Vagabond Drifter Camper Buildout and Mods
Discussion in 'Bay Area Metal Fabrication' started by MTNHABITOVERLAND, Mar 27, 2018.
  1. Jan 17, 2021 at 6:35 PM
    #5081
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Does anyone have experience with the relion low temp lithium battery? I know there has been a ton of discussion on charging batteries in low temps. The battle born look nice but integrating how to determine if the internal heater has the battery above freezing is unknown unless you add accessories to accomplish that.
    the relion looks like it does that for you before charging so you can use any charger. Though it’s a bit pricey I think buy once cry once.
    https://relionbattery.com/products/lithium/rb100-lt
  2. Jan 17, 2021 at 6:45 PM
    #5082
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    The main problem is that the charger doesnt know that your battery is heated. Even if you get the battery warm the charger will read the ambient temp as below 32F and wont apply the charge. Somehow you gotta get both to work together.
  3. Jan 17, 2021 at 6:48 PM
    #5083
    2ski4life7
    Seattle WA
    yeah I know from previous post redarc changed theirs to work down to -25f? Where as the older versions were 32f. Or is that still an issue? Couldn’t really tell. Maybe I’ll email redarc.
    I wonder if there is a charger that will charge regardless of ambient temp?
    also found another battery similar to the relion is life blue and seems a little better (BT integrated). And is cheaper.
  4. Jan 18, 2021 at 6:34 AM
    #5084
    Nick Nasty
    Nick Nasty Member
    Nick
    2016 Tacoma TRD 4x4 Sport
    King 3" Lift, OME rear springs, CaliRaissed LED lighting,
    Q?: How high, from the 5' 3rd Gen Bed Floor to the bottom of the bed slide (w/o interference), can cabinetry be installed/built? (sorry cwhet10 for highjacking your photo). Thank you.
  5. Jan 18, 2021 at 4:09 PM
    #5085
    cobes
    cobes habitual line-stepper
    cobes
    slc
    2000 XtraCab TRD 3.4l Auto
    Is a 3/8" baltic birch baseplate a bad idea? Everyone seems to use 1/2" and I'm curious what I'd be risking with 3/8"
  6. Jan 18, 2021 at 7:41 PM
    #5086
    excav8tor
    excav8tor Well-Known Member
    vic
    2016 Toyota Tacoma TRD sport 4x4 White
    I don't think 3/8 would be structurally strong enough if you plan on bolting cabinets to it.
  7. Jan 18, 2021 at 8:02 PM
    #5087
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    I used 3/8" plywood for my baseplate. The goal was to keep weight on my build to a minimum, so in every decision I factored weight in. One moderate-use season in, no problems. Not as durable as 1/2" I'm sure, but I'm happy with my decision so far. I bolted my homemade 80/20 cabinets and fridge slide to it and do a fair bit of high-country 4x4 driving.
    cobes[QUOTED], d.shaw and LTDSC like this.
  8. Jan 18, 2021 at 11:29 PM
    #5088
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I started having the same problem. I was thinking it was coming from the load support bar since it's more inboard and I really try to make sure the tent is tucked in as much as possible. I pulled the load bar out from it's home position, so we'll see going forward if the area sees more deterioration.
    Edit for pic:
  9. Jan 18, 2021 at 11:35 PM
    #5089
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    but wouldn’t that be rubbing the inside of the fabric?
  10. Jan 18, 2021 at 11:39 PM
    #5090
    SliMbo4.0
    Rick
    that pic of mine is of the inside
  11. Jan 19, 2021 at 10:42 AM
    #5091
    cobes
    cobes
    slc
    Mind sharing a pic por favor? Thanks for the info
  12. Jan 19, 2021 at 10:49 AM
    #5092
    breakfasttaco93
    breakfasttaco93 Well-Known Member
    Dan
    2017 Tacoma 4x4 TRD Off-Road
    Copied @Iggy propex setup for my AT Atlas.
    Mr. Nobody, SliMbo4.0, d.shaw and 2 others like this.
  13. Jan 19, 2021 at 11:37 AM
    #5093
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    That's interesting on the tent fabric wear. I do have the slight oil stain on the outer tent fabric, but have no physical damage to speak of after almost two years of regular use.
    Sinner2 likes this.
  14. Jan 19, 2021 at 12:41 PM
    #5094
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Thanks for the feedback on the scratches guys. If you close the camper where is that area located relative to everything else? My quick guess is that it may be getting caught between the shock body and the lower edge of the camper where the fabric is attached.
    All the tents have little loops on the inside, I would suggest adding some bungee cords there to help closing the tent fabric if you need it.
    SliMbo4.0 and TacoS2017 like this.
  15. Jan 19, 2021 at 1:05 PM
    #5095
    joeydurango
    SW Colorado
    Not as pro as some builds, not as basic as others... I was going for "light/simple/removable". Quite happy with the results in the real world.
  16. Jan 19, 2021 at 3:47 PM
    #5096
    Eazy.E
    Erik
    Snohomish, Wa
    You going to start dialing in insulated window covers for the drifter or still having too much fun using it to bother? lol
  17. Jan 19, 2021 at 4:05 PM
    #5097
    socalexpeditions
    What material does goose gear slide into their 80/20? I thought it was something like 1/4" HDPE but I can't tell.
  18. Jan 19, 2021 at 4:07 PM
    #5098
    joeydurango
    SW Colorado
    Haha! :D
    Honest answer: The pandemic is crushing us, but not in the ways one might expect. After an initial scary dead period, both of our businesses (both outdoor related) absolutely blew up... and we haven't been able to keep up since. It's partially high demand and partially COVID employee scheduling - we're scheduling seven days a week in the shop and everyone is working from home as much as possible, trying to minimize crossover between employees.
    For now we're focusing on bringing our lead time down and building inventory back up so that not everyone has to HAVE a lead time. Once we get to a good place in those regards, we'll refocus on new products, including Drifter stuff. But so far, it looks like 2021 is going to be very similar to 2020 - that is, nuts.
  19. Jan 19, 2021 at 4:08 PM
    #5099
    joeydurango
    SW Colorado
    It looks like ABS to me, and I'd assume 1/4".
    On my homemade cabinets, I used 1/8" ABS on the outside, and 1/8" coroplast on the inside. Lighter, plenty strong, and hidden benefit: Coroplast is white, so the interior of the cabinets is nice and light, easy to find what you're looking for.
    Trdooper and Wackyhacky like this.
  20. Jan 19, 2021 at 4:18 PM
    #5100
    socalexpeditions
    Do you have a picture by chance? I just need to replace the 1/8" birch that is slid in with something else. Tired of the carpet holding in smell and its too dark inside for my taste.
