Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Mar 11, 2020 at 10:29 AM
    #3041
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    Okay, so this isn't Drifter-specific, but it is something I'll be bringing along on all my trips and will have a permanent home in the Drifter - and you guys might think they're cool too! We just released something new at Nightfall Overland: The Helios Firepan. It folds flat for transport in the included carry case, assembles quickly with no tools, and is pretty rad. :D
    Check it out if you're curious: www.nightfalloverland.com/gear/firepan
    As my Drifter buildout gets closer to completion, I'll be building Drifter-specific screens, insulated covers, etc., this spring.
  2. Mar 11, 2020 at 10:32 AM
    #3042
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    looks cool man! Stoked to see what else you guys come up with :thumbsup:
  3. Mar 11, 2020 at 8:50 PM
    #3043
    huruta
    huruta Well-Known Member
    Christy
    Seattle
    2015 DCLB TRD Sport
    Drifter....ARRIVED!
  4. Mar 11, 2020 at 9:40 PM
    #3044
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I have seen one in use many times. Sat around it at dusk many times. It works great as far as I can tell. I don’t personally own one. I would like to after using it though.
  5. Mar 11, 2020 at 11:26 PM
    #3045
    9thhope
    9thhope Well-Known Member
    Los Angeles
    2018 Cement DCSB TRD Off Road
    I got one that I use regularly.
    Pros, compact and packs flat, grill works well and there's a bunch of different attachments you can use. For cooking I like to use charcoal with it.
    Cons, kind of heavy to lug around especially with the charcoal grate, if you choose to use wood instead of the charcoal for grilling, the wood will have to be split into smaller pieces to fit under the grill opening.
  6. Mar 12, 2020 at 7:38 AM
    #3046
    cwhet10
    cwhet10 IG: badassbrunette
    Cristin
    2015 Barely Stock TRD Sport
    Thank you!
  7. Mar 12, 2020 at 9:10 AM
    #3047
    joeydurango
    SW Colorado
    Haven't seen that exact model before, but we've seen similar... obviously everyone may have their own priorities, but when designing the Helios, we prioritized simplicity, ease of setup/use, and relative light weight. The Helios is equally functional with the grill option, half the weight, packs down much smaller, costs much less, is made in the USA by a small six-person business, and (importantly) takes up way less storage space in your Drifter! :)
    EDIT: Adding a photo for people who want to see the entire Helios in a daylight shot without going to the site.
    Happy Heathen likes this.
  8. Mar 12, 2020 at 10:44 AM
    #3048
    White Mountains
    White Mountains Well-Known Member
    Kevin
    Massachusetts
    Curious as to why you have 2 kinds of steel grill options.
  9. Mar 12, 2020 at 10:50 AM
    #3049
    joeydurango
    SW Colorado
    Good question - we originally did a stainless steel grill for ease of maintenance and cleanliness, since it is a food surface. But we decided to add a less-expensive non-stainless version for people who are okay with occasional cleaning and rust management - people like us at Nightfall, really! :D
    We're considering adding a completely stainless steel package - firepan AND grill in stainless. Would be significantly more expensive - stainless ain't cheap - but would be less maintenance. And, well, it would be shiny. o_O
    Bentrodder likes this.
  10. Mar 13, 2020 at 5:59 AM
    #3050
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    For those of you who have had your Drifter awhile & also have pretty robust (heavy!) build outs, how many have done upgrades to your brakes like bigger fronts or converting to rear discs? I was just curious what options were out there in that regard. Seems to me if I end up w/ 1200# of payload once I am loaded for fun, it might be something I want to consider.
    Anderson likes this.
  11. Mar 13, 2020 at 6:08 AM
    #3051
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    I’d be concerned with rear axle upgrades as the weight keeps adding up. Especially 2nd gen Offroads.
  12. Mar 13, 2020 at 7:39 AM
    #3052
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I did Stoptech 6 piston BBK up front, Currie Ford 9” rear axle with Stoptech 4 piston BBK conversion in the rear.
    https://sosperformance.com/t/tacoma
    tacomgee, Eazy.E, rob1208 and 5 others like this.
  13. Mar 13, 2020 at 7:47 AM
    #3053
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
  14. Mar 13, 2020 at 7:52 AM
    #3054
    joeydurango
    SW Colorado
    Haven't finished my Drifter buildout yet, but keeping things simple and lightweight is a major priority. With my FWC, fully loaded for a week out with two people, a dog, bikes, supplies, water, and personal effects, we pushed 600# over GVWR at times. No upgrades except suspension front and rear. While I didn't like being so overweight, honestly I never felt that the truck did too badly. Corner handling wasn't awesome, as expected. But acceleration and stopping were never an issue. Never felt the need to upgrade brakes. Can't know exactly what was happening with wheel bearings and differentials - hopefully nothing major that will bite me down the road.
    My current build should keep me well under GVWR most of the time, and less than a couple hundred pounds over when fully loaded for bear. Also keeping all weight as low as possible for better handling.
    Wackyhacky[QUOTED] likes this.
  15. Mar 13, 2020 at 7:52 AM
    #3055
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I have a StopTech 6 piston BBK up front. I plan on addressing the rear later.
    rob1208 and Wackyhacky[QUOTED] like this.
  16. Mar 13, 2020 at 8:02 AM
    #3056
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    @Anderson or @jberry813 Do you recall the PN for the front StopTech kit? I have been all over their damn website & cannot seem to find it even though I know it exists. I am sure it is pricey set.
  17. Mar 13, 2020 at 8:03 AM
    #3057
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  18. Mar 13, 2020 at 8:08 AM
    #3058
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
  19. Mar 13, 2020 at 10:26 AM
    #3059
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I called in to verify that the kit I was ordering would clear with my factory 16” Pro wheels. The dude that I talked with was super rad and informative. He got me square on everything and threw in the TW groupbuy discount that @Iggy setup way back when.
    Rear disc brake conversion is on the to do list but I still need to decide on an axle upgrade or not... Basically just another @jberry813 fanboi here tryin to stunt on his ride...
  20. Mar 13, 2020 at 10:43 AM
    #3060
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    +1 with the stoptech bbk up front. I have 16" SCS wheels so I went with this bbk
    https://sosperformance.com/products...-fits-2005-18-toyota-tacoma-w-slash-16-wheels
    I'll eventually do something about the rears.
    Anderson[QUOTED] likes this.
