Vacuum pump noise.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jws6295, Apr 23, 2021.
  1. Apr 23, 2021 at 4:20 AM
    jws6295
    jws6295 [OP] Well-Known Member
    Central PA
    2016 SR5 double cab long bed
    Anyone have a video of the vacuum pump knock? Curious to what it actually sounds like vs “normal operation.” I haven’t seen to many people on here that have had them replaced, they’re just being told the noisy engines are normal.
  2. Apr 23, 2021 at 4:48 AM
    rep_techy
    rep_techy New Member
    Jeremy
    2017 Magnetic Grey Metallic Tacoma SR5
    K&N Air filter, VSV rubber washer mod
    Mine sounded like a helicopter/double knee slapper sound from drivers seat at idle with radio and fan off, if you pumped brakes 4 times it would almost go away completely. I showed dealer brake pump temp fix process and the vacuum pump knocking tsb and they replaced it under warranty.
    jws6295[OP] likes this.
  3. Apr 23, 2021 at 9:56 AM
    jws6295
    Central PA
    Gotcha! I do get a clanking/slapper noise here and there. Did yours quiet up?
  4. Apr 23, 2021 at 10:17 AM
    rep_techy
    Jeremy
    Yeah, quite a bit. Now just hear the dieselish injector sound.
  5. Apr 23, 2021 at 5:47 PM
    jws6295
    Central PA
    Good deal! Might have to look into doing the vacuum pump. Might tackle it myself!
