Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Nov 13, 2020 at 2:04 PM
    #4481
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yeah, that's why I don't have a heater yet. I'm trying to research more on if the cheap ones can be adjusted for elevation or if they will just be filling up with soot from improper combustion.
  2. Nov 13, 2020 at 2:10 PM
    #4482
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    @excorcist has been running one of those cheaper heaters for a while now in his AT Habitat.
    socalexpeditions and excorcist like this.
  3. Nov 13, 2020 at 2:18 PM
    #4483
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    I believe most will run the heater on full periodically to blow out all the soot from the system.
    I’ll let you know how it works in altitude
    cmacblue42 likes this.
  4. Nov 13, 2020 at 2:31 PM
    #4484
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Mine is a 5kw if I remember right, haven't used it in a while since I sold my Tacoma and GFC but did fire it up a few times in Colorado around 6000' without problems. If you come through Colorado Springs I'd sell it to you since its just sitting in the garage now.
  5. Nov 13, 2020 at 2:42 PM
    #4485
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    The Chinese diesel heater has been awesome. Wouldnt want to camp in cold weather without it now that I have had it.
    They are seriously efficient little heaters. Was just using it last week at about 8000 ft in elevation. If you run it on low for long periods of time using diesel it soots up. It is easy to take apart and clean, but I have since switched to kerosene which apparently burns cleaner. They sell these convenient jugs at walmart for like $7.
    This is how I set mine up, routed intake and exhaust through the cubby on top of the wheel well. The box below it holds two 35ah batteries. I use the truck bed alot still so didn't want a full interior build out.
    NYCO, SDGrandpaTaco, JasonLee and 2 others like this.
  6. Nov 13, 2020 at 2:48 PM
    #4486
    excorcist
    Reno, NV
    socalexpeditions and JasonLee like this.
  7. Nov 13, 2020 at 5:28 PM
    #4487
    venisontaco
    venisontaco Well-Known Member
    Does anybody run a heater buddy? Seems like a cheap portable option, but it doesn't have a thermostat. I would think it would be hard to control temp. Maybe set on low and then crack tent windows....?
    socalexpeditions likes this.
  8. Nov 13, 2020 at 5:45 PM
    #4488
    socalexpeditions
    Yes. Problem is it creates so much dang condensation, and eats all my propane. Also it’s finicky to start when really cold outside. I love it but it’s just not clean heat.
    If I was between buying a $74 buddy or $115 chinese diesel heater as a first purchase, I’d pick the latter.
    rob1208 likes this.
  9. Nov 13, 2020 at 5:54 PM
    #4489
    venisontaco
    Ok, that makes sense. Is it a straight forward install?How are people setting them up? Thanks
  10. Nov 13, 2020 at 7:38 PM
    #4490
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I have a 5kw also. Unfortunately, even on the lowest setting its overkill (btw use hZ setting instead of the temp setting). You wont be able to sleep with the heater on all night on the lowest setting - too damn hot! Essentially you can turn it off/on as you please (hopefully with a remote so you’re not getting in and out of bed), but the heater pulls some amperage when you turn it on. Once the glowplug is on and heated, it only uses diesel (I use 100% kero instead). If your battery doesnt have enough juice, the heater wont turn on.
    In hindsight I should have gotten the 2kw version so I can keep it on all night but it still does the job
    EDIT - Also, if you have to install the fuel tank in the camper, you'll want to make a breather for it. The tank will expand with heat and/or elevation and the cap isn't efficient enough to hold the fumes in. Your camper will reek like gas and it will linger. I got some fittings at the local hardware store and pretty much did the same things I did with the rear diff breather - even used the same Toyota breather.
    infensus, NYCO, rob1208 and 3 others like this.
