. Aug 31, 2015 at 8:13 AM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    if you are concerned about a vacuum leak, chances are you will get a lean code. but if you haven't yet, get a scan tool and look at your long term fuel trims. if they re way high, they are compensating for air the ECM isn't seeing. hope that helps.
  6. Aug 31, 2015 at 5:55 PM
    SilverTaco2012
    Johndman
    Update - On my way home, the check engine light came on as well as the traction control light. The engine sounded like it was stuck in 3rd gear and the RPM's were sitting around 3800 at 65mph.
    I drove it straight to the dealership.... I'm thinking they are going to hit me with a new transmission charge.
    2012 with 70K miles.
  7. Aug 31, 2015 at 9:11 PM
    DEMikey
    mikey
    delaware
    2013 red taco
    if its dealer serviced id be raising cain...... make them eat parts or labor. if you are a good customer they sometimes work with you.
