Vacuum line on the back of the air intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by n0madoma, Mar 7, 2024.
  1. Mar 7, 2024 at 5:49 AM
    n0madoma
    n0madoma [OP] New Member
    Started installing new vvt solenoids last night in hopes of fixing a shuddering issue. When I removed the air intake cleaner (not sure what it's properly called, but its the big plastic box connected to the air filter housing) the vacuum line on the back snapped off where it connects to the box. The nipple is broken off inside the hose. I assume this will possibly cause some issues with performance so I've ordered a new box, but wondering if anyone else has any experience with this?
  2. Mar 7, 2024 at 6:02 AM
    Bishop84
    Bishop84 Well-Known Member
    Fuel pressure regulator, just take it easy until it’s repaired, it only changes pressure 4psi or so if I recall. You’ll be fine to drive it as long as you plug the hole off, put a small screw in the hole
    HondaGM likes this.
  3. Mar 7, 2024 at 6:06 AM
    n0madoma
    Awesome, thanks for the info!
  4. Mar 7, 2024 at 8:20 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I wonder if this is something you could fix with liberal amounts of high-strength epoxy? First to bond the fractured surfaces, then generous extra epoxy around the collar/base to help add some strain-relief around the joint.
  5. Mar 7, 2024 at 12:45 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Depending on what it looks like, he possibly could have drilled it out and tapped the hole with an NPT thread tap and installed an NPT barb with some permatex sealant.
    GilbertOz[QUOTED] likes this.
  6. Mar 7, 2024 at 12:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    They sell bulkhead fitting pipe nipples like this: https://www.amazon.com/GASHER-Thru-Bulk-Bulkhead-Fitting-Straight/dp/B0B6YYVD95 (measure the hose diameter first). Just clean up the hole on the airbox and install this with some RTV sealant.
  7. Mar 7, 2024 at 1:06 PM
    GilbertOz
    GilbertOz Driver
    CA
    Yes. This is The Way. A much better idea than trying to just epoxy the original plastic nipple back in place.
    In an extreme case one could even drill out a round hole to remove a jagged cracked area, then epoxy a new stiff piece of plastic over the clean hole, and tap a hole + put an NPT barb in the added-on plastic. Taking care to be sure there are no plastic shavings or debris left inside the intake housing when done.
    Revelations[QUOTED] likes this.
  8. Mar 7, 2024 at 2:21 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Id probably go the way of a hose barb bulkhead fitting. Or a rubber grommet of the right ID that would friction fit on the vacuum line well and call it a day.
