Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Dec 27, 2019 at 9:55 AM
    #2601
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    Why not just stick a sheet of stainless steel onto whatever aluminum surface you want it to stick to?
  2. Dec 27, 2019 at 12:43 PM
    #2602
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Not all stainless is magnetic, and the stuff that is isn’t as good as steel. But some PC’d or painted steel strips might work.
  3. Dec 27, 2019 at 2:23 PM
    #2603
    kalieaire
    Santa Clara County
  4. Dec 27, 2019 at 5:42 PM
    #2604
    venisontaco
    venisontaco Well-Known Member
    Hey Drifter people, My camper is coming around March and I want to get my truck prepared before I pick it up. It's a 2015 double cab. I've seen various mods on this thread, but what is required?
    I've upgraded my suspension. I have Bilstein 6112 up front and 5100 in back with HD OME Dakar springs. If I could do it over again I would get Deaver and not OME.
    Do I need a low profile antenna cover for clearance? Do I need different bed side covers?
    Let me know what you think. Thanks
  5. Dec 27, 2019 at 6:00 PM
    #2605
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Personally, I vote for the Bullet Cover Mod as the first thing to do ( that is of course, if you have a 2nd gen taco), but I have a personal interest in that suggestion.
    :cool:
    In all seriousness, what’s the year/make/model of your truck? There are slight differences that make your options vary. One thing I suggest is to get the rear suspension in order right away.
    evaluate your intended use of the truck and plan your rear suspension upgrade accordingly. What some would deem necessary (remote reservoir Extended Length Kings with Hydro Bumps for me please-not what is actually on my truck) may be completely a waste of money to others because of intended use.
    Seriously. Sit down and start drawing diagrams. See where all that leads you.
    oh, and try and adhere to “buy once, cry once” rule. Otherwise, you’ll cry a lot more...
  6. Dec 27, 2019 at 6:17 PM
    #2606
    venisontaco
    @Anderson Thanks for the reply. I edited my orginal post. It's a 2nd gen and I have upgraded my suspension, but I wish I would have cried once and got Deavers! I'll check out the bullet cover.
    Anderson likes this.
  7. Dec 27, 2019 at 6:33 PM
    #2607
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I would recommend replacing the factory plastic bedrail caps with metal. The plastic ones will eventually “walk out” on you over time and use. Mine have on both sides. It forces me to keep a good eye on my bed cap clamps.
    One other mod I genuinely like is the tailgate inner replacement panel. The factory plastic one is ribbed(but definitely not pleasurable), but that makes it a pain to use when cooking on or getting in and out of the truck. A smooth, metal replacement panel makes all of that nonsense go away.
    I’m sure there are more little bits and bobs but it’s been a long day and my daughter keeps trying to get my attention.
    SenatorBlutarsky likes this.
  8. Dec 27, 2019 at 9:02 PM
    #2608
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    "Required" but you can do later : Leaf springs
    Things you should probably beforehand, and is a pain in the ass once the drifter is on : bed rail caps
    SliMbo4.0 and Anderson like this.
  9. Dec 27, 2019 at 9:18 PM
    #2609
    venisontaco
    @SenatorBlutarsky What brands are people running? I found Voodoo in a search, but damn they're expensive! Do you think the antenna delete is required?
  10. Dec 27, 2019 at 9:43 PM
    #2610
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    Contact Phil, Vagabond can supply you with bed rail caps
    Bentrodder and rob1208 like this.
  11. Dec 27, 2019 at 10:39 PM
    #2611
    SenatorBlutarsky
    Utah
    What @tyfoon11 said.
    They are expensive, which is why I didn't do it initially. I'm now wishing I had just bit the bullet cause I know it's something I'll have to do eventually.
    tyfoon11 likes this.
