Vacuum port on 3rz intake for ps pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by gobraphil, Oct 30, 2023.
  1. Oct 30, 2023 at 2:15 PM
    gobraphil
    gobraphil [OP] Well-Known Member
    I have a non threaded hole on my 99 intake presumably where the vacuum line for the power steering pressure valve should go. Any idea what the fitting looks like?
    I could plug it but what are my options there as well?
  2. Oct 30, 2023 at 8:03 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    here's a '98....
    That steering switch just taps into the vacuum anywhere on each side of the butterfly.....
  3. Oct 30, 2023 at 8:09 PM
    gobraphil
    Thanks!
    What does that fitting look like? That port on my intake is not threaded.
  4. Oct 30, 2023 at 8:38 PM
    O'Silver_Taco
    MD
    I think there is like 2 or 3 different plugs/holes there...
    the newer with electronic switch just plug those....
    your talking about 8psi.....so not much.....to seal it...
    I've got that upper plenum I pulled off an old 4 banger taco 5 years ago...
    tomorrow I'll go look thru the junk pile and see if I can find that....
  5. Nov 1, 2023 at 5:29 PM
    O'Silver_Taco
    MD
    Well I looked at mine....and that tube appears to be pressed in....
    There's a plug below that I've seen others use.
    IF so the high one should be easy to plug since it only a few lbs of vacuum..
    and find something to thread in the lower....
  6. Nov 2, 2023 at 6:12 AM
    gobraphil
    Appreciate it!
