Vacuum pressure limits
Discussion in 'Technical Chat' started by Elkhound, Mar 13, 2013.
  1. Mar 13, 2013 at 4:36 AM
    Elkhound
    Elkhound [OP] Member
    Kurt
    New Hampshire
    Tacoma 4x4
    I'm about to do a complete brake job including replacing the rear wheel cylinders on my 06 Tacoma. I plan on flushing the brake fluid as well. Does anyone know what the maximum vacuum pressure I can use on the master cylinder during this process?:confused:
  2. Mar 13, 2013 at 4:42 AM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    If you are using a powered flushing machine connected to the master cylinder reservoir, I wouldn't go much more than 10psi of positive pressure. If you are talking about the hand held vacuum bleeder connected to each caliper, I don't think you will be able to create enough vacuum to hurt anything. Just keep the reservoir full.
  3. Mar 13, 2013 at 4:57 AM
    Elkhound
    Kurt
    New Hampshire
    Tacoma 4x4
    Thanks Vstrom30. I'm using a universal bleeder from Motive that attaches to the master cylinder.