  12. Dec 28, 2019 at 7:18 AM
    #2612
    MapJunkie
    MapJunkie Well-Known Member
    Washington
    2015 Tacoma OffRoad w/ Drifter
    My understanding is that the Drifter will clear the sharkfin on a 2nd gen if you leave the stock bedrail caps on. However, with the KB Voodoo caps, the camper is lowered another 3/4”. I think one of the early adopters found out that the camper can flex on a jump or whoop and hit the Sharkfin - denting the roof. So, required if you swap out the bedrail caps.
    That is why I swapped my sharkfin out, yesterday. BTW, the job is a lot more work on an Access Cab. I will post some pictures on @Anderson’s sharkfin delete thread.
    SliMbo4.0, Bentrodder, ETAV8R and 2 others like this.
  13. Dec 28, 2019 at 7:27 PM
    #2613
    SenatorBlutarsky
    Utah
    Oh, I know nothing about the sharkfin since my 2013 doesn't have one...
    Wackyhacky, ETAV8R and Anderson like this.
  14. Dec 28, 2019 at 8:38 PM
    #2614
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    Every truck is different
    @joeydurango has Relentless bed caps and had about a quarter inch clearance between shark fin and camper... had to take a hacksaw to it for clearance
    I have the same setup and have over a half inch clearance. Pulled a bit of my usual dumassery on the trail with no contact (stock roof rack on the other hand took a beating)
    ymmv
  15. Dec 28, 2019 at 8:49 PM
    #2615
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Relentless caps here. I had to take a hacksaw to my fin as well.
  16. Dec 28, 2019 at 9:39 PM
    #2616
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    I liked the post-install hacksaw-n'-silicone approach... nothing like taking a saw to your perfectly good 2015 Tacoma while everyone watches in trepidatious anticipation of some sort of mini disaster. :eek::D All's well that ends well, ended up with a decently straight cut. Going to clean up the cut with a file, level off the silicone, and leave it be. Had I been certain of that outcome ahead of time, I might have opted for Anderson's bullet cover.
    Other truck mods pertinent to the Drifter: Relentless bed rail caps. Rago Fab bed stiffeners. 5100's with stock coils leveled to 1.75". Custom Alcan springs in the rear with OME shocks - the suspension setup was for my FWC, and I only had them built for 900lbs over. Used them with airbags and Daystar cradles with the 975lb FWC and it worked well. This setup seems even better with my ~400lb Drifter and a bed full of gear (at least a few hundred pounds). Will see how the buildout goes and might even remove the airbags for better ride quality.
    tyfoon11 and JasonLee like this.
  17. Dec 28, 2019 at 10:02 PM
    #2617
    MapJunkie
    Washington
    I just happen to have a sharkfin, if you need a do-over!
  18. Dec 29, 2019 at 8:07 AM
    #2618
    Mr. Nobody
    Mr. Nobody Just a nobody
    San Diego, CA
    2017 Tacoma TRD Off-Road
    Lots of good second gen info, any third gen owners had issues with the full length Prinsu rack making contact? I know the Prinsu fits under it, just wondering if anyone has had it contact at all when getting after it offroad.
    I've found a used Drifter and we're scheduled to pick up in mid January. Pretty excited. We've been planning this for a while and I think we've got the truck prepped already for the install.
    Factory bed rail caps
    Bed corners stuffed with butyl rubber
    Rago bed stiffeners
    BP-51 kit all around with Dakar HD's +1 leaf
    JasonLee and tacomgee like this.
  19. Dec 29, 2019 at 11:15 AM
    #2619
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    FYI- I have a bed rug and the side insulation panels as well.
    We did two hot water nalgenes last night in the 20s and it was more than warm enough to sleep. The dew turned into frost inside the tent, so we pulled down the comforter, closed up and drove a few miles to the hot spring and then opened it up, opened all windows and let it dry out in the sun. I’m thinking of maybe a spare tarp or something to lay over the bedding when I need to close up with it wet inside.
    Microfiber towels work pretty well to wipe down/wring out to speed up the drying.
    i need to swing by Durango and do some brainstorming with you on some Drifter products.
  20. Dec 29, 2019 at 4:56 PM
    #2620
    joeydurango
    SW Colorado
    Let me know! :)
