Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Mar 5, 2020 at 6:37 PM
    #3021
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    Hell yeah! My focus will be on baby "mods" here soon to get the back set up for our little Cowgirl. I removed the driver side rear seat and made an 8020 platform there that utilizes the factory seat mounts that holds our fridge most of the time and it can still tilt forward. we plan to put our car seat on the passenger side anyways so the platform will most likely stay even if the fridge is in the back. We tend to only run the fridge in the back during winter tho.
    Nice Work! the soft white is really nice on the eyes when you are spending a lot of time back there. Did you use the adhesive backing that came on the light strips? I don't think that adhesive is very robust, over time ours peeled off so I removed it and replaced it with some .250 3M VHB and haven't had a problem since. You can also use that lighting underneath the hidden wire track for some low light options :thumbsup:
  2. Mar 5, 2020 at 7:47 PM
    #3022
    xplorn
    xplorn Well-Known Member
    Ken
    Oregon, USA
    '10 DCSB OR
    I left it on (had 3M labeling on it), but using VHB might work better long term. We'll see how this holds up adhering to the mounting tape I used and redo if needed.
    Eazy.E[QUOTED] likes this.
  3. Mar 5, 2020 at 8:26 PM
    #3023
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    Don't know how tall you are, but there's no way I could fit the car seat behind me when I'm driving. I'm not even comfortable in the passenger seat with the car seat behind me. Those suckers take up a lot of space! We move ours to the middle on long trips so both front passengers can have more leg room.
  4. Mar 6, 2020 at 10:35 AM
    #3024
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
  5. Mar 7, 2020 at 4:46 PM
    #3025
    Alexk3303
    Alexk3303 Well-Known Member
    Alex
    2015 White Tacoma TRD
    Stock
    Thanks! I can't get over how clean it looks!
    cwhet10[QUOTED] likes this.
  6. Mar 9, 2020 at 5:50 PM
    #3026
    9thhope
    9thhope Well-Known Member
    Los Angeles
    2018 Cement DCSB TRD Off Road
    Hey guys I just got my camper installed last weekend, question v/ rear springs. I am currently on regular medium dakars and they're definitely inadequate as they're pretty much flat and starting to invert. I'm not planning on running a rear swingout and hoping to keep my camper pretty light with maybe just some pull out drawers and a fridge later on. Would deaver stage2 springs rated at rated for 400-600lbs be enough? The camper I got has the front runner doors and an awning so I'm guessing its pushing 480-500lbs.
    Anderson likes this.
  7. Mar 9, 2020 at 5:53 PM
    #3027
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Deaver U402 Stage 3 or custom. I had AllPoo expos and they flattened out instantly. Actually, they went straight to inverse. I run custom rates. Super stoked on them. Caveat emptor being that I have a full bed build out, awnings, Frontrunner doors, rear dual swingout, water tank, etc...
    9thhope[QUOTED] likes this.
  8. Mar 9, 2020 at 6:24 PM
    #3028
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    the awning is <50lbs and the two doors are ~25+ a piece. So ~400+~100 and you're at 500. Those dakars are meant to lift your truck w/ no real weight in the back (just a camper shell for example), not a constant load. I would consider stage 3 minimum. But even then those would only take into account the camper itself. If you're planning on building out the back, to any degree, they won't last long.
    You can consider air bags with the Stage 3s, that's certainly an option for additional load carrying capability. That would give you some flexibility, but they'll become a maintenance item long term where you'll have to replace them with some level of requency.
    9thhope likes this.
  9. Mar 9, 2020 at 7:43 PM
    #3029
    MountainBikeRdr
    MountainBikeRdr Well-Known Member
    2017 Inferno Tacoma DCSB OR
    I have Deaver stage 2, alucab shadow awn, one front runner door, and no rear swing out. My interior isn’t built and the stage 2s are holding up great.
    One thing to keep in mind is future plans with the Drifter. If you ever consider building out or going with a swing out, I’d go stage 3. The Deaver stage 2 springs are a thinner composition than the stage 3. If you’re set-up gets heavier, Deaver can adjust the stage 3 pack to the weight. As far as I know, the thinner leaves on the stage 2 cannot be adjusted beyond their set capacity.