  11. Nov 13, 2020 at 7:43 PM
    #4491
    MJonaGS32
    MJ
    SF Bay Area (East)
    I think another issue (maybe) with the diesel heater is because it gets so hot in the camper, I think my fridge is overworking itself at night just to keep temp. All of this is usually no prob with my dual batt and solar set up, but when northern CA had the forest fires and crazy smoke in the air, my solar wasnt pulling anything during the day and I couldn’t use my heater on the 3rd night. Thankfully it wasn’t too cold that night (40°c) but the wife wasn’t happy haha
    tyfoon11 and socalexpeditions like this.
  12. Nov 13, 2020 at 7:49 PM
    #4492
    MJonaGS32
    MJ
    SF Bay Area (East)
    I had the buddy heater for a while before the diesel heater. Doesn’t work well in high elevation (where its usually colder and would necessitate a heater!!) and the condensation sucks big time. Did I mention it sucks at high elevation? Trying to turn it on in the middle of the night repeatedly pressing and repressing the knob to turn the pilot on is annoying as hell and you’ll be wide awake by the time you end up turning it on (or giving up).
  13. Nov 13, 2020 at 8:07 PM
    #4493
    JasonLee
    15 TRD OffRoad
    Hm, I tend to run warm anyway and if I'm going to get a heater, I'd like it to be able to cycle on and off through the night to reduce/stop the condensation from the water vapor coming out of 2 humans and 1 dog...
    I wonder if the smaller ones have such a large amperage draw as well.
  14. Nov 13, 2020 at 8:16 PM
    #4494
    MJonaGS32
    MJ
    SF Bay Area (East)
    These heaters aren’t really meant for constant on/off. Like I said they take some battery juice at start up, and there’s also procedure that automatically cycles through when you turn it off. This is what helps with eliminating soot like others have talked about. That’s why a 2kw unit on the lowest hZ setting will be ideal. Leaving the fan lid or tent windows open can also help.
    Also - forgot to mention that the fuel pump ticks kinda loud. If you have to install the unit like the one @socalexpeditions has, you can mod this by wrapping the pump with neoprene or foam or something. The all in one, already assembled, units like I have will be a little more challenging to add this to after the fact. I don’t really have an issue with the tick because we sleep with white noise on for the baby.
  15. Nov 13, 2020 at 8:32 PM
    #4495
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    It can cause other issues, but I have a Y in my heater output line that allows me to bleed off heat to the outside with a valve. Then i just adjust the valve on the bleed line till I am comfortable and the heater can run at a constant speed all night.
    socalexpeditions and venisontaco like this.
  16. Nov 13, 2020 at 8:37 PM
    #4496
    MJonaGS32
    MJ
    SF Bay Area (East)
    Interesting!! Any pics of your set up?
  17. Nov 13, 2020 at 8:43 PM
    #4497
    Pickeledpigsfeet
    Foothills, CA
    Not right now, its in my FWC so I had more space to work with than a Vagabond. But I just used some automotive exhaust pipe and essentially made a damper in one leg like a normal fireplace chimney. I now run my heater in a pelican case hanging off the back of my FWC and havent reconfigured my Y pipe yet for the new location.
  18. Nov 13, 2020 at 8:48 PM
    #4498
    Pickeledpigsfeet
    Foothills, CA
    You could even wire up a aftermarket exhaust cut off valve and then you could control the “damper” from you bed. That was on my list but now that I am running it outside I need to do some more testing before I spend some more $.
    https://www.aliexpress.com/item/32835851208.html
  19. Nov 14, 2020 at 1:21 AM
    #4499
    socalexpeditions
    Im thinking about mounting the entire system below the truck on the spare tire mount (like @Iggy) to help with 1. keeping more room in the truck and 2. keeping that annoying ticking outta my camper, haha. I also heard to hang it by zip ties.
    MJonaGS32[QUOTED] and excorcist like this.
  20. Nov 14, 2020 at 1:22 AM
    #4500
    socalexpeditions
    Thanks for the tip! I was thinking about that.
    Where did you mount the LCD controller?