  10. Mar 9, 2020 at 10:37 PM
    #3030
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    Is anyone running the Archive Garage hammer Hangers with Deavers? I was thinking about running this setup when I pull these crappy Dakars this summer.
  11. Mar 9, 2020 at 11:02 PM
    #3031
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I’m running the BAMF rear shackle hanger replacements with my Deavers. Some trimming was required. But I enjoy factory geometry on my shackle hangers.
    I don’t know about the “hammer hangers” being any different. But, the fact that they(hammer hangers) alter factory geometry might be a cause for concern for some people. Maybe someone else can chime in.
    rob1208 and SliMbo4.0[QUOTED] like this.
  12. Mar 10, 2020 at 2:50 AM
    #3032
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    I've been running a Deaver U402 custom pack and love them. has handled all the extra weight of the drifter and stuff in the bed flawlessly so far.
    As far as camper weight, you're pretty spot on. My drifter powder coated with fan, 2 fr doors, sliding front window, and a 6ft awning was 485lbs (weight truck before and after installation at the scales down the road).
    tyfoon11, Anderson and SliMbo4.0 like this.
  13. Mar 10, 2020 at 3:16 AM
    #3033
    SliMbo4.0
    Rick
    To me it looks like the BAMF and Archive hangers are essentially the same, Archive just has some other options. I have not read anything to say that they are changing the factory geometry.
    You're just running the shackle, correct? Not this...https://bayareametalfab.3dcartstores.com/2005-to-2020-Tacoma-HD-shackle-hanger_p_82.html ...combined with the shackle?
  14. Mar 10, 2020 at 5:18 AM
    #3034
    kceastsparks
    kceastsparks Fkn Kyle
    Kyle
    Sparks, NV
    2015 DCSB, SOLD 2010 DCLB, RIP 2017 DCSB
    Anderson, Twizted, tacomgee and 3 others like this.
  15. Mar 10, 2020 at 5:41 AM
    #3035
    SliMbo4.0
    Rick
  16. Mar 10, 2020 at 7:19 AM
    #3036
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I’m running both the shackle and the hanger replacement. Someone beat me to an explanation it looks like.
    SliMbo4.0[QUOTED] likes this.
  17. Mar 10, 2020 at 8:40 AM
    #3037
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    I have the same issue right now. I'm taking delivery of my Drifter within the next 2 months. I have medium OME dakars now. I am keeping my build relatively light weight. I'm a minimalist when I camp and venture out, I only bring the stuff I need plus tools etc. That said I will go the cheaper route and buy the add a leaf from OME and make them the 'heavy' version and install it prior to taking delivery of the Drifter. I do not really feel the need to spend $1k on a new leaf pack from Deaver. I'll see how the 'heavy' Dakar's do when I convert them.
    If down the road I need a more beefier leaf pack i'll sell the Dakars and buy Deavers. I've been happy with the Dakars so far, I spent a good amount of prep work to keep them quiet. 1 year later, they do not squeak at all.
  18. Mar 11, 2020 at 6:25 AM
    #3038
    huruta
    huruta Well-Known Member
    Christy
    Seattle
    2015 DCLB TRD Sport
    Drifter....ARRIVED!
    I’m going to butcher the details, but I think we have a hilux leaf springs with ome kit. The Mule is SEattle did them, about a year ago. They have held up fine so far and were a lot less expensive than deavers. Seems deavers are preferred here, but this is an option. I’d search the drifter thread for me and you should find the correct details.
  19. Mar 11, 2020 at 9:59 AM
    #3039
    4wdExplorer
    Orange County, CA
    Looking into this on the ARB Australia Site.
    The EK406C2 OME kit is good for 880 lbs to 1300 lbs of weight in the bed.
    The EK406C4 OME kit is for excess of 1300 lbs weight.
    https://www.arb.com.au/toyota-hilux-2011-2015/old-man-emu-4x4-suspension/
    This is for the suspension kit. Trying to find individual part numbers for the leaf pack.
  20. Mar 11, 2020 at 10:08 AM
    #3040
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    I have Alcan custom leaf springs built for 900lbs over stock, with OME shocks, and I've been stoked on the results so far. Used this setup plus airbags for my FWC; I'm hoping to drop the airbags and just run the springs once I get the entire buildout finished. Ride quality with airbags is marginal - certain types of suspension hits (especially both rear wheels at the same time) are just wretched.
